Thread Tools Rating: Thread Rating: 5 votes, 5.00 average. Display Modes
Old 06-05-2012, 04:44 PM #46
OrdnanceMarine OrdnanceMarine is offline
Real Name: David
OrdnanceMarine is on a distinguished road
Real Name: David
This issue is important enough to those towing heavy loads that it makes sense to sticky this one so that new folks looking to tow with their 4Runner will be less likely to overlook this detail. I was within a week of making this mistake with a maximum tongue-weight load and I'm sincerely grateful that this thread got my attention!
2007 V6 SR5 4WD - OME 884/Toytec Superflex with Bilstein 5100s - Air Lift 60809 Air Bags - Sixity Wheel Spacers - Draw-Tite 75155 Receiver - Tekonsha P3 Electric Brake Controller - B&M 70264 Tranny Cooler
2006 Jayco Jay Series 1206 PUP - 3450 lb GVWR/14' Carson Landscape Trailer - 7000 lb GVWR/16' Wells Cargo Enclosed Trailer - 7000 lb
16-19 MPG City/20-22 MPG Highway/17-20 MPG w/Jayco @ 55 MPH/16-19 MPG with Landscape Trailer @ 5500lb @ 55 MPH/12-14 MPG with Enclosed Trailer at 55-60 MPH @ 6000lb - Pushing air sucks gas!
OrdnanceMarine is offline   Reply With QuoteReply With Quote
Old 06-07-2012, 10:22 AM #47
CAN-03runner's Avatar
CAN-03runner CAN-03runner is offline
CAN-03runner is on a distinguished road
Yes this thread/information in it is important. Crucial even.
My 4runner manual says
V6 5000 lbs
V6 with WD 6400 lbs
V8 7000 lbs no mention about WD or not. I've been skeptical of that since on this forum often the differences in V8 hitches for the 4runner has come up. Without having read this forum, I would have never questioned it, and just went on to pull up to 7000lbs with thinking about it.
Plus my manual atleast doesn't even talk about trailer brakes. I've seen manuals from other makes that give different rating for unbraked trailers vs braked trailers. And the difference in 1000's of lbs.
2003 4Runner Sport 4.7 V8 Silver/Grey - Fr/Rr ARB Locker - OME 885/895 - LR UCA - BFG KM2 255/80/17- RCI Skids - Demello Sliders - Bud Hidden Winch- Runva Winch - Synthetic oils- Trail Stripes - Two Baby Seats...
1984/86 4runner In Progress....... V6 swap - High Steer - 33" MTZ - 4.88 Gears - welded rear - ARB front - axle gaussets - Diff covers - Longfields - 4.7 crawler - Titan Winch http://www.toyota-4runner.org/classi...ner-build.html
CAN-03runner is offline   Reply With QuoteReply With Quote
Old 06-07-2012, 12:06 PM #48
Ross Ross is offline
Ross is on a distinguished road
V6 5000 lbs
V6 with WD 6400 lbs
There seem to be different versions of owner’s manual, maybe even within the same year. Maybe not all 4th gens are the same in this respect.
My owners manual says:
Towing capacity (trailer weight + cargo
weight), kg (lb.):
For weight carrying hitch 2268 (5000)
Also for weight distributing hitch2UZ- FE engine onlyTwo- wheel drive models
3311 (7300)
Four- wheel drive models
3175 (7000)
Ross is offline   Reply With QuoteReply With Quote
Old 06-07-2012, 12:30 PM #49
weight), kg (lb.):
3311 (7300)
3175 (7000)
Ross. I think there might be several revision of the manual too. I'm in Quebec, Canada. So I have a French manual with mine. Sometimes I think it was translated from Japanese, to English, to French. French isn't my first language. But I ask my buddies for who it is their first language, and they don't understand some of the words either.
Example: the French wordage used to describe the WD hitch and attachements etc...is really applicable to attachements for horse drawn carriages with a harness.....
Old 06-07-2012, 01:42 PM #50
Real Name: David
Real Name: David
I get the feeling it's translated too (see the gross error regarding the receiver in earlier posts) but I also have heard that companies have gone more conservative in their tow ratings over the past 5-10 years, possibly in response to too many owners overloading their rigs because they don't understand how to calculate what can be reasonably towed. How many folks out there think a 5000lb tow rating and 500 lb tongue rating means you can slap a 5000lb trailer with 500 lb of tongue weight and THEN load up the TV with another 1000 lbs of people and gear, especially gear over and aft of the rear axle and tow just fine? My thought is that lots do. I'm an engineer and before I started reading up on towing I thought this as well. Thankfully I just so happened to have the interest and take the time to drill down and figure out how things really ought to be. Where I live and drive I see countless rigs that must be thousands of pounds over the ratings. All is fine and dandy until you need to stop. Most of the other effects of overloading your TV don't show up until thousands of miles down the road.
