12-30-2014, 10:37 PM
I have an electrical problem
I have a 95 4runner sr5 when you are using a lot of voltage such as turning the turn signals on, head lights on or rolling the windows up it will shut the stereo off and some times kills the motor. What do you all think it could be???????????? Thanks
12-30-2014, 11:04 PM
Moderator
Real Name: The Chosen One
Moderator
Bad alternator, battery, or both (one can lead to the other).
'89 4Runner SR5 - stock
12-30-2014, 11:05 PM
I'm no expert but if it happened to me I would be testing the alternator or the battery. I know auto zone will test both of those for free.
GL.
2008 Limited V6 2WD
LED interior lights, HID's, Plastidip'd emblems, Fire extinguisher, HCF delete, 25% tint.
12-31-2014, 11:19 PM
'95 4runner SR5
New battery Alt. tested good, holds good volts on volt meter in the ins. cluster (14-16 volts).Back to the problem, in general day time driving the radio will cut off and come rite back on. Sometimes no problem occurs. I have checked grounds in places I know of. do u know of any other trouble shooting areas?
12-31-2014, 11:51 PM
Moderator
Moderator
The dash voltmeter is not particularly accurate.
When the radio goes out does the meter go down? Does the engine hesitate?
Moderator
Moderator
01-01-2015, 12:03 AM
it does go down very little
01-01-2015, 12:06 AM
the only time the motor stales is when u use head lights and that is seldom now that I replaced the coil
01-01-2015, 11:07 AM
Could it be an intermittent ground problem? Like maybe the ground is loose or corroded?
01-01-2015, 12:04 PM
Real Name: Dave
Real Name: Dave
If you haven't cleaned the battery connections and posts, I would start there. then check the condition of the battery cables and the other ends of the cables, in particular the ground to the frame and engine. Since the problems seem to be so widespread I think you will find it on one of the larger cables direct from the battery.
2017 Blizzard Pearl Limited
Redwood guts
Gone but not forgotten:
2015 Attitude Black 4Runner Trail
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
