04-01-2014, 01:22 PM
Running oversized spare for 500mi OK or dangerous?
A snow tire 30.5" (left rear) completely exploded itself and I put on the spare 31.6" summer. (After wear, probably 30.4 vs 31.4 so 3.1%-3.5% difference)
The replacement snow is coming. The tires are new enough that the tire dealer said I didn't need to replace all 4. But the tire dealer freaked out about me driving 3 30.5" and 1 31.6". I've already driven 250mi in AWD with zero issue in this configuration.
Is it safe WITH RESPECT TO BRAKES/DRIVE TRAIN DAMAGE (I understand traction differences) to drive another 250mi until the replacement snow comes in? Or do I have to take off the 3 remaining snows, put on my summers, and then switch them all back again?
07 T4R SE V6 4WD - GYSA 265-70-17 LT C / Blizzak DM-V1 245/70/17 - Yakima Holdup + Skybox Lo Carbonite - Weathertec Liners
15 T4R SR5P V6 4WD - Blizzak DM-V2 245/70/17 - Thule Force XL
04-01-2014, 02:27 PM
It's probably not the best idea to be doing this with AWD because one wheel will be turn faster than the other three and it might screw with the center differential (overworking it). However, while there is most likely no immediate damage, it would be best to stop driving like that for now until you can get a matched set of tires on there.
Just for future reference, if you plan to run smaller tires seasonally, maybe it would be best to get a 5th spare for each set of tires so you don't get caught in this type or predicament again
04-01-2014, 02:31 PM
you can run a little less air in the taller tire, to help bring the rolling diameter down closer to the others.
what environment are you driving in it? is the ground covered with snow/ice?
if yes, then it should be fine, much better than if dry pavement.
1985 pickup : EFI 331/4r70W-Dana 300-42 TSL SXII's/raceline beadlocks-30spl longs-5.29's-spools-sky Hi steer-OBA/4g tank-10.5k RR winch-dual blue tops-200 amp alt-flatbed.
1985 4runner sr5 : 22RE/5spd-6" pro-comp suspension-37 BFG at's-5.29 gears-Badlands Basher bumper-8.5k RR winch.
2006 4runner v8 limited : stock. Build Thread YouTube Channel
04-01-2014, 02:41 PM
mix of snow and ice and pavement
04-01-2014, 02:59 PM
Real Name: Leonard
Real Name: Leonard
Just put it on the rear and drop some air pressure, but not to much to create sway.
Having fun's build
04-01-2014, 04:22 PM
Moderator
Real Name: The Chosen One
Moderator
^^ what he said
'89 4Runner SR5 - stock
04-01-2014, 04:28 PM
Did that worked well so far
04-01-2014, 04:40 PM
Real Name: Leonard
Real Name: Leonard
I haven't had to do this. I have off road tires and street tires also, but keep a spare for both, different sizes also.
The comment is just common sense to do, as different size tires on the front can pull differently and make the abs,vsc work strange.
Having fun's build
04-01-2014, 05:02 PM
Real Name: Kevin
Real Name: Kevin
Am I the first guy that's going to say this is a bad idea? I don't know anything about the AWD or what damage might be done there, but having two tires with vastly different traction abilities on the same axle is a bad bad bad idea. Having different tires on a drive axle is worse. Especially on ice. You should at least have the tire shop mount up one more summer tire, and put them both on the rear axle.
Do you really need dedicated winter tires this late? I'd probably just slap the summer tires on and forget it. You do have 4wd, after all.
'My needle always settles between west and southwest. The future lies that way to me, and the earth seems more unexhausted and richer on that side.' - Thoreau, sort of.
The Grey Bastard, 1985 4Runner, driveway ornament.
Utah DesertRunners T4R, for all things wheeling and 4Runner in Utah.
04-01-2014, 11:41 PM
That would be worse because the difference from front to rear would be greater and therefore overheat the tcase
Op the biggest issue is you could severely over heat your tcase
1997 sr5 Mall crawler 3.4l 174,000
1993 sr5 3.sloooow 5 speed ome 2" rear coils slightly cranked torsion bars
