Old 10-15-2013, 10:45 AM #1
Rooster4289 Rooster4289 is offline
Rooster4289 is on a distinguished road
What Power Inverter I need 2014 Trail
I am sure there is already a thread out here in regards to power inverters. However, I am new to this. I am getting a 2014 Trail Edition within the next week. I plan to camp/tailgate. I would like to be able to power a 36'' tv and maybe a fan. I would rather have more power than not enough, you never know what you will end up plugging in, laptop etc... Obvisiouly this is a brand new car and I will not be in the market for one for a very long time. I want to keep this thing clean as possible so I want to do everything right...
-What brand should I look at?
-Is hard wiring it a bad idea?
- What voltage inverter do I need to power this equipment?
ETC.....
By the way as I said before...I am new to this thread b/c I have put Chevy in my rearview and moved on to Toyota....Let me know if I am posting in the right place or any advice that can help me. I plan on using this often...
Rooster4289 is offline   Reply With QuoteReply With Quote
Old 10-15-2013, 11:12 AM #2
Blacksunshyne Blacksunshyne is offline
Blacksunshyne is on a distinguished road
You will get better answers in the 5th Generation 4Runner forum here 5th gen T4Rs - Toyota 4Runner Forum - Largest 4Runner Forum
Also would be helpful to know what kind the spec are on the TV that you plan on running.
2010 T4R Trail Edition BLACK + 285/70R17 BFG KM2 + Interior LED swap + Icon 2.5 stage II with LR UCAs
Blacksunshyne is offline   Reply With QuoteReply With Quote
Old 10-15-2013, 11:22 AM #3
Thanks. I have moved it to that forum.
Old 10-15-2013, 11:29 AM #4
jwyshrek jwyshrek is offline
Registered User
jwyshrek is on a distinguished road
Registered User
Well, to get the best recommendations, the power specs of what you are going to 'plug in' would be needed...worst case.
But for argument sake, a 36" TV (flat, I assume) can be 30-40W. A typical table fan can be 15-25W.
Taking worst case TV+fan is 65W total...so, if just run those two things, I would go with a 100W inverter just for margin. You can safely plug in a 100W or so inverter into a 12Vdc outlet. Anything higher would probably need to be hard wired to the battery or you'll be blowing fuses.
But that's another thing...if you do hard wire an inverter, you'll need a heavy duty (deep cycle) battery or a dual battery setup or leave your engine running.
If you don't know exactly what you'll be 'plugging in' then a small portable generator might be better...
jwyshrek is offline   Reply With QuoteReply With Quote
Old 10-15-2013, 12:14 PM #5
Rocky5000100's Avatar
Rocky5000100 Rocky5000100 is offline
Rocky5000100 is on a distinguished road
Pshh just get a 1000w inverter. Decent Ines can be had for <100, then you'll have enough room for a lot of items. I would go with a dual battery setup though. Then you can run it with the engine off.
Rocky5000100 is offline   Reply With QuoteReply With Quote
Old 10-15-2013, 05:54 PM #6
fourwd1's Avatar
fourwd1 fourwd1 is offline
Moderator
Real Name: The Chosen One
fourwd1 is just really nice fourwd1 is just really nice fourwd1 is just really nice fourwd1 is just really nice
Moderator
fourwd1's Avatar
If you want to run any expensive electronic equipment like a computer or nice flat screen TV make sure it is a true sine wave output, and that's going to eliminate all the inexpensive ones (the low dollar,high output types)
Your going to pay for a decent one.
'89 4Runner SR5 - stock
fourwd1 is offline   Reply With QuoteReply With Quote
Old 10-15-2013, 05:58 PM #7
So if I do a dual battery setup, how much will that cost? I haven't gotten the 14 TE yet but do you think there will e room for a dual set up?
Also, if I run duals, would I not have to have my car on, and when it is on it charges that second battery. Basically the setup would be so I don't kill my primary battery?
Old 10-15-2013, 06:01 PM #8
This is the tv I would run...I could not fine the wattage
Walmart Mobile
Old 10-15-2013, 06:26 PM #9
bimrunner's Avatar
bimrunner bimrunner is offline
Real Name: Ben
bimrunner is on a distinguished road
bimrunner's Avatar
Real Name: Ben
I think I may be going with this setup: http://kodiakinc.com/powersystems/dualbatterykits.html It isn't cheap (somewhere near $800 I thought) but really easy to install and takes the same room as the stock battery but you end up with dual.
2013 LE, All Pro +2 LT Front, CVJ axles, King shocks, Califab rear links, Hutchinson beadlocks, Nitto Trail Grappler 35x12.5x17, 4x4 Labs rear bumper and front bumper and sliders, tints, Bajarack, RCI skids, 4.56 gears and ARB lockers/Compressor, Rigid Lights, Rydeen 360 camera system, KK6JZH...Keeping it mild Build & Pics
bimrunner is offline   Reply With QuoteReply With Quote
Old 10-15-2013, 06:28 PM #10
snivilous's Avatar
snivilous snivilous is offline
snivilous will become famous soon enough snivilous will become famous soon enough
snivilous's Avatar
You'd want a dual battery with deep cycle so you don't kill your primary battery. The main battery is meant for lots of short high amperage pulls (for your starter) and isn't meant for extended load. A deep cycle can be run down until it's nearly dead and then charged back up but less often, like you would be using it for to run electronics.
snivilous is offline   Reply With QuoteReply With Quote
Old 10-16-2013, 01:54 AM #11
Offroad_Medic's Avatar
Offroad_Medic Offroad_Medic is offline
Real Name: Brad
Offroad_Medic is on a distinguished road
Real Name: Brad
If it were me I would just drop the money into a 1000-2000Wportable generator. That way you can run pretty much whatever you want on it plus you can take it with you anytime anywhere even if you're in a different vehicle.
Utah Desert Runners T4R
1997 T4R Limited
2004 TRD Tacoma xtra cab---Sold
Offroad_Medic is offline   Reply With QuoteReply With Quote
Old 10-17-2013, 01:55 PM #12
fourwd1's Avatar
Moderator
Moderator
fourwd1's Avatar
Yeah, those new inverter generators from Honda are real nice.
Clean sinewave output and real quite. Pricey but worth it.
2014 , power inverter , trail edition
Power inverter questions m007allred 3rd gen T4Rs 15 03-14-2019 12:20 PM
Which power inverter to hardwire? 4-Ripcord 3rd gen T4Rs 19 04-07-2013 06:25 PM
400 Watt Power Inverter for $5 MICA4R 4th Gen T4Rs 0 10-30-2011 10:45 PM
Power inverter hulk311 4th Gen T4Rs 9 05-12-2007 12:30 AM
3rd Gen Power Inverter BlackIceWAP 3rd gen T4Rs 3 05-04-2007 11:24 PM
