Originally Posted by zacattack20
Yes if you want to adjust the time, but if you are going to hook up the tach wire then that won't be neccesary. I personally think it would be easier to get to the tach wire I mentioned, the black wire at the disgnostic port in the engine bay. It's also where I've seen multiple aftermarket alarm wiring diagrams recommend to connect there. It just seems more work to remove things on the passenger side to get to the ecm.
Zac, thanks a lot for your help.
I'm trying to find the diagnostic wire you're talking about. Is it like the other end of the ODBII? Where exactly is it plugged in, and should I just cut the harness tape opena nd find the black wire, and solder my brain-unit violet wire to it?
