07-10-2017, 10:51 AM
#16
Real Name: Chris
Real Name: Chris
Originally Posted by Signal
I am 5' 7.5" and I can tell its going to be a chore to pack the tent up. On the back I have a Gobi ladder and of course the RTT has a ladder. But I need something to get up when necessary for example to pack the RTT around the front. I have not done the pack/unpack routine much since buying it so maybe I will not need it, but I am thinking maybe a retractable ladder of sorts. On one hand I am a bit put off by having 3 ladders in the vehicle, so I am hoping maybe with technique a ladder isn't necessary for packing the RTT.
I am a little over 5'9" and have a 3" lift. its a struggle some of the time but I have not needed a ladder yet. I usually climb on top to zip the cover which is the hardest part for me.
07-10-2017, 11:57 PM
#17
Here are a couple of pics of the FR rack and RTT with the FR quick release mounts.
Pros: The quick release is really easy to install and works perfectly. It seriously takes 2 mins to take RTT off the rack.
Cons: The RTT sits up about 5-6, inches higher than before which causes more wind noise. It cost a lot $300. Center of gravity of the vehicle is higher.
Overall, I'm happy with it. It's worth it for me. It won't be a PITA to take off and on.
Sent from my Pixel using Tapatalk
09-15-2017, 06:27 PM
#18
Real Name: Chris
Real Name: Chris
These are so worth the $. After all initial install and measurements it takes less than 5 minutes to take CVT Mt. rainier Summit Series on and off. They are also lockable rig a TSA Style cable lock. Insert into pinhole and it's virtually impossible to get at with anything other than the key to the lock.
2015 SR5 Premium 4wd Magnetic Grey w/3rd row: Frontrunner Slimline II 3/4 Rack - Yakima Skybox 16 - Weathertech - 22" Behind Grill Light Bar - TRD Skid w/Full Aluminum RCI Skids - RCI Sliders - Falken AT3 265 SL - Lamin-X - Taxa Cricket
"If I Can Do it You Can" Light Bar Install
ARB Breather Mod
Cymon's Weekend Warrior/MFD Thread
10-16-2018, 12:31 AM
#19
Hey! Looks good. Can you explain how the quick release mounts make it sit over 5 inches taller? It doesn't look like it would be more than a couple inches taller than sitting directly on the Front Runner.
Thanks!
05-18-2019, 03:21 AM
#20
Incident Report - Wind Blew Floor Overhang up, Ladder Got Stuck
Had a grand time in Death Valley. Titus Canyon, to Ubehebe Crater, to roadside camp on Racetrack Playa a couple of miles south of the crater. Next day, we drove to Tea Kettle Junction, Racetrack Playa, and got to Homestake Dry Camp early for snacks, siesta and a relaxed evening.
I slept on ground as usual. Late at night strong gusts of wind woke me up, but no worries. Then more gusts and it started to drizzle. As I walked toward my friend's Jeep to sleep under his awning, he called me from his Front Runner RTT.
The wind * had blown the floor overhang and folded it up. The ladder swung against the RTT cover that is left draped from the roof rack and got caught in its folds. In that configuration, my friend could not reach and free the ladder! He could have exited through the zippered window, but since I was already down below, I just helped him free the ladder and bring the floor back to horizontal.
One potential preventive would be to tie a guy-line from ladder hinge to rock slider.
HOMESTAKE DRY CAMP AT SUNSET
IT COULD HAPPEN TO YOU, TO ANY ROOF-TOP TENT
* Note that winds in that area are strong enough to move rocks! ARTICLE HERE
The awning held because I guyed it out.
86 4Runner, 22R-Eliable, 5-Speed Manual, dlx. WHAT'S YOURS?
If you want us to help from afar please let us see, hear, feel what you're dealing with.
A picture paints a thousand words.
Toyota components are bullet-proof. Issues often arise from poor wiring, assembly and/or maintenance. Suspect those first.
Next only to our senses, the multi-meter is the most important electrical diagnostic tool. Spend $6 at Harbor Freight or $$$ blindly replacing parts.
05-18-2019, 10:45 AM
#21
Real Name: Chris
Real Name: Chris
this! I always stake mine down. I've been in some really crazy winds where the whole car is shaking but never had an issue of the ladder or tent blowing around.
05-18-2019, 03:52 PM
#22
Originally Posted by leftyguns21
this! I always stake mine down....
Yeah, I preach that to all friends regarding any camping setup, especially mountaineering tents. Guy-outs are best protection from the wind blowing tent down or away.
07-03-2019, 10:42 AM
#23
Real Name: CJ
Real Name: CJ
When unpacking and packing my Tepui, I literally just lie on the top of the tent. You can roll your weight back and forth to make adjustments all the while placing all the pressure in the tent rails and not the vehicle.
07-03-2019, 11:52 AM
#24
Real Name: CJ
Real Name: CJ
This is a great idea! Thanks for the suggestion.
07-06-2019, 02:12 PM
#25
Real Name: Matt
Real Name: Matt
Can one of you two tell me how high the bottom of the tent is from the top of the 4Runner roof with this front runner rack?
I just lifted my wife’s 4Runner and now it’s too high with the tent to fit in the garage and I need a couple of inches.
2015 4Runner trail, roof top tent
07-06-2019, 02:55 PM
#26
Real Name: Chris
Real Name: Chris
depends on what tent you have
the front runner quick release tent mounts add just under 2" to height of rack
I have the CVT Mt Shasta and its almost 16" from the bottom rail to the top of the ladder(closed)
if you have a standard garage entrance it is probably only 7' high, this is not high enough for most SUVs with a rack/RTT
07-07-2019, 01:02 PM
#27
Real Name: Matt
Real Name: Matt
Not sure I explained what I was asking for very well. I understand that the height of the tents vary. what is the distance from the top of the roof of your 4Runner to the bottom of the tent rails with the rack and quick release mounts?
07-07-2019, 01:46 PM
#28
Real Name: Chris
Real Name: Chris
I no longer have a 4Runner but measured it on my GX. It is just under 6" from top of roof to top of the release mounts. From top of roof to the top of the slat its 4", the quick release tent mount is 2". From top of roof to top of rack (since the sides sit up higher than inside) is 5"
My guess is a 4Runner is roughly the same since Frontrunner uses similar trays and feet for all vehicles.
08-02-2022, 03:02 PM
#29
I have a slimline II on top of my 05 4R and the Front runner tent. I want to mount the front runner awning with the quick release mounts on the rack (the side pictured below). Im pretty sure it will block my zipper access. Anyone done this yet?
Google Photos
2005 4RUNNER LIMITED
