12-11-2013, 11:53 PM
Real Name: Matt S.
Real Name: Matt S.
Fire extinguisher
I have a fire extinguisher that I want to conciel some where in my 3rd gen for easy access but also out of sight so its not an eye sore. I could only think of once place which is the rear compartment in the back but its not very easy to access fast. If your in a panic situation it has to be of easy access... Thanks for the suggestions.
Limited 4wd 2000 3rd gen silver
Mods: ISR mod, plastidipped rims, 265/75/16 bfg all terains, front fender on bumper taken off, Flowmaster super 44, ARB D-shackles 4.75ton, 12in 1600watt peak kicker, kenwood kdc-152, crunch 2000watt max, 891 ome coils in the rear, 3inch spacer in the front, 1.25 wheel spacers all around.
12-12-2013, 12:10 AM
Real Name: Adam
Real Name: Adam
You can mount a bracket on the driver side of the back hatch area. There nothing behind there. Just screw in a couple self tappers. Its to the side, out of the way, and easy access. I plan on mounting mine to the roll bar I installed, but not everyone has one of those.
12-12-2013, 12:18 AM
Mine is in the rear compartment. I have a lot of stuff crammed in there so I cut out most of the plastic bumps and humps. This left 2 strips where you can see the body but I just stuffed some 30 minute flares in there.
In my compartment I keep a fire extinguisher, 30 foot - 3" strap, 2 shackles, 2 hitch pins, 2 pairs of gloves, coreless roll of TP, multi meter, siphon kit, duct tape, jb weld, quick steel, flares, 100' of 550 cord, small collapsible 1 liter water bladder and a space blanket.
It's not super accessible but it's out of the way for my everyday use. If it were floating around or in the actual passenger area it would either get mangled or moved because it was in the way.
12-12-2013, 10:37 AM
Real Name: Matt S.
Real Name: Matt S.
Ah ha! So ive just decided to keep it in the rear compartment, where the jumper cables should be in the little straps. It fits nicely and I had to lift the extinguisher to get the jumper cables in so I could close it. I just got a deal on 12 extinguishers for 2$ per from a hotel because apparently there is a law saying they must replace them every so often. So looks like I'm going to play with a few
12-12-2013, 10:44 AM
Real Name: Kevin
Real Name: Kevin
You want to be able to access that fire extinguisher as quickly as possible. When you have a vehicle fire, tenths of a second can make the difference between a few scorched wires and your truck burning to the ground. Whether or not the extinguisher is an eyesore should be a distant second consideration.
I have mine on my roll bar in the back. It's too far away. I'm going to mount it on the front of the drivers seat, underneath my legs.
'My needle always settles between west and southwest. The future lies that way to me, and the earth seems more unexhausted and richer on that side.' - Thoreau, sort of.
The Grey Bastard, 1985 4Runner, driveway ornament.
Utah DesertRunners T4R, for all things wheeling and 4Runner in Utah.
12-12-2013, 10:49 AM
Real Name: Matt S.
Real Name: Matt S.
I get what your saying but its better then not having one at all...
12-12-2013, 10:59 AM
Real Name: Caleb
Real Name: Caleb
I have mine on the side of the tunnel. Very easy to access, in direct sight, so if there IS a fire, anyone can see it and grab it.
92 ExtraCab on 38s: built for go, not for show
88 4runner: Solid axle, doubler, fun stuff
IG: rattlewagon
Its all about the parts you break, and the friends you make.
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