Old 10-07-2012, 06:19 PM #51
CincyGuy CincyGuy is offline
CincyGuy is on a distinguished road
Unhappy Yikes! Can I get an after-market WDH Receiver?
Originally Posted by TechWrench View Post
What I think you are missing, is the difference between the oem V6 hitch receiver, and the heavier duty V8 hitch receiver. Because of the way it is mounted to the rear crossmember only, the oem V6 hitch receiver is NOT rated for use with any type of Weight Distribution system (it states this in the owners manual) only weight carrying hardware is permitted. According to the figures in my owners manual, the 4WD V6 hitch receiver is rated for a maximum of 500 lbs tongue weight and 5,000 lbs trailer (towed) weight. But with the optional towing package installed (frame mounted hitch receiver, and aux trans cooler), these numbers are increased to 640 lbs tongue weight and 6,400 lbs max trailer (towed) weight for the 4WD V6. The V8 numbers are higher.
As I tried to explain in my earlier post, because of the rotational torque that a weight distribution system imparts to the hitch receiver, the crossmember mounted hitch receiver is not rated for any type of weight distribution system. With enough load applied via the weight distribution system, the rear crossmember may twist out of position. This is why only a frame mounted hitch receiver is rated for any weight distribution system.
Thanks for the thorough explanation! I’ve been looking for one for a long time.
I have a 2007 V6 4Runner. I thought I bought the “trailering package”, but my sticker says I paid $430 for Option TO, which is a “Weight-Carrying Tow Hitch and Ball Mount Kit” (which I believe includes a transmission cooler).
I want to tow a 3300 lb Casita, and am buying one that has an after-market WDH, which I believe would be highly desirable (if not necessary). However it looks like I need a WDH RECEIVER on the 4Runner. Questions:
1. What good options do I have if I stick with the Weight-Carrying Tow Hitch?
2. Can I buy an aftermarket WDH? Who from? Is thaht cost-effective?
3. Would it make better sense to trade-up to a V8 4Runner? Or should I look a bigger tow vehicle?
Thanks!
CincyGuy is offline   Reply With QuoteReply With Quote
Old 10-08-2012, 08:39 AM #52
Pepedog11's Avatar
Pepedog11 Pepedog11 is offline
Pepedog11 is on a distinguished road
Pepedog11's Avatar
Thanks!
This is one of the most confusing threads I have yet to read. It took me a good bit of research to figure out what I have myself.
I have the 2008 4.7 V8 with the towing package. On the hitch itself (factory)there is a sticker stating tounge wieght limmits for both use as a weight-carrying and weight-Distubing hitch. Take a look back there and see what you have allready.
In my opinion the weight of what you want to tow is fine and you will be conforatable, but you do not mention the tounge wieght. If that is within the limmits I think you would be fine. But I got no doubt that with a WDH it would be safer smoother ride.
Pepedog11 is offline   Reply With QuoteReply With Quote
Old 10-09-2012, 12:05 PM #53
Real Name: David
Real Name: David
Thanks!
You're pretty much at the same point I was a few months back. I'm towing a 2006 Jayco 1206 pop-up that has a GVWR of 3450lb and I tow it near or at that number. Here's my answer to your questions:
1. If you stick with the weight-carrying hitch receiver (the one bolted directly to the last frame crossmember) you CAN NOT use a weight distributing hitch with the spring bars hooked up in design mode. You can, however, tow without hooking up the spring bars or just purchase a standard ball and shank of the correct height. Additionally you could install an "air bag" suspension kit to adjust the ride height and distribute some of the load forward so your rear end doesn't sag and your front end doesn't end up riding high. Some members here have done this and you can check one out at Air Lift Vehicle Suspension for Toyota 4Runner 2007 - AL60809
2. You can definitely buy an aftermarket weight distributing hitch receiver. I ended up paying someting in the $135 range for mine after rebate. I purchased the Draw-Tite one Draw-Tite Trailer Hitch for Toyota 4Runner 2007 - 75155, had e-trailer.com match the lowest price I could find elsewhere and then sent in for the $30 rebate that was being offered. If you go this route you'll have the best possible solution since towing with a weight distributing hitch - receiver combo is as good and as safe as it gets.
