Old 01-13-2015, 08:57 PM #1
PROFILER's Avatar
PROFILER PROFILER is offline
PROFILER is on a distinguished road
PROFILER's Avatar
Come along recommendation
Looking for a come along recommendation if anyone has had prior use with success. I do a bunch of back country roads for kayak fishing, mtn biking, and xc skiing and don't expect to get stuck but would like to be prepared just in case. Figured a come along would be a valuable tool w/chains just in case. Not sure I'd get enough use out of a winch.
PROFILER is offline   Reply With QuoteReply With Quote
Old 01-13-2015, 10:07 PM #2
Jeff614's Avatar
Jeff614 Jeff614 is offline
Real Name: Jeff
Jeff614 is on a distinguished road
Jeff614's Avatar
Real Name: Jeff
Usually can get them at Tractor Supply. No offense meant but have you tried one to recover a vehicle? I had one years ago and tried to unstick my Jeep with it. It did move it some but the wire rope isn't long and by the time I got it re-rigged I sank back to where I was.
Even a Hi-Lift might be better than a come-along as a last ditch recovery effort.
There's lots of cheap winches out there and while it doesn't seem our hitches our super strong, a cheap easy setup would be one of the better Chinese winches on a receiver mount.
- Jeff
2014 Mag. Gray Trail Edition, SouthernSS Slimline Front Bumper w/ ENGO e9000 and flush mount LED bar, Toytec /Bilstein 5100 Coilovers, Rear Bilstein 5100's, Rear SAW coil's, 265 Nitto G2's on FN Six Shooters, Husky Liners, TRD exhaust tip, Midland 75-822 w/Wilson 5000 mag. mount, AVS low-profile ventvisors, Lamin-X fog covers
Jeff614 is offline   Reply With QuoteReply With Quote
Old 01-13-2015, 10:12 PM #3
junkyardbiker junkyardbiker is offline
Real Name: Danny
junkyardbiker is on a distinguished road
Real Name: Danny
Get a Hilift jack, or the smittybuilt one. Serves well as a winch in a pinch hahaha as well as a great jack for getting your truck unstuck. I have one and love it, had it less than a month and it has already gotten me out of a bad hole in a river bottom. Just read around online, don't be afraid of the bad rap these farm jacks get. If you are careful and pay attention to what you are doing with planning and preparation a farm jack will be the most useful and versatile tool you can carry. Sadly most come-a-longs do not have the power to actually pull a vehicle out. Just about any one you find will have a stamped frame and will crumple or buckle under load and do real damage or leave you stranded. If you do go for one, get one with a cast frame by either Lug-all or Power puller. And you will still want a Hi-lift after you see all they can do.....
junkyardbiker is offline   Reply With QuoteReply With Quote
Old 01-13-2015, 11:01 PM #4
Fern's Avatar
Fern Fern is offline
Fern will become famous soon enough Fern will become famous soon enough
Fern's Avatar
I just picked up a 4 ton Haulmaster from HF for $30.
Fern is offline   Reply With QuoteReply With Quote
Old 01-13-2015, 11:08 PM #5
Fern's Avatar
Fern's Avatar
...and a snatchblock for $25.00.
Old 01-14-2015, 12:11 AM #6
Titanpat57's Avatar
Titanpat57 Titanpat57 is offline
Real Name: Patrick
Titanpat57 is a jewel in the rough Titanpat57 is a jewel in the rough Titanpat57 is a jewel in the rough
Titanpat57's Avatar
Real Name: Patrick
I would only reccomend a nonwinch recovery with a Hi Lift.....ive never seen a come along used, especially an imported one. Look up the right way on youtube.
White 2016 TEP .....My ROAM Truck Build....... My ROAM trailer Build
Titanpat57 is offline   Reply With QuoteReply With Quote
Old 01-14-2015, 12:54 AM #7
csp csp is offline
csp is on a distinguished road
csp csp is offline
If you're going that route get a good one with a length that doesn't make you re-set up every 5-6 feet. Yes, they are quite a bit more expensive than the cheapo 2 ton units that you can find anywhere.
American Power Pull 15002 Cable Puller, 3-Ton: Pulley Hoists: Amazon.com: Home Improvement
csp is offline   Reply With QuoteReply With Quote
Old 01-14-2015, 01:00 AM #8
UnderFire's Avatar
UnderFire UnderFire is offline
UnderFire has a spectacular aura about UnderFire has a spectacular aura about UnderFire has a spectacular aura about
UnderFire's Avatar
If you're going to use a comealong, make sure its one that uses a chain instead of a wire rope, they last forever, the wire style ones don't work right after a couple uses in my experience.
'97 3RZ 5 Speed "FrankenRunner" (Build Thread) - Dormant
The "shitmobile" 500$ 3RZ Auto 4Runner - (Saved from the Scrapyard: Resurrecting a 500$ 3rd Gen
02 Tacoma Double Cab, mid-travel, locked, armored, supercharged and riced. (Longbed and 5 speed in the works)
UnderFire is offline   Reply With QuoteReply With Quote
Old 01-14-2015, 07:44 AM #9
PROFILER's Avatar
PROFILER's Avatar
Thanks for the info. I'll look into some cheap winches and or the HI-lift. I've never personally used a come along myself and hope to not have too in the future. I'm not planning on doing serious off roading that will push the limits but when out in the woods you never know until its too late.
