08-08-2015, 10:44 AM
#16
Originally Posted by mario4r
When to install new tires I had ordered a lift a couple days before I told the tire guy if they could put the spacers since they were going to mount the new tires.. He said they cant do it because spacers are dangerous a wheel could fall out or it could vibrate or affect the truck in the long run..
Is this true??
How long before you check on your spacers to see if they are well bolted on??
Sorry im new to spacers..
I think there is some confusion out there among those that don't really know the difference between wheel spacers and wheel adapters.
A wheel spacer is generally a smaller, universal single piece of steel/aluminum, designed to work on a variety of cars and to give minimum spacing, usually less than 1/2". They fit directly onto the studs, and are sandwiched by the wheel and the hub. Wheel adapters are usually heavier, and thicker pieces that are machined, are designed for specific applications, and generally have their own studs. The adapters bolt to the stock studs, then the wheel is bolted to the studs on the adapter. Adapters are usually used to provide spacing greater than 1/2" (I've seen adapters that are 2+ inches thick), and they can also be used to alter a bolt pattern.
I have had Spidertraxx for years and have never had a problem with. When you hear people complain about "spacers" and the existing OEM lug nuts coming loose its because almost half of the OEM studs are made unusable due to the fact that the spacer is now filling up that threaded space. The adapters like Spidertraxx bolt onto the existing OEM studs but they also have their own studs which the rim then bolts onto giving you the full length of threading on the stud to tighten down the rim and lug nuts.
What I like about Spidertraxx is they are made vehicle specific.
2004 Limited V8 w/ Factory Nav- OME Front Heavy Coils, OME Rear Medium Coils [] ProComp ES9000 shocks all around [] Shrockworks Single Hoop Bumper w/ PIAA Super White Driving Fog Lights [] Shrockworks Sliders [] KC 4" x 6" Gravity LED Driving Light [] Clazzio Black Seat Covers - Front and Rear [] Spidertrax 1.25" spacers [] Pro Comp MT2 285x70x17 [] 2006 Headlight Mod [] Satoshi Grille [] Black Canvas Back Canvas Jackets [] Black Husky Liners Front and Back [] Gobi Stealth Rack & Ladder
08-08-2015, 11:31 AM
#17
Running SpiderTrax on the FJC for several years and about 40k miles, running G2 on the 4R for 4 months and 5k miles. Both brands are high-quality hub-centric spacers. I regularly check the torque on both vehicles, all are torqued to recommended specifications, and I use Red Loctite.
Nearly bone-stock 2015 TRDP<paid under sticker!, TRD Supercharger, Helo 904 17x9 rims, 285/70-17 BFG KO2, BMC, MetalTech OPOR Sliders w/extension, Hella Aux Fogs, Ultragauge, Rockford Fosgate Speakers, FJC Sub Woof Box, Kicker Woof, Cheapo Boss Woof Amp, Aux Glovebox Outlet, etsy TRD hub covers, Shaved/trimmed Mud Flaps and Fenders, Cobra WX75 CB, Rear Storage Drawers, Shovel Mount, Radar, FZ-1 Fuzeblock, AVS LP Visors, Window Tint, Painted Roof Rack, Low Profile SiriusXM Antenna, Dash Cam, Exhaust Tip, Accessory Meter Mod, Some Stickers. 2008 FJ Cruiser, FJNE Member DMAND.
08-08-2015, 11:45 AM
#18
We have everyone in our group running spidertrax spacers. One has had them for 7 years and he wheels pretty often. Nothing wrong with them. Just retighten the spacers every so often and you're good to go.
08-08-2015, 07:20 PM
#19
Originally Posted by TRD Pro
Other than the slight tire rubbing they cause, my Spidertrax spacers have been trouble free for the last 8000 miles since I installed them. Here is an interesting write up I found from a guy on a Jeep forum.
"I recently installed a set of 1.5" Spidertrax spacers. However, prior to doing so, I took one of them, along with my spare wheel, into our engineering lab.
We modeled both in 3D using the latest NX CAD software. We did this by reverse engineering. That means taking all dimensions and determining the materials.
