Old 01-27-2014, 11:00 PM #1
TOY2G TOY2G is offline
Real Name: Nathan
TOY2G will become famous soon enough
Real Name: Nathan
TRD Push Button Start....can it be added?
I have a friend that just got one of these from Japan for his highlander...
Anyone know if push button could be added to non limited 5th gens?
For $145 I may be willing to try, if someone had added regular push button start.
TOY2G is offline   Reply With QuoteReply With Quote
Old 01-27-2014, 11:11 PM #2
4Running Daily's Avatar
4Running Daily 4Running Daily is offline
Real Name: Connor
4Running Daily will become famous soon enough
Real Name: Connor
Anything is possible. I'm sure it wouldn't be too hard.
1996 Toyota 4Runner 4x4 w/ 5 speed- Lifted, Locked,Painted,Armored
Build: http://www.toyota-4runner.org/3rd-ge...ld-thread.html
Originally Posted by invisible4Runner View Post
Highlander = minivan, purses, soccer practice
4Runner = testosterone, steak, dirt
4Running Daily is offline   Reply With QuoteReply With Quote
Old 01-27-2014, 11:16 PM #3
Real Name: Nathan
Real Name: Nathan
I like your enthusiasm, but it says in the instructions "for vehicles equips with push button start only" and "2wd only".
How would you get around the chipped key?
Does anyone know what the back of the keyed ignition switc looks like.
I have a pic of TE back of this one...
Old 01-27-2014, 11:23 PM #4
nevada's Avatar
nevada nevada is offline
nevada has a spectacular aura about nevada has a spectacular aura about nevada has a spectacular aura about
nevada's Avatar
you could wire the keyed ignition to that button, then leave the key in the RUN position. maybe then relocated the key switch to under the dash somewhere? then cover the hole.
1985 pickup: EFI 331/4r70W-Dana 300-42 TSL SXII's/raceline beadlocks-30spl longs-5.29's-spools-sky Hi steer-OBA/4g tank-10.5k RR winch-dual blue tops-200 amp alt-flatbed.
1985 4runner sr5: 22RE/5spd-6" pro-comp suspension-37 BFG at's-5.29 gears-Badlands Basher bumper-8.5k RR winch.
2006 4runner v8 limited: stock. Build Thread YouTube Channel
nevada is offline   Reply With QuoteReply With Quote
Old 01-27-2014, 11:29 PM #5
Real Name: Nathan
Real Name: Nathan
Originally Posted by nevada View Post
you could wire the keyed ignition that button, then leave the key in the RUN position. maybe then relocated the key switch to under the dash somewhere? then cover the hole.
If I understand the Japanese instructions (and I don't) the switch is a 3 position switch push in all the way = Start, let go switch remains in Run, push in again to toggle off.
So in theory, it has start, run and off...so the question is, will it plug in to the harness, and can you HUD a key in the dash close enough to trigger the transponder???
It shows to fit about 40 variations of Toyota vehicles....so I would have to guess the ignitions in most of them (newer one) are very similar.
Old 01-28-2014, 01:12 AM #6
eddiebx's Avatar
eddiebx eddiebx is offline
eddiebx will become famous soon enough eddiebx will become famous soon enough
eddiebx's Avatar
More than likely I think it probably means that it fits 40 variations of Toyota vehicles which already have a smart key...ie. replacing the factory push to start button with the fancy TRD one.
The only way I see this as being a feasible add-on into your current 4runner is if you use it as just a start button in addition to the regular key. I really doubt there's 3 actual electrical positions in the button itself, it sure feels like it's only just a momentary on-off switch...
eddiebx is offline   Reply With QuoteReply With Quote
Old 01-28-2014, 01:26 AM #7
Real Name: Nathan
Real Name: Nathan
You may be right, but it does have 4 pins. Leads me to believe there is mote than on-off. I'm sure one is illumination. But consider this, if it was just an on off. How would it start the vehicle and the disengage the starter once running. And the when you push it again, how would it shut off and not re-engage the starter..
Just thinking out loud. I have push button start In my 83 Hilux (has a Lexus V8). Perhaps I will look at it a little closer.
Old 01-28-2014, 02:06 AM #8
eddiebx's Avatar
eddiebx's Avatar
All those functions you mentioned are controlled via a computer I believe, I think it just detects the push button actuation and does it's thang...it's been a while since I sold my old car that had the smart key, but I am almost positive that when you are engaging the "start" function, you can let go of the button mid way and it will continue cranking until started. Same with turning it on and off...for example if I press the button once while I am in park it will turn it completely off; if I press the button once (the same exact way) but leave the shifter in gear it will turn the ignition off but keep the accessories on.
