02-05-2013, 01:53 AM
#46
Thanks to everyone sending email addresses early!
1997 FZJ80
02-06-2013, 04:03 PM
#47
Ordering is starting to cool off, but there's definitely still time to get your order in.
Ordering will stay open until February 28.
1997 FZJ80
02-06-2013, 11:41 PM
#48
1997 FZJ80
02-07-2013, 01:40 AM
#49
Payment sent for 2x TrekPod OctaPlus (Squares, Flood Beam) and a FloodPod.
For those on the fence - the photos of the lights and their performance speak for themselves.
However, the customer service I've received thus far has been OUTSTANDING and deserved mention. If the rest of this purchase process goes this smoothly I'll have to say that this is some of the best customer service I've ever received. My emails have been answered promptly and Troy definitely knows his stuff.
2016 Trail Premium - Icon Stage 3 Lift, SSO Sliders, RCI Skids, SSO Slimline Bumper with High Clearance Add-ons (awaiting install), Ryder RR01 wheels (awaiting install), BFG KO2's 285/70/17, Morimoto XB Headlights, and more to come...
SOLD: 04T4R Limited V6 4WD
02-07-2013, 03:19 PM
#50
Will Definitely be ordering one! Just can't decide yet!
02-08-2013, 09:48 AM
#51
Thanks for those kind words, John!
1997 FZJ80
02-08-2013, 09:56 AM
#52
Everyone who sent me their email addresses Monday-Yesterday should have an invoice
1997 FZJ80
02-08-2013, 10:15 AM
#53
Moderator
Real Name: Waldo
Moderator
Real Name: Waldo
lol your neighbors must hate you
BTW, that little Octa+ light is a flamethrower! Nice!
'99 Toyota 4Runner LTD - Dual Locked | Geared | Mid-Travel | 35s | Armored
02-08-2013, 10:57 AM
#54
They've never complained, so I'll just keep on telling myself that they like the light until they tell me otherwise
1997 FZJ80
02-11-2013, 11:40 PM
#55
Everyone, I'm "officially" starting to process payments today, so please let me know your email address and I'll get an invoice to you ASAP!
-Troy
1997 FZJ80
02-12-2013, 01:59 AM
#56
Hoping to put an order in for an XT series, PM in bound.
02-12-2013, 05:58 PM
#57
Hey Troy, I'm trying to determine what would work best for these needs:
- Low mounted fog lights (will cover them with yellow self-stick film), for use in heavy rain/fog/snow, possibly as a near replacement to low bean main lights as needed depending on conditions.
There are alot of 4" or Pod options that would seem to work, what would you recommend ?
- Mid/grill/upper bumper mounted Spot for offroad/long empty highway in Northern-VT type use. Probably relay off the high beam circuit and a switch.
I'm thinking of a 18" or 22" XT spot for that one. Do I need more reach for that use ?
Thanks.
2019 TRD OffRoad - Fox w/Resi, 650lb Springs, JBA HD UCA, T12 Rear Springs w/DS 5mm Spacer, Odyssey 34R-PC1500T AGM w/Diode Upgrade and CTEK Monitor, NOCO battery charger wired to external port for shore power, Rago Hidden Winch Plate, Comeup Seal 9.5 RSI, RCI Sliders/ Skids, 285/70-17 Cooper AT3 XLT on Fuel Rims, Various LED upgrades, OE Engine Heater w/External Port, XenonDepot Low Beam HID & LED 3k Fogs, ScanGauge, Midland GMRS, Accessory Mount for iPad, mike and Inreach, iKamper Mini 3.0, Custom Kitchen/Cargo system, ARB 50Q, Goose Gear dual drawer, Wilco Solo Tire/Hilift/RotoPax Carrier.
02-13-2013, 12:54 PM
#58
Thanks.
Hey greydog,
I think that for your bumper, an 18" or 22" TrekLight XT will be the perfect solution. What size you get just depends on what you have the real estate for. If you can fit a 22" TrekLight XT, go for it. Otherwise, the 18" will make you just as happy.
The fog situation is a bit of a tricky question, as true fogs are a wide, flat beam. Sinceour flood lights are wide and tall, I'd go with a spot pattern, more specifically a pair of the 4" TrekLight XT's in spot pattern.
PM me with your email address if you want to place an order, and let me know if you have any more questions!
-Troy
1997 FZJ80
02-13-2013, 07:24 PM
#59
Real Name: Bill
Real Name: Bill
Hey Troy
I seem to remember you posting some pictures of what was all included with the product- harness, relay, switch.
Can you confirm what is included please?
Another question.
I plan on using a different switch. OTRATTW ViDiFBBB
Do you see any issue with using this switch?
I want to stay with the factory type of switch as long as I have factory locations. Guess I have not done enough mods
I pledge allegiance to the flag of the United States of America, and to the republic for which it stands, one nation under God, indivisible, with liberty and justice for all.
02-14-2013, 02:12 AM
#60
Originally Posted by Desert Fox
Hey Troy
Another question.
Each light is shipping with a switch and a fuse holder. Relay and wire gauge is up to your personal preferences.
Yes, those switches should work. I've had my eye on the Zombie Lights version for a while now
If anyone is looking for a pre-built harness, I recommend this one: Low Beam: 9006/HB4 - Relay Harnesses from The Retrofit Source Inc
Paired with these (or similar) connectors: 9006 Female Wire Harness Connector Plugs Hella Ballast | eBay
1997 FZJ80
