03-03-2020, 12:27 PM
#46
-2020 SR5P 4x4
-After turning off the vehicle or after turning off from "ACC" from the ignition (PUSH Button Start)
-Noise seems to be coming from the passenger side of the car
-The noise sounds like an electrical buzzing right after turning off the car or switching the ignition to off from "ACC". The buzzing lasts for about 1 minute right after turning the car off. The sound is really subtle and may only be heard in quiet areas (inside garage).
It's not a big deal, but just curious what it is. Never heard a buzzing sound in any of my cars.
04-28-2020, 04:15 PM
#47
Help it won't let me create a new post. I have a 2002 4 runner sr5 v6 auto 4 wheel drive I have taken it to three different garages for a shake in the front end around 60 so they check it say everything is tight nothing wrong i am lost it feels like I am losing steering
08-08-2020, 11:38 PM
#48
Squeaking
Hello all, I am a new member and just purchased a 2020 trd off road 4 runner. I love it so much and can’t wait to take it to the snow. I drive it very gently so far and haven’t done much of anything. However. I hear a squeak noise from the rear end even when I slowly go over speed bumps. Not always but every once in a while. Any thoughts? Could this be a serious issue?
08-12-2020, 10:51 AM
#49
Real Name: Brad
Real Name: Brad
I have a 2020 ORP, recently bought in July.
When I have my radio off, or really low, and I press the brake, I hear a super high pitched noise. It almost sounds electrical. Has anyone experienced this?
*Note: I am sure it happens when I have music playing, I just can't hear it.
Black 2020 ORP: Bilstein 6112/5160, Dobinson 1.5" rear coils, SPC UCA's, Wildpeak 275/70/17's, RSG Sliders, Sherpa Crestone roof rack (on the way)
08-13-2020, 06:51 PM
#50
Real Name: Skip
Real Name: Skip
If it sounds like a small electric motor running it most likely the ABS/Booster pump motor, it should only run for about 10 seconds whenever you start it after setting for a while and about every 3 to 4 depressions of the brake pedal.
If so it's totally normal.
2004 Limited V8
08-13-2020, 10:57 PM
#51
Real Name: Brad
Real Name: Brad
It doesn't really sound like an electric motor, it sounds more like a super high pitched sound you'd here from a speaker or something, it is odd. I definitely have not heard the sound in any previous vehicle I have owned and can't find anything on the forum, or internet for that matter, that sounds like a similar issue. I am going to try to turn my radio completely off next time I drive, see if I hear it.
09-03-2020, 06:35 AM
#52
That's really cool...
09-06-2020, 11:38 PM
#53
Thank you for sharing those tips
09-08-2020, 06:32 AM
#54
Originally Posted by 5thgenSR5P
-2020 SR5P 4x4
I think it is coming from the radiator or the engine.
10-05-2020, 12:19 PM
#55
I have a 2001 SR5
I've replaced all the belts except the timing recently, drove a lot, tightened and accounted for heat expansion, and still sometimes I hear a little whine on the start up. Do I need to replace my timing belt or something? It is getting colder where I'm at during the night now.
My second problem is that I hear a sort of metal rattling noise that seems to be around the right side of the vehicle when I accelerate. It's not noticeable in the cabin with all the windows up, but when I have them down I can hear it, and when I drive by something like a car to bounce noise back at me I really hear it. I think it's something to do with the heat shields being loose, or something with the exhaust system, but I haven't actually gotten underneath to check those yet. Has anyone had a similar problem where it wasn't the heat shield? I already want to replace my exhaust system so i'll check when I do that, but I don't want to miss something important. For the record, it's always done that, there's no drop in RPM or acceleration, just an ugly noise.
11-17-2020, 04:25 PM
#56
Real Name: 2016 Trail Edition. Was the XP from the Southeastern Region. Rocking a TOYTEC Boss Lift, 285 Yokoham
Good afternoon!
I am rocking a 2016 Trail with 46K miles. I have put them all on myself. It has just recently started getting cold out and I am now getting a knocking sound from start-up and during some accelerations from my muffler, I believe. The sound is right under the passenger seat and it is just one clunk, not continuous while moving. However, when I look under the vehicle during start-up, it doesn't happen. I am running the MBRP exhaust system. For the price, it's everything I needed for a little more throaty sound. Has anyone else had any experience with this? Is it just because of the cold?
Thanks!
Austen
11-17-2020, 04:26 PM
#57
Originally Posted by terrarunner4
I have a 2001 SR5
I also have a rattling noise under my vehicle during acceleration. I replaced the exhaust so all of those new bolts are tight. I think it may be my heat shields as well but during the replacement, I looked at that and they were also tight. Just a 4Runner sound, I suppose.
Reason: spelling
12-11-2021, 05:21 AM
#58
Amazing tips in here. Really appreciate these as I have been having some noise issues myself. Car is at the mechanic but as soon as I get it back will re-post my situation
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