We identified the wheel material as alloy 356-T6. The spacers are made from 6061-T6 alloy. 356-T6 has tensile strength of 30,000 PSI. 6061-T6 has a tensile strength of 45,000 PSI. This means that in reference to the basic materials, the spacer is 50% stronger than the wheel for a given thickness, and the spacer is much thicker in section.
We ran an extremely complex finite element analysis of both to determine where peak stresses are and where each component is most likely to fail. The result is what I expected. In short, spacers are not the weak link. The wheel itself is 2x more likely to fail under severe loading than the well designed spacer.
Now, let me qualify our findings. Our corporate engineering team has designed significant portions of the Airbus A350 landing gear system. We engineered the latest landing gear system for the Boeing CH-47. Our hardware is on the F-35, F/A-18, F-16 and a number of other aircraft.
This same engineering team has analyzed the Spirdertrax spacers and concluded that they are extremely strong, stronger than they need to be. Over engineered. These spacers are utterly safe if installed properly. Like an offset wheel, they may accelerate bearing wear, but the offset is so little as to be of no great significance.
I installed the spacers very carefully. Not knowing specifically what brand and type of threadlocker compound was provided with the spacers, I tossed it and used Loctite 271 Red. Each spacer was torqued to recommended specs in a star pattern. The wheel was then installed and torqued to 95 lb/ft.
After about 150 miles, I pulled off the rear wheels and checked the spacer lug nut torque. No change... I'll re-check torque at each tire rotation.
Installed correctly, Spidertrax wheel spacers are not only safe, they're stronger than the wheels you bolt to them."
I didn't mention that we found areas of stress concentration in the factory wheels. We were able to pinpoint the most likely location of failure. I'll explain where that is...
The Factory Moabs have spotfaces milled into the wheel hub to provide clearance for assembly washers used during manufacture to secure the brake rotors on the hub prior to final assembly. Using an endmill, each lug hole is spotfaced on the inside (think of a spotface as a shallow counterbore). The edges and corners of these spotfaces are quite sharp. This is where the FEA predicted the greatest concentration of stress. Unfortunately, this is also adjacent to the where the studs transmit all rotational torque into the wheel. The failure to radius edges and corners is what leads to stress concentration. If your Moab is going to fail at the hub, it will crack at a spotface.
In short, Tom and Eddie at Spidertrax have designed and engineered a very high quality spacer, that if properly installed, will provide you with many years of problem free and safe use.
/thread
08-08-2015, 07:27 PM
#20
I think a lot of the fear of spacers comes from one or two horror stories that have made their way around every off-road forum. I believe the one I read the guy had them installed incorrectly. When you think about it, there are thousands and thousands of spacers installed on trucks all over the U.S. and there are very few stories of them failing. Good spacers aren't expensive so I really don't understand why people go cheap and order off eBay when it's something that important.
2009 Trail Edition
2006 Sport Edition - SOLD
08-08-2015, 07:29 PM
#21
Did they only model the spacer and wheel or did they run an analysis on the complete OEM hub and bearing assembly? There have got to be some increased moments around that area. I'm just curious.
2007 V8 Sport Edition: Definitely Not Stock
2014 LX 570: Stock
08-08-2015, 07:38 PM
#22
Yep. The one part (4 technically) you don't want to f'k with on a vehicle is the part that your life depends on which are the wheels.
08-08-2015, 07:54 PM
#23
I wanted to purchase some spidertrax wheel spacers not too long ago, but after all the surgery that needs to be done to prevent rubbing (cutting the fender liner, removing mud guards). I decided to wait it out and purchase wheels with the proper offset and tires.
2015 Toyota 4Runner TRD-PRO Attitude Black
CORNFED 2.25(F) 2.00(R) SPACER LIFT KIT/285-70-17 FALKEN WILD PEAK TIRES/1.25 SPIDERTRAX WHEEL SPACERS/TRD INTAKE/SSO ROCK SLIDERS/DIGITAL-FIT WEATHERTECH MATS/K&N AIR FILTER/TRD OIL CAP/WEATHERTECH WINDOW VISORS/BUSHWACKER FENDER FLARES/FULL INTERIOR LED LIGHTS/AVS AEROSKIN/3’ URD MARK3 CATBACK EXHAUST/PRINSU FULL ROOF RACK/BAJA RACK LADDER
08-08-2015, 08:05 PM
#24
Agree....yet the general problem is that there aren't a ton of options for 17" wheels which meet this criteria.