Old 01-15-2015, 01:49 AM #10
wfo9's Avatar
wfo9 wfo9 is offline
wfo9 has a spectacular aura about wfo9 has a spectacular aura about
wfo9's Avatar
This is what you want. Not the Chinese knock off linked to above.
https://www.wyeth-scott.com/models.asp
Get the one with the synthetic rope. It is the real deal.
Model:3-35-A-SLT
I have one, and really like it. You will need more recovery gear to go along with it. Some straps, an Extension, tree saver, D-Shackles, extra snatch block, shovel. Then some practice before you actually need it. Recovery is serious business and you really need to be careful and have a good plan and working knowledge of your equipment. I'm usually too concerned with wheeling and don't test my equipment enough. Then I'm rusty when I need it. You just motivated me to go do a mock recovery before I go out again LOL Actually, I usually never wheel alone, so the tow strap is the go to device.
BTW, winching with a hi-lift is a total PITA. Horrible solution IMHO. Would only use it as a last resort.
wfo9 is offline   Reply With QuoteReply With Quote
Old 01-15-2015, 04:32 AM #11
lovhanyou lovhanyou is offline
lovhanyou is on a distinguished road
lovhanyou is offline   Reply With QuoteReply With Quote
Old 01-15-2015, 11:56 AM #12
gm350reratliff's Avatar
gm350reratliff gm350reratliff is offline
gm350reratliff has a spectacular aura about gm350reratliff has a spectacular aura about
I have a light duty come along that I use around the house/shop (doubt it could do anything for a stuck vehicle) and a very heavy duty one that I got from my dad (it's probably older than me and weighs almost as much). I've used the heavy duty one to free one of my Z71's once. It did the job, took forever though, and I was so friggin' tired from cranking and re-rigging that I literally passed out when I got home (I actually got stuck a number of times trying to get through a remote area). At the time I had no choice but to use it as it was just me and my wife. No cel phone service for miles and just above zero temps. If you plan on needing to use one, take some extra water and food (my mistake, I go prepared now).
Shortly after that trip, I finally installed a winch in that truck.
2014 Super White Trail Premium My build thread: http://www.toyota-4runner.org/5th-ge...ld-thread.html
2008 SR5 4X4 V6 Better late than never build thread: http://www.toyota-4runner.org/4th-ge...ld-thread.html
gm350reratliff is offline   Reply With QuoteReply With Quote
Old 01-15-2015, 12:12 PM #13
KidVermicious's Avatar
KidVermicious KidVermicious is offline
Real Name: Kevin
KidVermicious has a spectacular aura about KidVermicious has a spectacular aura about
Real Name: Kevin
For the size and weight of a comealong strong enough to winch a properly stuck vehicle, just get a Hilift and learn how to winch with it. It's only a little bigger and heavier than a comealong, and a thousand times more versatile.
The hilift is big, and heavy, and can be a PITA to use, and I don't go anywhere without mine.
'My needle always settles between west and southwest. The future lies that way to me, and the earth seems more unexhausted and richer on that side.' - Thoreau, sort of.
The Grey Bastard, 1985 4Runner, driveway ornament.
Utah DesertRunners T4R, for all things wheeling and 4Runner in Utah.
KidVermicious is offline   Reply With QuoteReply With Quote
Old 01-16-2015, 12:43 AM #14
wfo9's Avatar
wfo9's Avatar
I disagree, a hi-lift is not a PITA to use, it is near impossible to use in a real world winching situation and requires a crap load of bulky chain to move anything more than a few feet. A good come along like the power puller can move you up to 30' without re-rigging. It will last for a lifetime... I find it extremely useful and versatile for all kinds of stuff. It can do things a mounted winch just can't do in tight situations. I still carry a hi-lift, but don't use it for winching. I have tried a few times and finally said never again.
Old 01-16-2015, 08:31 AM #15
Real Name: Kevin
Real Name: Kevin
It's not impossible at all. I've done it, it works, you don't need chain.
Obviously it's not easy, and any truck that risks needing to winch on a regular basis needs to invest in a proper winch. But the OP isn't going to be winching on a regular basis. He wants to carry something just in case, and the Hilift's versatility across multiple situations beats out a hand winch every day of the week.
Oil recommendation? JeffMerr 4th Gen T4Rs 46 06-06-2018 10:05 AM
DMM recommendation? SUBTEGRAL Engines / Suspension / Wheels / Tires / Audio / Accessories 4 04-21-2012 06:55 PM
Recommendation on oil changes. RJS-T4R 5th gen T4Rs 184 03-26-2012 10:32 AM
Need tire recommendation 265/65 17 nauticalniremor Engines / Suspension / Wheels / Tires / Audio / Accessories 1 09-08-2011 01:26 PM
Tire recommendation? atalarico 3rd gen T4Rs 11 09-05-2011 11:43 PM
