Old 06-21-2017, 02:25 PM #1
David61 David61 is offline
David61 is on a distinguished road
Unhappy Very Strange Actuator Behavior- HELP
05' 4 Runner, 6 cyl. Was stuck in 4WD, it would go in but not out. I did the forward backward thing with no change. By chance with the car in 4WD, I stopped, put it in park and turned off the engine / restarted and 4WD disengages every time. I would switch back to 4WD and it engages, but wont engage until I restart. This happens from forward or reverse.............please dont say I need a new actuator. What's going on? are there any tests? cleanings..................Thanks for your wisdom!
One more thing, the 4WD status lights are always blinking when in 4WD mode.
David61 is offline   Reply With QuoteReply With Quote
Old 06-21-2017, 03:16 PM #2
Muzzle of Bees Muzzle of Bees is offline
Muzzle of Bees will become famous soon enough
I think there are vacuum lines doing some work that need tested?
2016 TEP
Muzzle of Bees is offline   Reply With QuoteReply With Quote
Old 06-22-2017, 10:31 AM #3
Brandon H's Avatar
Brandon H Brandon H is offline
Brandon H will become famous soon enough
Brandon H's Avatar
Your front Actuator is going out. There is probably some moisture inside the actuator causing it to go bad. I replaced 3 of them on my 07 Tacoma. I had the exact same problem you did
'17 T4R TRD OR Premium w/KDSS. Icon Stage 7,Nitro 4.88 Gears, Volk TE-37 XT-M SPec wheels, Toyo Open Country RT Trail 35/12.50/17 Tires, RCI Aluminum Skids, CBI Front/Rear Bumpers, Alu-Cab load bars, Alu-Cab 3.1 Roof Top Tent, OEM Audio Plus Reference 450Q, Baja designs S8 30", Baja Designs Squadron Pros, Baja Designs Squadron Sports (Rear bumper), Baja Designs LP6 (Roof)
IG: @Expo_T4R
Brandon H is offline   Reply With QuoteReply With Quote
Old 06-22-2017, 12:19 PM #4
jwkilgore's Avatar
jwkilgore jwkilgore is offline
jwkilgore is on a distinguished road
jwkilgore's Avatar
Have you confirmed that you're actually going into 4WD? Turn off traction control and try to spin the tires on dirt to see if both front and back are getting power.
My guess is that it's trying to work the actuator but failing and throwing a code. The code stays active until you restart the engine and reset the code.
2011 SR5 4WD, Maroon, no 3rd row, no sliding cargo tray.
ARB Bumper/Bullbar; Southern Style Offroad Sliders; Budbuilt Gastank Skid
OME Nitrocharger Sport Suspension (884 front, 895E rear); Gen Grabber ATX 275/70R/17
jwkilgore is offline   Reply With QuoteReply With Quote
Old 06-22-2017, 01:51 PM #5
Further testing reveals =
Drive to Park+ 2wd to 4wd and 4 to 2 = audible disengage.
Neutral to park, 4 to 2 = audible disengage
P 4 to 2 and 2 to 4 engage /disengage = audible
P 2 to 4 = audible engage.
I hope this helps, I'll check the vacuum lines (any secrets) Thanks again for helping me out.
Old 06-22-2017, 07:02 PM #6
I'll try spinning on dirt. Going out of town for a week and will let you know what happens. So the actuator is trying, but failing and "throws a code" to indicate the failure........how and where do I find the code?
Old 07-06-2017, 06:46 PM #7
t-case diagnosis, what's up??????
OK, Got the 4R off the ground.
4H - 4L Actuator sound, engine off to reset.
4L - 4H Actuator sound, no sound returning to 4H
Otherwise I heard no other sounds. The front tires never turned, the front drive shaft engaged, but no front wheels turned. The left front wheel is a little more difficult to spin than the others........what do ya think? I'm hoping its the front.
I saw another post about taking the cover off the t-case actuator to inspect the gears for corrosion etc. There was also some talk about cad electrical contacts on the actuator motor. Thanks!
actuator , strange issue
Strange Cruise Control behavior Mudeprived 3rd gen T4Rs 15 03-22-2018 04:17 AM
Strange Transmisson Behavior on Cold Start 4'running'26 3rd gen T4Rs 5 12-20-2016 11:55 AM
Strange idle behavior Freb_mc 3rd gen T4Rs 2 06-06-2016 10:41 AM
High Idle, Strange IAC behavior jcush87 3rd gen T4Rs 7 12-07-2015 02:08 PM
Strange temp and heater behavior after thermostat replacement giro Classic T4Rs 5 11-21-2013 09:16 AM
