Old 07-01-2016, 11:19 PM #1
rannydice's Avatar
rannydice rannydice is offline
rannydice is on a distinguished road
rannydice's Avatar
Gas Tank Capacity?
I feel beyond silly asking this BUT I'm having conflicting reports and real life experience. I bought my 4R this past Saturday and I need clarity lol.
Everywhere I read (searching Internet, looking at the owners manual, and even on here), I see that the gas tank capacity is 23gallons. Ok cool.
Today, I run my car to almost empty, pull into a gas station to fill it for only the second time, and for the second time, the pump stops pumping at 17.8+ gallons. Get in, gauge shows above full.
Soooooooo? Someone please explain lol.
2010 4WD SR5-P
Stock for now but not for long
rannydice is offline   Reply With QuoteReply With Quote
Old 07-01-2016, 11:40 PM #2
PWD4R's Avatar
PWD4R PWD4R is offline
PWD4R is on a distinguished road
PWD4R's Avatar
First off when your fuel light comes on you have roughly 60-100 miles left depending on the vehicle. My last vehicle burned 17 gallons when the light came on and it was a 21.5 gallon tank. Your gauge goes below the E. When you turn off your car that's how low it goes. Even if you're below the E you still have a measurable amount of gas so when you turn it off the gauge goes down some. I used to run mine until it had 1 gallon left lol. The closes I ever came was .3 and when I turned it off the fuel gauge didn't go down. Moral of this is you had more gas left than what the truck led you to believe. It's to prevent people from running out subconsciously
PWD4R is offline   Reply With QuoteReply With Quote
Old 07-02-2016, 09:05 AM #3
Runn4est Runn4est is offline
Real Name: Steve
Runn4est is on a distinguished road
Real Name: Steve
I've never gotten close to the 23 gallon mark either. I think the biggest refuel we've had is right around the 20 mark.
'15 Mag Gray LE -- TOTALED | '14 TE wheels - dipped black, Falken AT3W 285/70/17 | SPC Adjustable UCAs | Daystar 2.5/1.5 top spacer lift | RCI Fuel Tank Skid (Steel) | Shrockworks Step Sliders (trimmed LE Rocker Trim) | SR5 front end conversion
'08 BP Urban Runner -- 5100 fronts at .85 with Toytec 620# springs | SPC Adjustable UCAs | Plastics Guy Front Bump Stops | ICON VS 2.0 Rear with Toytec Superflex 2 inch springs | RCI Transition, Front and Transmission Steel Skid | LT275/65/18 Falken Wildpeak A/T3W | 1.25 inch wheels spacers
www.4runnerfamily.com | IG: Runn4est
Runn4est is offline   Reply With QuoteReply With Quote
Old 07-02-2016, 10:58 AM #4
Trail Wonka's Avatar
Trail Wonka Trail Wonka is offline
Real Name: Bill
Trail Wonka is on a distinguished road
Real Name: Bill
PED4R is dead on! If you want to confirm you can, when your about empty, grab a can of gas and take a drive until you run out. Best to use a road you are comfortable running out on. I like to know where my vehicles actual run out on my gauge.
Sent using Tapatalk
1974 FJ40 1971 FJ55 1953 Willy's Wagon 2008 Sandstorm FJ Cruiser 2016 Quicksand 4Runner TRD Pro
Trail Wonka is offline   Reply With QuoteReply With Quote
Old 07-02-2016, 11:51 AM #5
Ron4RNevada's Avatar
Ron4RNevada Ron4RNevada is offline
Real Name: Ron
Ron4RNevada is on a distinguished road
Real Name: Ron
Toyota and other manufacturers are doing you another favor too:
In modern fuel injected cars with the fuel pump and gage in the tank - the fuel pump is cooled by the fuel running through it.
When you really run out of gas the fuel pump rapidly overheats and destroys itself.
You don't even want the expense and trouble of having to replace that expansive item.
When the low fuel indicator comes on -> FILL UP.
Totally stock 2013 SR5 4WD. Have added Toyo Open Country M/T LT 265/70-R17 (E) tires the first week I owned it. Added second set of Toyo M/Ts at 86900 miles.Added RCI OFF-ROAD Rock Slidersat 84000 miles. Added RCI OFF-ROAD front skid plate at 90,000 miles. Daily driver and so far spending about 30% of time/mileage off-road. Previous truck 2004 Land Rover Discovery that also spent about a third of it's life off-road. I HANG AROUND HERE "THE T4R FASHION FORUM" JUST FOR LAUGHS.
Perfect vehicle as it stands for northern Nevada terrain. Keep it stock - it'll go most anywhere as is.
Ron4RNevada is offline   Reply With QuoteReply With Quote
Old 07-02-2016, 01:51 PM #6
Bob22222 Bob22222 is offline
Bob22222 is on a distinguished road
Just fill up before a quarter tank. That way you never have to worry about it. And your vehicle and its fuel pump will thank you. Especially this time of year as the fuel pump is cooled by the fuel it is submerged in. Little fuel, little pump cooling.
