Old 10-04-2021, 06:00 PM #1
08 Hilux Surf 08 Hilux Surf is offline
08 Hilux Surf is on a distinguished road
Driving on 4H 4wd
What is the max speed driving on 4H 4wd? I heard the max speed on 4H for the new 5th generation 4R is 60mph. I live in Seattle which "rains a lot" and I often used to drive my old '08 4R SE on a wet surface freeway up to 75mph and never had any issues while owning the 4R. Of course the main use on 4H was dirt and gravel (or snow) roads and would not drive over 55mph.
Please comment if driving over 65mph on a freeway with wet surface may be a problem to the new 5th gen 4R. I got a new '21 TRD Off Road this summer and unfortunately had to give up my 08 4R SE due to high mileage (no issues on 4wd). Appreciate your feedback/comments.
08 Hilux Surf is offline   Reply With QuoteReply With Quote
Old 10-04-2021, 06:14 PM #2
mscot mscot is offline
mscot is a glorious beacon of light mscot is a glorious beacon of light mscot is a glorious beacon of light mscot is a glorious beacon of light mscot is a glorious beacon of light
I've never gone over 60. If I can go that fast I'm usually safe switching back to 2wd.
The 5th gen does not have an LSD on the front when in 4x4 mode so the front tires can bind.
Build thread
mscot is offline   Reply With QuoteReply With Quote
Old 10-04-2021, 09:12 PM #3
Ascole Ascole is offline
Ascole will become famous soon enough
There’s a handful of threads about this, seems the most recent is this one:
Top speed in 4-High
As a side note; I’m from Seattle and have never felt the need to drive in 4wd on the highway in the rain.
Probably helped I learned to drive there in a 2wd Ford Ranger with bald tires and no weight in the rear.
Ascole is offline   Reply With QuoteReply With Quote
Old 10-04-2021, 09:21 PM #4
BorotHex BorotHex is offline
BorotHex has a spectacular aura about BorotHex has a spectacular aura about
I don’t understand why one would drive in 4WD on just a wet road.
What’s the objective?
BorotHex is offline   Reply With QuoteReply With Quote
Old 10-04-2021, 11:12 PM #5
AuSeeker AuSeeker is offline
Real Name: Skip
Real Name: Skip
I just read what it says in your owner manual...
"H4 (high speed position, four-wheel drive)
Use this for driving only on tracks that permit the tires slide, like off-road,
icy or snow-covered roads. This position provides greater traction than
two-wheel drive."
I highlighted in red the adverb which is key to what it says you can or can't do. IMHO
It says nothing about how fast...but more importantly it doesn't say wet/rainy roads/tracks, which tells me not to use 4H on just rainy/wet roads because it apparently doesn't allow "tire slide", or at least enough "tire slide" to not damage the 4WD system.
2004 Limited V8
Old 10-05-2021, 09:56 AM #6
jp.vegas jp.vegas is online now
jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light
The ‘08 4Runner Sport had an all wheel drive mode. You put it in 4 high but don’t lock the center diff, and it can be used on any road at any speed the vehicle is capable of, just like the Limited trim.
None of the 5th gens, besides the always AWD limited, have his capability any longer because there’s not a lockable center diff on the other trims.
4 high in a 5th gen is the same as 4 high locked center in the old 4th gen sport model. You shouldn’t be driving on wet roads with it, only loose or icy surfaces as stated in the manual.
'20 Army Green 4Runner TRD PRO
'16 Quicksand Tundra TRD PRO Gone
'08 Salsa Red Pearl 4x4Runner SE V6:
Gone
jp.vegas is online now   Reply With QuoteReply With Quote
Old 10-06-2021, 10:21 AM #7
JK47! JK47! is offline
JK47! is on a distinguished road
This is good info. Is anyone aware of an actual situation occurring with a Gen5 where driving in H4 improperly has damaged the 4x4 system? Just wondering how much abuse it would take to break something.
JK47! is offline   Reply With QuoteReply With Quote
Old 10-06-2021, 12:03 PM #8
RichinRidgewood's Avatar
RichinRidgewood RichinRidgewood is offline
RichinRidgewood is a splendid one to behold RichinRidgewood is a splendid one to behold RichinRidgewood is a splendid one to behold RichinRidgewood is a splendid one to behold RichinRidgewood is a splendid one to behold RichinRidgewood is a splendid one to behold RichinRidgewood is a splendid one to behold
I engage 4H in the rain whenever I think there could be a traction issue. I drive at the appropriate speeds for the conditions. I don't bother if Im driving on slow moving surface streets.
