Originally Posted by BlackCloud
My 2016 Gen 5 will take 2.5 gallons more fuel after the auto fill fuel pump stops.
Manual says 23 gallons. I once put in 24.95 gallons.
Full in the tank and "full" in the filler neck are 2 different things, the filler neck is quite long and can easily hold another couple gallons.
That being said if you fill it up into the filler neck every time or quite often you risk messing up the charcoal canister which can be quite costly to replace, the canister is design to deal with gas fumes, liquid fuel will damage it to the point it will need replacing, with the fuel level way up into the filler neck the gas can easily get into the hose going to the canister.