Bob22222 is offline   Reply With QuoteReply With Quote
Old 07-02-2016, 01:52 PM #7
Mariner's Avatar
Mariner Mariner is offline
Real Name: Dustin
Mariner is on a distinguished road
Mariner's Avatar
Real Name: Dustin
I usually fill up when my gas needle is in between 1/4 and 1/2 tank. The 4Runner is new to me but I've done it with all my vehicles for multiple reasons. One was mentioned above, the fuel pump. If they're in the tank, that's an expensive repair. Two, if you park on a hill anywhere, depending on where the suction line is, you may have less usable gas to start. I've seen instances where I start facing down or up a hill and once I get on level ground, the gas needle moves. Three, I grew up in Maine and it's never good to leave low fuel in your car on a brutally cold night. And finally, some gas needles on older cars are incorrect. I very embarrassingly ran out of gas at a stop light because my needle showed 1/4 tank, but upon fill up, went way above the full line. Shit happens. And I prefer to not be the one high and dry on the side of the road.
2016 Super White Trail (build in process)
2013 Tuxedo Black Ford Raptor SVT (built and sold)
Mariner is offline   Reply With QuoteReply With Quote
Old 07-02-2016, 07:15 PM #8
PWD4R's Avatar
PWD4R's Avatar
Keep in mind that modern vehicles don't have a bobber so whether you're on a hill or not won't change the needle position.
Old 07-02-2016, 08:55 PM #9
Ezlife45 Ezlife45 is offline
Ezlife45 will become famous soon enough
I can say for a fact that my '14 has a low fuel light that comes on when my OBC says I have 20 miles left. None of my other vehicles do that. I hate to do anything about it but it sure would have been nice if it was 60-100 miles like the other poster previously stated.
Ezlife45 is offline   Reply With QuoteReply With Quote
Old 07-02-2016, 09:25 PM #10
Bossman's Avatar
Bossman Bossman is offline
Bossman is a glorious beacon of light Bossman is a glorious beacon of light Bossman is a glorious beacon of light Bossman is a glorious beacon of light Bossman is a glorious beacon of light
Bossman's Avatar
Cosmo Kramer - completely below the slash!
https://www.youtube.com/watch?v=TuEdU_lrtZk
Summer: Michelin Defender LTX 245/60R20 on OEM Limited 20" rims / Winter: Toyo Observe GSi-5 265/70R17 on 2018 TRD Off-Road 17" rims.
Bossman is offline   Reply With QuoteReply With Quote
Old 07-02-2016, 11:25 PM #11
PWD4R's Avatar
PWD4R's Avatar
What your computer says you have left is far below what you really have. In my Corolla my miles left will say 0 but I can still go 40 miles without worrying. You guys need to quit worrying about these digital games and understand your fuel capacity. Granted yes fuel pumps need the fuel to keep them from overheating but every now and then won't kill them. It's better to know the truth. I promise you that if you run that down to 0 miles until empty you still have at least a gallon left maybe 2.
Old 07-02-2016, 11:26 PM #12
PWD4R's Avatar
PWD4R's Avatar
Next time my miles says 0 to empty I will take a photo of my odometer and then another right before I fill up. You'd be surprised at what's left..
Old 07-03-2016, 10:13 AM #13
Agreed. Just don't want to put a 5 gallon can and test it to be certain. Just bothers me how late the light comes on. My trucks come on at 1/8 of a tank.
Old 07-03-2016, 02:13 PM #14
Lester Lugnut's Avatar
Lester Lugnut Lester Lugnut is offline
Lester Lugnut has a spectacular aura about Lester Lugnut has a spectacular aura about
Not to cut hairs, but if it's coming on with the needle at 1/8th full, I'd say it's coming on early.
2015 2WD Toyota Tacoma Prerunner V6 SR5 1GR-FE 236HP VVT-i
2014 2WD Toyota 4Runner SR5 1GR-FE 254 HP Dual VVT-i
2006 Toyota Avalon 3.5l automatic 2GR-RE Dual VVT-i
1991 Mercedes-Benz 300-SEL M103
1975 Kawasaki 900 Z1-B
Lester Lugnut is offline   Reply With QuoteReply With Quote
Old 07-03-2016, 09:16 PM #15
Not really, had three trucks do exactly the same thing. They were all dodges. I think even the owner's manual states 1/8 of a tank.
Now my Runner is a totally different story. I would love it if it would come on with about 50 or so miles left. When I've gotten down to the light, I believe I pumped around 21 or so gallons. It's not my daily driver so I don't really "know" it as well as my beater cars.
Tires, Gas Tank Capacity and Air Pressure SwiftRunner Classic T4Rs 9 07-05-2016 09:14 AM
Gas tank capacity less than 23 gallons geenowalker 4th Gen T4Rs 23 05-03-2016 10:06 AM
fuel tank capacity/mpg measurement amalik 3rd gen T4Rs 3 03-11-2014 03:24 PM
5th Gen Gas Tank Capacity and Range syndicate1 5th gen T4Rs 26 06-08-2012 04:50 PM
Fuel tank capacity? Red Classic T4Rs 2 03-28-2008 10:52 AM