Has anybody done the math on a 2015 TEP wheel with 1.25" Spidertrax to determine the "effective" offset/backspace?
That might be the golden goose of this thread....as that's generally "the look" most are trying to achieve.
08-09-2015, 11:02 AM
#25
Be careful in replying on the jeep guys analysis.
What's important to remember is that the fasteners are only there to provide clamping force. Not resist rotation. And wheel failure from adding spacers is generally am issue of friction failure and wheel spinning against the hub. So the real issues are whether the spacer material has a lower coefficient of friction against either they wms or the wheel, whether the spacer is compressible under the force of the fastener, and whether adequate thread interface remains. All of these depend on the starting point and the spacer thickness and material.
For example aluminum spacer between steel wheel and wms likely makes it marginally safer. But steel spacer between aluminum wheel and steel wms is less safe. Anodized spacer is less safe than raw aluminum. And many other variables.
The FEM analysis seems misplaced to me. I don't think they really understand how fasteners work if they are looking at static failure. I wouldn't put much value in that analysis. In fact id put it in the category of engineering nonsense. Is analysis of the wrong problem and does nothing to indicate whether spacers are safe or not. That's simply not how they fail. Please don't rely on that for much. It's not wrong per se. It's simply not useful.
For me, I would buy a proper wheel for what I want. Unless there's a very small - 1/4 inch space needed for something like clearing a caliper or a remote resirvoir can then I might use a spacer. At some point your really stressing the hub, ball joints, and wheel bearings to much for long service life. On my trail rig with 12" wide wheels and 2" back spacing I know I'm dramatically shortening the life of the bearings but it's not a daily driver so I don't all that much care. And it weighs 3000lbs on big axles. On my 4 runner I wouldn't want to push the bearings that hard. They aren't very big compared to something like a land cruiser. And I've had a few failures on my last mini truck that used similar size bearings.
So I would suggest keep em small. Keep them uncoated. And check your torque a few times after installing.
08-09-2015, 12:48 PM
#26
Moderator
Real Name: Greg
Moderator
Real Name: Greg
Exactly.
08-09-2015, 12:50 PM
#27
Due to pure laziness, I've never taken off my spidertrax and cleaned the threads or whatever. Loctited them once 90k miles ago, have never had a problem with them.
Andrew
2010 Battleship Grey SR5 4x4
Sweet mod list.
08-09-2015, 01:40 PM
#28
It seemed to me that the FEM analysis simply assumed a set of properly installed SpiderTraxx and tested them accordingly. Theoretically if they were installed correctly then the SpiderTraxx should not rotate at all and be a solid component of the hub and wheel; so load forces and stresses should translate into the wheel. Granted I imagine they didn't bother to mention shearing forces on the studs because the studs were equal to or greater than OEM units and thus would have similar failure points at a shearing level.
Now it would have been interesting to see some testing with loose, slightly loose, or improperly installed units to get an idea of how they fail.
08-09-2015, 02:28 PM
#29
Moderator
Real Name: Greg
Moderator
Real Name: Greg
Pulling from a long time of design experience, the biggest cause of failure on a component such as this is not the actual component itself but the "human" factor of installation and maintenance.
Untrained people mess stuff up. Read some of the build threads here. Would you want to buy a vehicle modded by them?
If I were in the used 4Runner buyer's market and I came across a modded (suspension, spacers, tires, wheels, bumper, skid, etc) one I liked my first question would be "Who did the work?" If it turned out to be the owner then I would automatically deduct the time it will take me to take all his "mods" apart, fix what he F'd up, (again, read some of the build threads) and reinstall things properly.
There is a reason why people like Icon and AEV are in business and there is a reason why individually modded vehicles get no extra money for those mods when it is traded or sold.
Bottom line: If quality spacers are used and install and maintenance instructions are followed to the letter then they are safe. Otherwise I wouldn't take it out of my driveway.
08-09-2015, 02:34 PM
#30
Real Name: Sparky
Real Name: Sparky
Originally Posted by marshal
I'm going to throw a curveball at you
DUALLY TRUCKS COME WITH A FACTORY 6" WHEEL SPACER IN THE FRONT
of course they're safe, just buy good ones.
