Originally Posted by MSRP.
Don't think you need a pump.. just simple clear tubing and siphon it down to the fill port.
I'd recommend at least using a cheap shaker- or bulb-prime siphon instead of the old
suck-and-gag method.
Shakers are cheapest but require a few inches of fluid in the upper tank to start. With these you want to siphon the entire upper tank once you get going.
Bulb-primes are slightly more expensive (still generally less than $20) but can be started as long as the upper liquid covers the end of the hose.
