Old 04-01-2015, 06:02 PM #1
FMann FMann is offline
FMann is on a distinguished road
2015 Limited Shock Issue Question
New guy here with a 2015 Limited 4x4. Read on this forum about a leveling-lift kit. Asked my local 4WD shop and also called Daystar, everyone recommended the kit. Well, it turns out it seems to have the XREAS system.....
Car has 800 miles on it and before knowing what I was doing I began to remove the line from the first shock....bad idea. So, i let some fluid out of the front left shock and decided against it....again, bad idea.
I called Toyota and they said it's very expensive to service the system without just replacing all the shocks.
Am I doomed to have to do this replacement? Can the system be serviced? If it can, it doesn't seem like I can install the lift because the hydraulic line limits the ability to move the shock...
I probably have too many questions for answers, but any advise would be great.
Thanks for the time.
FMann is offline   Reply With QuoteReply With Quote
Old 04-02-2015, 12:12 PM #2
DCook0 DCook0 is offline
DCook0 is on a distinguished road
I think your best bet price wise is to pick up some 5100s. You can use the stock springs on those ( from what I've read).
That's what I plan to do for a basic lift. (With some rear lift springs, diff/sway bar drop.
What ever you plan to do. I wish you the best of luck!
2015 Limited 4x4 Black, BFG KO2 275/70r17, Bilstein 5100s, OME Springs (3 inch), Spidertraxx Spacers, Budbuilt Bump Out Sliders, Front swaybar drop, LED headlights, interior lights, reverse light.
DCook0 is offline   Reply With QuoteReply With Quote
Old 04-03-2015, 07:52 AM #3
philsey's Avatar
philsey philsey is offline
Real Name: Um, Phil?
philsey has a spectacular aura about philsey has a spectacular aura about
philsey's Avatar
You need to repost this over in the 5th Gen forum...
2010 Blizzard Pearl SR5/P - traded
2018 Superwhite SR5/P ... IS350 retrofit.
philsey is offline   Reply With QuoteReply With Quote
Old 04-03-2015, 08:52 AM #4
Ezlife45 Ezlife45 is offline
Ezlife45 will become famous soon enough
There is a right way and a wrong way to work on the suspension. Being uninformed, you picked the wrong way. Not sure what the fix is but as suggested, posting on the 5th gen forum someone may be able to help you out.
Ezlife45 is offline   Reply With QuoteReply With Quote
Weird electrical issue on 2015 Trail Ezekiel2222 5th gen T4Rs 116 02-09-2023 02:56 PM
Question: Exhaust Tip 2015 4Runner Limited Buffaloe 5th gen T4Rs 8 04-11-2015 07:41 AM
2015 DRL issue T4R_S2k 5th gen T4Rs 8 03-20-2015 07:10 PM
2015 Trail / Frame paint issue? Sphonaut 5th gen T4Rs 13 02-18-2015 11:59 AM
2015 4Runner Issue givealoha 5th gen T4Rs 6 12-01-2014 12:33 AM
