Old 12-27-2020, 02:27 PM #31
jbatchelor jbatchelor is offline
jbatchelor is on a distinguished road
I have owned 2000 4 runner for 17 years, have never got over 13.5 gals in fuel tank . Never even close to 18.5 .
jbatchelor is offline   Reply With QuoteReply With Quote
Old 12-27-2020, 02:39 PM #32
fuel tank capability
I can only get 13.5 gals into 2000 4 runner tank never even close to 18.5 as manual quotes.
Old 12-27-2020, 02:42 PM #33
BlackCloud's Avatar
BlackCloud BlackCloud is offline
BlackCloud has a spectacular aura about BlackCloud has a spectacular aura about
BlackCloud's Avatar
My 2016 Gen 5 will take 2.5 gallons more fuel after the auto fill fuel pump stops.
Manual says 23 gallons. I once put in 24.95 gallons.
BlackCloud is offline   Reply With QuoteReply With Quote
Old 12-27-2020, 03:04 PM #34
Real Name: Skip
Real Name: Skip
Full in the tank and "full" in the filler neck are 2 different things, the filler neck is quite long and can easily hold another couple gallons.
That being said if you fill it up into the filler neck every time or quite often you risk messing up the charcoal canister which can be quite costly to replace, the canister is design to deal with gas fumes, liquid fuel will damage it to the point it will need replacing, with the fuel level way up into the filler neck the gas can easily get into the hose going to the canister.
2004 Limited V8
Old 12-27-2020, 09:55 PM #35
Ezlife45 Ezlife45 is offline
Ezlife45 will become famous soon enough
While I agree that sometimes the gas has bubbles that stops the pump quickly, sometimes the pump is very sensitive to the bubbles too. I have a difficult time seeing the filler neck holding another two gallons of fuel. I would suspect that possibly the calibration of the fuel pump may be off. In other words charge you for 24 gallons but only pump 22.
Ezlife45 is offline   Reply With QuoteReply With Quote
Old 12-27-2020, 10:33 PM #36
shadow247's Avatar
shadow247 shadow247 is offline
shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice
shadow247's Avatar
Common 3rd Gen problem. Fixed on the 2001 and up. My 99 had the same issue. The light comes on with about 5 gals of fuel left instead of 2 like it should. Just know that there is about 5 gals of fuel left when your light comes on. At 17 mpg, I figured I could go another 60 to 90 miles once the light came on. Never ran out of gas.
There is no simple or easy fix. Involves replacing the sending unit and an updated circuit board in instrument cluster.
The 4Runner Show
shadow247 is offline   Reply With QuoteReply With Quote
Old 01-03-2021, 11:54 PM #37
2Biglabs 2Biglabs is offline
2Biglabs is on a distinguished road
Eh, just do what my wife does. When the light comes on reset trip A. when 50 miles comes up, get gas....
works every time... I usually get a call... the car wont go anymore. I think im out of gas....
2Biglabs is offline   Reply With QuoteReply With Quote
Old 01-06-2021, 06:11 PM #38
BlackCloud's Avatar
BlackCloud's Avatar
It consistently takes 2.5 gallons more at pumps all over the place.
Old 02-14-2021, 08:04 PM #39
Nicknasty's Avatar
Nicknasty Nicknasty is offline
Real Name: Nick Pasquale
Nicknasty is on a distinguished road
Nicknasty's Avatar
Samesies
2000 4runner sr5, Imperial Jade Mica, bone stock, 191k
Nicknasty is offline   Reply With QuoteReply With Quote
Old 02-17-2021, 10:09 PM #40
AgentKooper AgentKooper is offline
AgentKooper will become famous soon enough
Today I took my 2021 Pro down to 35 miles left on the range calculator. At that point my empty light went on, right as I was coming up on a gas station. I had a stretch of snowy foothills to get through before the next gas station, so I decided not to chance it further.
Pumped 18.5 gallons up to the auto shutoff.
2021 4Runner TRD Pro (Lunar Rock)
AgentKooper is offline   Reply With QuoteReply With Quote
Old 02-17-2021, 11:47 PM #41
spartacus's Avatar
spartacus's Avatar
That's odd! I ve filled it with 16+ gallons several times.
Old 04-09-2021, 04:53 PM #42
Captain Planet's Avatar
Captain Planet Captain Planet is offline
Captain Planet will become famous soon enough
I've had mine fill 21 before, but that was driving way past the light being on.
On my 19, it will come on around 30mi left. It will go down to 1 and just stay at 1mi left.
I only did this because I had 3 gallons on the roof and I was just driving around town, curious if I could make it to where I was going. Never managed to run it dry.
Captain Planet is offline   Reply With QuoteReply With Quote
Old 04-17-2021, 07:38 PM #43
I4Ran I4Ran is offline
I4Ran is on a distinguished road
This thread helps. I swore these had 16 gallon tanks, and that the owners manual was full of lies!
I4Ran is offline   Reply With QuoteReply With Quote
Old 04-21-2021, 03:46 AM #44
newt0n newt0n is offline
newt0n is on a distinguished road
You can go a long ways after the fuel light comes one. Something like 5 gallons left in the tank still.
newt0n is offline   Reply With QuoteReply With Quote
Old 05-12-2021, 10:51 PM #45
Fountainhead's Avatar
Fountainhead Fountainhead is offline
Fountainhead is on a distinguished road
Whew! Typically haven't run it to empty but this week took it down to '0' miles left and hit the gas station. Both times only 20 gallons +/- .25. 2015 Trail and checked the manual, it says 23 gallons. Guess I'll throw my gas pack on the rig and test the mentioned theories. If so then like the previous poster mentioned, reset trip milage and watch for 50 more, kind of silly if you ask me. But if it works, good to know.
On the top off or overfilling point; my buddy just informed me of this recently as I would every once and a while on long trips add more gas. He said it was not good but could not articulate as well as explained here. Thanks.
2015 TE w/KDSS, Gray. And, I understand. Ergo, Toyota.
Fountainhead is offline   Reply With QuoteReply With Quote
Tires, Gas Tank Capacity and Air Pressure SwiftRunner Classic T4Rs 9 07-05-2016 09:14 AM
Gas tank capacity less than 23 gallons geenowalker 4th Gen T4Rs 23 05-03-2016 10:06 AM
fuel tank capacity/mpg measurement amalik 3rd gen T4Rs 3 03-11-2014 03:24 PM
5th Gen Gas Tank Capacity and Range syndicate1 5th gen T4Rs 26 06-08-2012 04:50 PM
Fuel tank capacity? Red Classic T4Rs 2 03-28-2008 10:52 AM
