03-18-2014, 08:36 AM
Can't post in my build thread??
Hopefully someone who can help will see this...
This has been going on for over a week. I've PM'd Admin twice and haven't heard back. I can start new threads (obviously) and post in other existing threads. However, even if I wait 2 days between tries, I get a message saying I need to wait 20 seconds between posts and to try again in 5 seconds when I attempt to post in my build thread. That's if I use the "quick reply" function. If I try to do a regular reply the page just goes blank when I click on submit. I've tried this from multiple computers.
Help? Thoughts?
'01 T4R SR5, 4x4, TRD Supercharged, OME 881/90004 fronts w/ 3/4" spacers & 890/60028 rears, ToyTec 1" BL, 255/75/17 BFG MTs, Tundra 13WLs, 1.25" Spidertrax WS, Savage Offroad Sliders, Andy Mod 2.0, Deckplate Mod, Magnaflow 18"
My Build
03-18-2014, 08:59 AM
Moderator
Real Name: Jonathan
Moderator
Real Name: Jonathan
I tried to do some moderator magic, hopefully it works for you.
I made a new build thread for you and merged your build thread into the thread that I made. I'm hoping that essentially it makes your thread a "new" thread that you can reply to. Give this a shot and see if you can relpy to it. If so then problem solved. If not then we either need to get admin involved or you may have to start a new build thread.
Here's the link:
http://www.toyota-4runner.org/3rd-ge...read-test.html
03-18-2014, 09:43 AM
That worked! I really appreciate it!
My Build
03-18-2014, 09:45 AM
Moderator
Real Name: Jonathan
Moderator
Real Name: Jonathan
No problem, glad it worked!
03-18-2014, 09:55 AM
Not working again after you changed the thread name back. Maybe try changing the name to "BenK's 4R Build" and leave it?
My Build
03-18-2014, 10:01 AM
Moderator
Real Name: Jonathan
Moderator
Real Name: Jonathan
DOH! Title changed.
03-18-2014, 10:08 AM
*!&%#@ Back to the same problems...
My Build
03-18-2014, 10:33 AM
Moderator
Real Name: Jonathan
Moderator
Real Name: Jonathan
I tried another merge. IF that doesn't work still then I would suggest you start a new build thread. It should be a few minutes of copy and paste so it shouldn't be too painful.
03-18-2014, 10:39 AM
Thanks for the help. Still no luck. New build thread it is... Feel free to delete this...
My Build
