Old 05-20-2015, 09:11 PM #1
Enduro414 Enduro414 is offline
Real Name: Chris
Enduro414 is on a distinguished road
Real Name: Chris
Gobi Ladder Installation/Fitment Question
I was wondering if anyone could give any pointers on how to get the ladder to fit correctly. When the hangar plate is seated flush, the ladder is not level as well as not sitting completely flush with the bottom of the tail gate. I can adjust the ladder to get most of the lower mount flush, but the hangar plate slides forward and comes in contact with the body of the vehicle (already scraped a bit of paint when I opened the hatch not knowing it moved forward [doh]).
The hangar plate was already replaced by Gobi due to one of the screws being welded at a slight angle, which didn't allow the ladder to mount to the plate.
I am usually mechanically savvy, but this ladder has me thrown for a bit of a loop. -_-". Any advice/help will be greatly appreciated.
Cheers,
Chris
2018 Ram 1500 EcoDiesel
2009 4Runner Trail Edition (Shadow Mica)
2007 Honda XR650R Stock- Project Bike
2002 Honda CR250R Not so stock
Enduro414 is offline   Reply With QuoteReply With Quote
Old 05-23-2015, 09:22 AM #2
gaterose's Avatar
gaterose gaterose is offline
Real Name: Matt
gaterose will become famous soon enough gaterose will become famous soon enough
gaterose's Avatar
Real Name: Matt
Not sure if this helps, but you have to mount the top of the ladder then have someone put weight on it to make it bend slightly and pull down to the lower mount.
2017 Tacoma TRD OR - His
2014 4Runner Limited - Hers
'13 Silverado Z71 - Sold
'03 4Runner UnLimited - Sold
gaterose is offline   Reply With QuoteReply With Quote
Old 06-01-2015, 09:25 PM #3
RedStripeRanger's Avatar
RedStripeRanger RedStripeRanger is offline
Real Name: Reed
RedStripeRanger is on a distinguished road
Real Name: Reed
Should I be worried?
Put my ladder up yesterday, everything was flush, level (beides on step that isnt exactly square).
Went out this evening and the top of the ladder didnt look level anymore. Climbed up and found the bracket on the ride side has shifted up and now the ladder isnt sitting flat on the top.
Is this going to cause any issues? Anyone else experience this?
Gobi Ladder Installation/Fitment Question-gobi-ladder-1-jpg  Gobi Ladder Installation/Fitment Question-gobi-ladder-2-jpg  Gobi Ladder Installation/Fitment Question-gobi-ladder-3-jpg
2014 TEP Magnetic Grey with KDSS // GooseGear Icebox and Drawers // Icon Stage-2 // Black Rock Type D Wheels // Toyo Open Country ATII LT285/70R17 // Gobi // Rigid Lights // Canvasback Max4 Camo // Rotopax // Maxtrax
RedStripeRanger is offline   Reply With QuoteReply With Quote
Old 06-02-2015, 12:29 PM #4
Nyc-Runner's Avatar
Nyc-Runner Nyc-Runner is offline
Nyc-Runner is on a distinguished road
Nyc-Runner's Avatar
I did mine exactly as @gaterose said, mounted the top and then put some weight on it and pulled it down so the bottom would sit flush and secured the bottom.It probably would have helped if i had a extra hand when putting weight on it and pulling it down to keep the pressure on it while i secured the bottom. Other than everything went on and worked out fine,i've used it numerous times with no issues..
[/SIZE]08 Urban Runner Dipped-Satoshi Grill,Icons,M LT,BAMF,RCI,Addicted Off Road Front bumper,4x4 Labs rear bumper,Warn M8000 w Spydura synth,FN Five Stars with 34" Goodyear kevlar Mtr's,4:56 Re gear with Rear FJ Elocker,Flow Master,Afe,and much much more..........
My Build >http://www.toyota-4runner.org/4th-ge...ld-thread.html
Nyc-Runner is offline   Reply With QuoteReply With Quote
Old 06-03-2015, 02:29 AM #5
gaterose's Avatar
Real Name: Matt
gaterose's Avatar
Real Name: Matt
lol same here-- I laid down on the ground and kinda did a pull up on mine while I attached the bolts.
Old 06-03-2015, 10:12 AM #6
Real Name: Reed
Real Name: Reed
I did the same but then that happened. I have no Idea why, you can see the white adhesive was over the edge and lined up right. Im going to email Gobi to figure if its an issue or not.
Old 06-04-2015, 11:00 PM #7
gaterose's Avatar
Real Name: Matt
gaterose's Avatar
Real Name: Matt
Sorry I somehow missed your post when I replied. It looks fine to me, but might be better to get some input in the 5th gen section.
As long as it feels sturdy and doesn't contact the paint anywhere it shouldn't, you should be fine. I believe mine shifted slightly after installing it so that the adhesive is showing too.
Old 06-05-2015, 05:08 AM #8
ergizheng ergizheng is offline
ergizheng is on a distinguished road
ergizheng is offline   Reply With QuoteReply With Quote
Old 06-05-2015, 09:10 AM #9
Real Name: Reed
Real Name: Reed
No worries, and yeah its solid no rubbing I can tell of, just moved after the install. Thanks for the help
Old 06-08-2015, 09:22 PM #10
Real Name: Chris
Real Name: Chris
Thanks for the reply guys. I will hopefully be getting it on soon, now that school is finally over for the semester.
WTB Gobi Ladder ThePMFG Want to Buy/Trade 1 07-25-2019 07:41 PM
Gobi Ladder Installation: Quick Question Engineer 5th gen T4Rs 13 05-21-2015 08:23 PM
Gobi Ladder Question to Those Who Have It jnance50 5th gen T4Rs 12 01-31-2015 10:32 AM
Gobi ladder hrjaw Want to Buy/Trade 0 07-20-2013 11:50 AM
Gobi Ladder calcrc 5th gen T4Rs 3 02-21-2013 12:16 PM
