Old 10-25-2011, 06:48 PM #1
Jason02 Jason02 is offline
Jason02 is on a distinguished road
vsc/vsc off/and traction control lights
what up everyone , i have a 2005 4runner sr5 and today the vsc, vsc off the traction control light, and the check engine lights (which I got code 420 which is a o2sensor) came on. I rest the code and all the lights went out, about 20 miles later there all back on Any help would be great
Jason02 is offline   Reply With QuoteReply With Quote
Old 10-25-2011, 08:38 PM #2
Daron-t4r's Avatar
Daron-t4r Daron-t4r is offline
Daron-t4r is on a distinguished road
Daron-t4r's Avatar
Gas cap, I had the same problem.
2005 4WD Limited V6. Pacific Blue Metallic -- "The Fourplayer"
Current Mods: +ToyTec Ultimate Lift w/ Superflex and Bilstein 5100s + Cobra Iphone Radar detector/voltometer + aFe stage 2 CAI w/ pro-dry + URD MAF calibrator
Daron-t4r is offline   Reply With QuoteReply With Quote
Old 10-25-2011, 08:45 PM #3
Dunk50 Dunk50 is offline
Dunk50 is on a distinguished road
Yep, don't argue, don't over think it and quit looking!! Gas cap is loose or bad!! Replace or tighten!! If you disconnect your battery for 5 minutes after replacing / tightening the lights will go out and stay out!!
WELL, I just got done eating a 3 1/2 pound crow. Jason, all my lights were on just like yours. I did a search and found the gas cap answer. I put on a new gas cap, unhooked the battery for 5 minutes, hooked battery back up and all was good FOR ABOUT A WEEK!! That's why I answered the way I did. TODAY THE SAME LIGHTS CAME BACK ON!!! Grrrrrrrr!!!! I hate to take my runner to the dealer to have them start replacing expensive items until the find the right answer accidentally. Mean while the lights will be out a week at a time until they luck out!!
Military at 17, 7th SFG Ft. Bragg, 10th SFG Bad Tolz, 5th SFG Nam, 34 Years South Bend Police and retired. Should be fishin but I'm on here!
Dunk50 is offline   Reply With QuoteReply With Quote
Old 10-26-2011, 06:28 PM #4
pauls4runner pauls4runner is offline
pauls4runner is on a distinguished road
A P0420 code is not for an 02 sensor, its your bank 1 catalytic converter not working properly. you will only be able to get your CEL to stay off for small periods of time before coming back on. the only way to keep from having a P0420 come back on is to replace your bank 1cat
pauls4runner is offline   Reply With QuoteReply With Quote
Old 10-26-2011, 07:39 PM #5
Paul, I am going to guess that the cat is expensive. With 36K on my runner I would expect it to last longer. Either poor cat or poor gas!!
Old 10-27-2011, 09:17 AM #6
cats are expensive unfortunately. most usually have a longer life than what yours have unless their is an issue with gas or if the spark plugs are fouled
Old 12-01-2011, 05:21 PM #7
UPdate on this thread. Just took the runner into Toyota. They ran diagnostics and said the cat. converter was bad. Said something about it and a manifold and $2000. Then he tells me all covered under warranty. All parts ordered and appointment for next week. COOL!! FREE is COOL!!
Old 12-02-2011, 10:48 AM #8
034RUNNER's Avatar
034RUNNER 034RUNNER is offline
034RUNNER is on a distinguished road
034RUNNER's Avatar
Yep, I had this happen a few times; once it was the cat like you're saying, and the other times it was the O2's.
'03 4Runner Sport Edition SOLD
'02 Corvette Z06
034RUNNER is offline   Reply With QuoteReply With Quote
Old 12-10-2011, 11:46 AM #9
Ding Ding we have a winner!!!!!!!!This is what they just replaced under warranty. They also said something about the manifold being cracked. At any rate so far so good and FREE, FREE is good!!
Old 01-11-2012, 05:06 PM #10
Slipstick Slipstick is offline
Slipstick is on a distinguished road
Gas Cap Verified
I have the 2003 4 liter 6, sport edition 4x4. Engine light came on, code reading indicated Catalytic converter malfunction, bank 2. Also VSC Off and VSC Trac lights came on - all the time.
I was ready to replace lots of stuff for lots of money.
The big help was " Stop over thinking this - buy a new gas cap". For $25 the problem appears to be fixed. I did remove the negative cable from the battery and let the systems discharge for an hour or so.
It appears that somewhere in the computer decision tree, it thinks that if the emission system isn't working right, it would be a good idea to disable the traction control system. Doesn't make sense to me, but I'm glad the gas cap fixed it.
Thanks for the help in the thread.
Slipstick is offline   Reply With QuoteReply With Quote
Old 01-16-2012, 11:42 PM #11
Kopasz's Avatar
Kopasz Kopasz is offline
Kopasz is on a distinguished road
Kopasz's Avatar
2003 4x4 limited here with same issue. Mine are he bank 2 cats that are bad (apparently). Anybody know if the bank 2 cats are the hard to get to ones? If they can be replaced with aftermarket parts and welding, I can save a lot of bank.
Of course, I'll try the gas cap trick first.....
adam
2003 Stratosphere Mica 4Runner, Bronze Limited Wheels, 1" Spidertrax spacers, 1" DS front levelers, constant 12V outlets in center console, more to come......
Kopasz is offline   Reply With QuoteReply With Quote
Old 01-19-2012, 11:36 PM #12
Huskey's Avatar
Huskey Huskey is offline
Huskey is on a distinguished road
Huskey's Avatar
You guys need to let your 4runners idle and warm up for at least 30 seconds (best is a minute or better would be two) before you start driving, especially with the V8's - then no more broken cats or exhaust manifolds. As for the gas cap... minimum 3 clicks!
Learn to be patient with your 4runners... step one - wait for the backflip, and just be patient as it takes time.
Limited 05 T4R - Custom Built 6" Lift <--If you watch long enough he will do a backflip
Huskey is offline   Reply With QuoteReply With Quote
Old 04-28-2014, 12:18 AM #13
daniellierman daniellierman is offline
Real Name: Daniel
daniellierman is on a distinguished road
Real Name: Daniel
Who'd uh thunk
I have had those stupid lights on for over a year. Just read this post, went out and tighten my gas cap 3 clicks and they are now off ! Thank you.
daniellierman is offline   Reply With QuoteReply With Quote
traction control and stability control cmills 5th gen T4Rs 7 02-07-2011 11:28 PM
'08 4Runner check engine/vsc/traction control lights Ant3_16 4th Gen T4Rs 2 03-11-2009 12:32 AM
traction control, tire pressure, CEL, VSC warning lights on !?!?!?! ///Mracer 4th Gen T4Rs 11 01-27-2009 12:35 AM
traction control DesertBelg 4th Gen T4Rs 1 04-01-2008 09:41 AM
Traction control and comp aided stab lights Larry Maintenance/Detailing 1 03-29-2008 11:56 PM