3. I don't think there's any need to trade up to a V8 Runner to tow a 3300 lb trailer. Sure, it will tow it a bit easier but I've never found the engine to be the limiting factor. Instead, I tow pretty high and pretty steep during the peak summer heat and I have to keep speeds down to keep the transmission cool. Two advantages of the V8 are that they come with a weight-distributing hitch receiver and a secondary transmission oil cooler already installed.
Additional notes, if you do not have an aftermarket transmission cooler and you plan on towing, get one, plain and simple. The V6 does NOT come with an aux cooler and having one makes quite a difference in the temps I see via my ScanGaugeII http://www.toyota-4runner.org/towing...evelation.html
One more thing if you haven't considered it yet: Do you have electric or hydraulic (surge) brakes on the trailer? I converted my Jayco from surge to electric brakes and couldn't be more satisfied with the upgrade.
Old 04-05-2014, 12:45 AM #54
kaatahdin kaatahdin is offline
kaatahdin is on a distinguished road
Revivial
Thought I would post on this really old thread, since I was looking into a WD hitch. Mine does have the sticker with weights listed (v8).
Weight bearing = 7300 total / 750 tongue
With WD hitch = 7300 total / 1095 tongue
kaatahdin is offline   Reply With QuoteReply With Quote
Old 04-05-2014, 12:51 AM #55
Real Name: David
Real Name: David
I was aware of the higher weight for the V8 but not the higher allowed tongue weight for the V8 with the WD hitch. Makes me think I have more margin than I thought when towing the heavy (for a 4Runner) loads that I've started doing. Thanks for the heads up!
Old 04-14-2014, 06:45 AM #56
ebg18t ebg18t is offline
ebg18t is on a distinguished road
@OrdnanceMarine - do you have an install thread for your B&M tranny cooler ?
'14 VW Touareg & '15 Porsche Cayenne
Sold -- 2004 4Runner SR5 4WD V6 | Properly built & prepared for overland use!
ebg18t is offline   Reply With QuoteReply With Quote
Old 04-14-2014, 06:25 PM #57
Real Name: David
Real Name: David
I think this was it. I attached mine differently and both my supply and return lines both pass through the frame hole on the right and I lined the hole by splitting some extra transmission hose and placing it over the sharp metal edge for protection. Two years later it looks great and is doing exactly what I need it to. I'd recommend this mod to everyone with a V6 that does any towing, off roading or extended climbs in hot temps.
Transmission Cooler Install
Old 04-14-2014, 08:11 PM #58
Any major difference between the Hayden and B&M coolers?
Where did you install the P3 controller?
Old 04-16-2014, 01:59 PM #59
Real Name: David
Real Name: David
I don't remember why I chose the B&M over the Hayden. I see two B&M 70268 coolers at Amazon under "used" stating that packaging may be damaged or repackaged for under $44.
I installed my P3 just above/forward of where my right knee sits when I drive. I'm a little concerned about the damage that will happen to my knee if I ever get in a forward collision so I'd probably consider a slightly different location, maybe a few inches higher but the options were limited unless I wanted to splice extensions on the wiring harness to move it to the cupholder area and relocate my cupholders. I'd probably spend a little longer thinking about where to mount it than I did but having it just above my knee means it is very visible and easy to manually activate the brakes or change a setting while underway.
Old 04-16-2014, 07:48 PM #60
Thanks for heads up on the B&M coolers.
Is the p3 small enough to fit in the storage compartment under the HVAC controls?
Weight Distributing Hitch? Yes or No? Shooter33 5th gen T4Rs 29 01-31-2016 05:14 PM
Weight Distributing Hitch CXS For Sale: T4R Items 0 08-26-2011 05:47 PM
Weight Distributing Hitch Questions SurfToy Engines / Suspension / Wheels / Tires / Audio / Accessories 1 02-03-2010 04:20 PM
Installed Weight Distributing Hitch LV4R Engines / Suspension / Wheels / Tires / Audio / Accessories 14 06-01-2006 12:41 AM
Weight-distributing hitch for 2003-4 surfman Engines / Suspension / Wheels / Tires / Audio / Accessories 7 03-06-2004 12:17 AM