The four pins are probably mostly for the illumination purposes (the led has an orange and a green to indicate the button status).
Old 01-28-2014, 12:06 PM #9
Millerad1651's Avatar
Millerad1651 Millerad1651 is offline
Real Name: Adam
Millerad1651 is on a distinguished road
Real Name: Adam
I know there are some guys that have added them to 3rd gen with the chipped key, Zacattack is one, and there was a guy from Tacomaworld selling kits...not sure about 5th gen though. Gimme a few and I'll find the threads.
1998 SR5 4x4 Natural White
http://www.toyota-4runner.org/3rd-ge...read-gigi.html
Millerad1651 is offline   Reply With QuoteReply With Quote
Old 01-28-2014, 12:09 PM #10
Real Name: Nathan
Real Name: Nathan
Thanks man.....
Old 01-28-2014, 01:04 PM #11
zacattack20's Avatar
zacattack20 zacattack20 is offline
zacattack20 will become famous soon enough
Mine I added was an RFID ebay kit from china for $80. The button is just that, a button. You need some sort of controller/computer to tell it what to do. You could probably get the button and then like a cheap kit that I got and use them together. As for wiring, I have a '98 so I didn't have all the computers controlling the truck like newer trucks do. I don't have an immbobilzer but many people that do, like when installing a remote start, just tape a key around their ignition switch to bypass that.
'98 SR5 Converted to '01-'02 Sport Edition
Matte Blue Vinyl Wrap - Black Interior - Too Many Mods
Build Thread
Instagram: 98trd4r
zacattack20 is offline   Reply With QuoteReply With Quote
Old 01-28-2014, 01:20 PM #12
I guess you could just wire it to the starter wires of the ignition switch but then I don't think you are going to get an option to have just the power on with the engine off. You also need a way to disable to the wheel lock. So you either are still going to need your key everytime and get in ,turn to RUN and then push the button which is more work; or you cut off a key and leave it in the ignition turned to ACC and then cover the hole. That last option though isn't too safe against someone being able to break in and just push the button to start it.
Build Thread
Instagram: 98trd4r
Old 01-28-2014, 08:16 PM #13
Kmvreter's Avatar
Kmvreter Kmvreter is offline
Kmvreter will become famous soon enough Kmvreter will become famous soon enough
Kmvreter's Avatar
Originally Posted by zacattack20 View Post
... You also need a way to disable to the (steering) wheel lock...
I think this would be a major hurdle and why this is meant as a straight replacement for a current push start with the smart key system. You would have to retrofit the truck with a full smart key capability (or similar hack) to use this button.
____________
[__/[_[_\____\,_
L---L-L-L--0=*=0
`(o)_---(o)_--)_)`.........
Kmvreter is offline   Reply With QuoteReply With Quote
Old 01-29-2014, 12:33 AM #14
NuclearN8's Avatar
NuclearN8 NuclearN8 is offline
NuclearN8 is on a distinguished road
NuclearN8's Avatar
definitely more expensive http://www.digitalguarddawg.com/auto...ess-go-systems
but I had one of these RFID's for my harley back in the day (for security only) and loved it and they had great customer service back then...
Current: 17' GX460 Luxury with DSP, Nightfall Mica / Black
Sold: 05' 4R Sport v6, 07 4R Limited v6
NuclearN8 is offline   Reply With QuoteReply With Quote
Old 09-04-2017, 03:58 AM #15
anomalous's Avatar
anomalous anomalous is offline
anomalous will become famous soon enough anomalous will become famous soon enough
anomalous's Avatar
I know this is a super old thread, but I'll be wiring in my TRD Push Start Button in my 2017 4Runner SR5 real soon. I'll have it work the same way I had it in my Tacoma by still using the key for its transponder and to turn on ACC, and IGN. The button will light up amber on ACC, then green on IGN, and then push to crank and start. The TRD logo will also illuminate when parking lights are on. I'll still be able to use the key to turn on and start the car normally incase the button and/or relays fail.
TRD Push Button Start....can it be added?-imag1347-jpg
anomalous is offline   Reply With QuoteReply With Quote
RFID Keyless Entry, Push Button Start and Remote Start BFLAN 5th gen T4Rs 41 04-17-2012 09:36 PM
Adding push button start lmbbuilders 5th gen T4Rs 3 08-15-2011 01:50 PM
Those with push button start 4ShoreRunner 5th gen T4Rs 7 06-30-2011 03:44 PM
