Don't mind me just another stranger here to add his $.02.
Personally I've never had a bad experience with seafoam. I've used it many times and it has seemed to help in any case I've used it. here's a video to support my statement:
https://www.youtube.com/watch?v=agAWXnT4-EQ
I look at Seafoam the same way I look at changing ATF or switching over to a synthetic oil, It won't cause a problem if used correctly but it can make a existing problem more apparent.
My main point is that you shouldn't have any issues using seafoam if you maintain your engine. As for the OP saying that the pick-up was clogged with deposits due to the seafoam causing low oil pressure isn't likely accurate. If it is then the engine sure as hell wasn't maintained. It wouldn't have had chunks big enough to clog the pick up tube if it was. The engine in the photo below has 181k HARD miles with synthetic oil changes done every 6k-7k.
My advice is an ounce of prevention is a pound of cure. Change your oil regularly and you never will need to use seafoam in your oil. If you do have a bit of gunk you should be fine using it, personally I prefer adding some ATF into the oil when it needs to be topped off (no more than a quart in between oil changes). Good day!
