Originally Posted by jrdo410
If that's the case, then why would the gas cap trick work?
verify all the vacuum lines are installed in the correct locations.
ive seen this happen before, but it was on a carb'd rig. improper tank venting was causing a vacuum in the tank, which the fuel pump wasn't able to overcome , it would end up starving the engine for fuel.
popping the cap off would fix it temporarily.
you could try just driving around with the cap loose, I suspect you wouldnt have that issue anymore. altho, that may lead to other CELS, but it would at least let you know you have a venting problem.
1985 pickup
: EFI 331/4r70W-Dana 300-42 TSL SXII's/raceline beadlocks-30spl longs-5.29's-spools-sky Hi steer-OBA/4g tank-10.5k RR winch-dual blue tops-200 amp alt-flatbed.
1985 4runner sr5
: 22RE/5spd-6" pro-comp suspension-37 BFG at's-5.29 gears-Badlands Basher bumper-8.5k RR winch.
2006 4runner v8 limited
: stock.
Build Thread YouTube Channel