2020 4Runner SR5 Premium 4x4
Barcelona Red, Graphite/Grey
Sunroof
RichinRidgewood is offline   Reply With QuoteReply With Quote
Old 10-06-2021, 01:33 PM #9
spartacus's Avatar
spartacus's Avatar
Most folks will not knowingly try to abuse or break their 4x4 systems on this forum but then again I might be wrong
Old 10-07-2021, 12:53 PM #10
I was thinking more along the lines of accidentally leaving it in 4H and driving at excessive speeds on dry pavement and causing damage. Not purposely trying to kill it.
Old 10-07-2021, 07:58 PM #11
Jetboy's Avatar
Jetboy Jetboy is offline
Jetboy's Avatar
Max speed is not 60mph for driving in 4hi in the 5th gen. The max speed to shift from 2hi to 4hi is 60mph. The limit is because there's a clutch that engages to bring the non-spinning parts up to speed in the transfer case before the gears mesh. So it has a max engagement speed. Over that speed it just tells you to slow down before it'll engage. Max driving speed in 4hi is 113mph in the 5th gen. I believe that is the same for all models. The Limited version shares the same drive train entirely except the transfer case is awd and it lacks the front passenger side intermediate axle shaft disconnect mechanism. And it also shares the same 113mph speed governor I think.
65mph is no problem in 4hi on wet roads. I wouldn't think twice about 80mph cruising in 4hi. I've done it many times.
Good luck.
Old 10-10-2021, 04:13 PM #12
Thank you for your input/comments. Yes, I agree about the max speed when shifting to 4H from 2H. But I never seem to get a clear answer on the max speed driving on 4H. Furthermore, I get more comments that I shouldn't drive on wet surface. All my other 4WD Toyotas driven in Japan recommended/allowed me to drive 4H on wet, dirt, or snow conditions. Obviously I'm not trying to damage the 4wd on my new TRD OR, but my main purpose of driving in 4H is the "traction" while driving in the rain for "safety purpose". Freeway surface may be smooth, but with rain driving around 60-75mph there are always some slight curves, uneven surface, or small holes, and even possibility of hydroplaning as the amount rain/pour can change constantly... And of course I wouldn't drive 60-75mph in heavy snow either. I get various comments which is a bit confusing but thank you for your comments!
Old 10-10-2021, 04:47 PM #13
Devbot's Avatar
Devbot Devbot is online now
Real Name: Devan
Devbot's Avatar
Real Name: Devan
Top speed in 4-High
Also from the area, yeah this is just absurd Only time I use 4WD in the rain is coming up are on the hills in Everett and Seattle in stop-and-go traffic
That's like putting on studded tires on for a frosty morning
Devbot is online now   Reply With QuoteReply With Quote
Old 10-11-2021, 12:25 AM #14
Baystate4Runner's Avatar
Baystate4Runner Baystate4Runner is offline
Baystate4Runner will become famous soon enough Baystate4Runner will become famous soon enough
Speed gov in 5th Gen models is 118mph and that’s were mine kicks in (speed measured with GPS)
2024 Lexus GX550 Overtrail+ - pre ordered
2021 TRD Pro - Lunar Rock
2017 TRD Pro - Super White, RCI Rock Sliders, Falken Wildpeak A/T3W - SOLD
2012 Porsche Cayman S
Baystate4Runner is offline   Reply With QuoteReply With Quote
Old 10-11-2021, 01:48 AM #15
Jakeepoo3's Avatar
Jakeepoo3 Jakeepoo3 is offline
Jakeepoo3 has a spectacular aura about Jakeepoo3 has a spectacular aura about Jakeepoo3 has a spectacular aura about
Jakeepoo3's Avatar
40 mph
Jakeepoo3 is offline   Reply With QuoteReply With Quote
4wd , drive , driving , surface , wet
Best driving practice for driving up hill Satter 3rd gen T4Rs 35 02-02-2020 05:35 PM
Driving in 4wd? Schamattack 4th Gen T4Rs 1 01-11-2018 10:26 AM
TJM Xray Driving Light - 220mm QH Driving zooroadbaja For Sale: Non-T4R Items 1 05-16-2013 09:35 PM
Think twice before driving in.... taylz Classic T4Rs 1 04-01-2012 09:55 PM
