Old 06-14-2017, 12:14 AM #1
2010-Runner-Trail's Avatar
2010-Runner-Trail 2010-Runner-Trail is offline
2010-Runner-Trail is on a distinguished road
PLEASE HELP, I am so lost!!
Ok yall I really need some help. I have been chasing this forever now and I am SOOO sick of it I find myself not even wanting to drive my 4runner.
Here is the deal, while coasting I get a grinding noise that sounds like its coming from the Tcase. I have replaced the tcase, both driveshafts and all u-joints. It still happens. The faster I go the worse it gets. This only happens when there is no load on the drive train. If I am using the engine to break or accelerating the noise goes away. Here is a link to a video of the problem, sorry its shot at night.
https://www.youtube.com/watch?v=Euy8xB9J_3E
Please any help would be greatly appreciated!!
2010-Runner-Trail is offline   Reply With QuoteReply With Quote
Old 06-14-2017, 12:42 AM #2
4Reak Show's Avatar
4Reak Show's Avatar
Probably transmission bearing my friend. When accelerating (and I also believe engine breaking) you're putting load on one side of the gear teeth (called the drive side for obvious reasons)
And when coasting, the driveshaft is pushing the guts of the transmission from the other side of the gears (called the coast side as you can imagine why). Likely a bearing in the mainshaft or countershaft gets cocked just right and makes the noise.
That's my guess anyhow.
Good luck.
Old 06-14-2017, 01:44 PM #3
Thanks for the input. May be pulling the tranny.
Old 06-14-2017, 10:05 PM #4
gm350reratliff's Avatar
gm350reratliff gm350reratliff is offline
gm350reratliff has a spectacular aura about gm350reratliff has a spectacular aura about
Hard to tell online here at work since the PC speakers suck but it sounds more like a vibration possibly from a transmission mount or exhaust pipe rattling against something. I would find someone with a 4-post lift and see if you can replicate it while you can look underneath.
2014 Super White Trail Premium My build thread: http://www.toyota-4runner.org/5th-ge...ld-thread.html
2008 SR5 4X4 V6 Better late than never build thread: http://www.toyota-4runner.org/4th-ge...ld-thread.html
gm350reratliff is offline   Reply With QuoteReply With Quote
Old 06-14-2017, 10:42 PM #5
4Reak Show's Avatar
4Reak Show's Avatar
Duh haha. ^^^ totally forgot about replicating with rear wheels off the ground and a stethoscope. I'd do that before yankin trans.
Old 06-16-2017, 02:30 AM #6
nglayton's Avatar
nglayton nglayton is offline
Real Name: Neal
nglayton is just really nice nglayton is just really nice nglayton is just really nice nglayton is just really nice
nglayton's Avatar
Real Name: Neal
Throw out bearing? Clutch disk failing? But I assume since you swapped the xfer case you checked those. Main bearing? or the Transmission are about all that's left.
nglayton is offline   Reply With QuoteReply With Quote
Old 06-16-2017, 02:38 AM #7
dms1 dms1 is offline
dms1 is an unknown quantity at this point
Sounds like the throw out bearing on the Clutch
Dave S
dms1 is offline   Reply With QuoteReply With Quote
Old 06-17-2017, 05:26 PM #8
RBE17 RBE17 is offline
Real Name: Steve
RBE17 is on a distinguished road
Real Name: Steve
That sounds rough. I'd try and replicate it w/ all four tires off the ground and check for rubbing. It might be something very simple, but if you pull the trans, check everything. No need pulling it more than once.
FWIW, I chased a whirling in a 95 Trans Am that only happened if the car was in neutral. If I pushed in the clutch, all was fine. Under load, all was fine. I pulled the trans three times in a week. Each time I replaced the pilot bushing in the crank shaft. On the last time I used a brass bushing instead of a bearing. All whirling went away after that. I couldn't believe it.
Good luck.
RBE17 is offline   Reply With QuoteReply With Quote
Old 06-17-2017, 10:28 PM #9
BlackWorksInc's Avatar
BlackWorksInc BlackWorksInc is offline
BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold
Throwout bearing? Did the OP swap in a manual from a Tacoma or FJ?
BlackWorksInc is offline   Reply With QuoteReply With Quote
Old 06-17-2017, 11:18 PM #10
4Reak Show's Avatar
4Reak Show's Avatar
Noise coasting in gear = throw out and pilot bearings aren't in use (flywheel and trans input spinning together, so pilot bearing isn't spinning. foot off clutch pedal means throw out bearing is retracted and not spinning)
My money is still on internal. Running in the air with stethoscope is the next best option in my humble opinion
driveshaft , grinding , loud , noise , tcase
Lost my key!!! Help please Zonly1 4th Gen T4Rs 13 01-21-2017 09:50 AM
Lost OD? Ol'Blue 3rd gen T4Rs 16 01-16-2014 05:52 PM
In memory of those lost and those who have lost SV_Dude Off Topic 5 09-11-2013 09:58 PM
lost my job 4Evr4RunN3R Off Topic 41 02-06-2009 11:45 PM
