Old 03-06-2018, 04:55 PM #16
JPOVS's Avatar
JPOVS JPOVS is offline
JPOVS will become famous soon enough
JPOVS's Avatar
I use a Stihl 201TC with a 16” bar. What I carry it in is a Stanley tool box that has a o-ring that keeps in the smells for when I store it in the cab, and keeps the weather out for when it’s on the roof. I can fit all the necessary tools, safety gear, gas, and oil inside too. Also the removable tray that sits along the inside top I cut down in length to clear the hand brake.
Carrying a Chainsaw-5a9d79d3-5108-4e1f-848b-566f5fbb6fdf-jpg
Carrying a Chainsaw-2c579889-3dbc-4df3-b1e2-886412c8b3e0-jpg
2016 TEP, Elka 2.5 RR Adj F&R, Chaos UCA & LCA, OME 899, KO2 285/70E, Wheeler F&R Bumps, BMC, Spindle Gussets, Cam Tabs, Nitro 4.88 Gearing, Tranny Cooler, Hefty Fab F&R Bumpers Dual w/ ladder, Warn Plat 12s, Icon Pan & Billet Rear Links, OCD Links, GFC RTT, RCI Sliders, Every RCI Skid Plate (In Alum if avail), SCS Stealth 6 Rims, ARB Twin Comp, ARB 2500 Awn, Quick Pitch Shower Awn, Compustar T11 & RMS, Dual 42" drawers W/ Adj sleep/dog height platform (2nd Row Removed) Switch Pros, Baja LP9's, Squadron & S2 Pros, Rock Lights, Dometic CFX3 35qt.
JPOVS is offline   Reply With QuoteReply With Quote
Old 01-04-2021, 09:07 AM #17
Ogre75 Ogre75 is offline
Ogre75 has a spectacular aura about Ogre75 has a spectacular aura about Ogre75 has a spectacular aura about
Originally Posted by DesertCanyons View Post
Occasionally I transport my chain saw up to a friend's cabin for tree trimming and clearing work. I have a 24" Stihl that I bought the carry box for. I keep the saw inside the truck. I carry a one gallon gas jug, a pre-mix jug for mixing fuel and the various oils on top in a crate that I tie down. I don't want gas cans or oils inside the vehicle.
I have a Baja Rack flat utility rack that I tie things down to. The main problem with the Toyota roof rack is that anything you tie down on top sits directly on the roof paint. As things move around on rough roads the top gets scratched. There are ways to work around that, like putting stuff on boards that span between roof rack rails or putting pads down below boxes and hard stuff. Cardboard makes a decent pad, but it's not going to last if it rains.
Generally, you should be running your chain saw dry between uses because old gas in the carburetor is not good for these two stroke engines. If you do, the saw will not be full of fuel when it's inside your car. I dump my unused saw fuel back into a pre-mixed fuel can and then run it for a minute to empty the carburetor.
Only problem with running things dry is that if stored over time, the orings can dry out and deteriorate, then when you add fuel and run again, they can leak.
2014 4R SR5 - 3" Dobinsons, 285/70 Wild Peak AT3, RCI Skid & Sliders, CBI Bumper, Firewire light bar, Diode Dynamics Fogs
Ogre75 is offline   Reply With QuoteReply With Quote
Old 01-04-2021, 02:39 PM #18
702tripgen 702tripgen is offline
702tripgen is on a distinguished road
Originally Posted by Jetboy View Post
I bought one of these 20v versions for about $100 around black friday. With two 9ah 60v batteries that I already have for my cordless tools - it's amazing how much the little saw will cut. I'm probably going to sell my little stihl ms170 that was my camp saw. If you're cutting all day - the gas saw is by far the better choice. If you need to clear a log or two - the cordless saws are the answer. No mess (It does use chain oil). No noise. No smell. No hassle with starting. And while they're kinda $ if you don't already have batteries, they're cheaper than most gas saws by the time you add a gas can, a case, roof rack to store it outside the car. And it weighs next to nothing.
I second the Dewalt 20V chainsaw, the thing is amazing! I bought an extended Oregon bar/chain combo for it but haven't even installed it yet because the stock setup has worked for the little jobs I have used it for.
702tripgen is offline   Reply With QuoteReply With Quote
Old 01-07-2021, 08:50 AM #19
Direwolf82 Direwolf82 is offline
Direwolf82 will become famous soon enough
Pretty much every lawn guy and 2 cycle repair place I know of all say run it dry before storing. I've been doing that for years with all my stuff and never had an issue, including my ancient homelite super 2 and that thing might be older than I am.
Sent from my XT1650 using Tapatalk
Direwolf82 is offline   Reply With QuoteReply With Quote
Old 01-07-2021, 11:50 AM #20
Drobs Drobs is offline
Drobs is a glorious beacon of light Drobs is a glorious beacon of light Drobs is a glorious beacon of light Drobs is a glorious beacon of light Drobs is a glorious beacon of light Drobs is a glorious beacon of light
Get yourself a set of LFD crossbars. Helluva lot cheap than a full roof rack. Can be turned into a full roof rack at a later date.
LFD Off Road - Ruggedized Crossbar 5th Gen
I have 3 of these steel crossbars plus the wind fairing.
I really only use 2 of the 3 bars.
2019 OR - LT285/70R17 Yokohama Geolandar MT, SPC UCA's, BMC, Eibach Pro Truck Lift, Warn VR10 Winch, Warn 100022 Winch Bumper, TRD Skid Plate, Cali Raised Light Bar, Shrockworks Sliders and Skids, LFD Ruggadized Cross Bars, Sprint Booster.
Drobs is offline   Reply With QuoteReply With Quote
Old 01-07-2021, 12:28 PM #21
Hyde802's Avatar
Hyde802 Hyde802 is offline
Real Name: Caleb
Hyde802 has a spectacular aura about Hyde802 has a spectacular aura about
Hyde802's Avatar
Real Name: Caleb
Something like this? SawHaul Complete Kit for Polaris(R)
Those electric saws are pretty cool. Used one a few weeks ago and now Im sold.
92 ExtraCab on 38s: built for go, not for show
88 4runner: Solid axle, doubler, fun stuff
IG: rattlewagon
Its all about the parts you break, and the friends you make.
Hyde802 is offline   Reply With QuoteReply With Quote
Old 01-07-2021, 12:58 PM #22
4Runnergenius 4Runnergenius is offline
Real Name: Chris
4Runnergenius is on a distinguished road
Real Name: Chris
i have a friend who swears by stihl chainsaws, and i have to admit, he may be right about them. i second what others have said just find a carry box for it. just keep things simple and all together.
4Runnergenius is offline   Reply With QuoteReply With Quote
Old 01-11-2021, 06:47 PM #23
jasonbach jasonbach is offline
jasonbach is on a distinguished road
Originally Posted by nb rob View Post
it's not what you asked,
but i carry mine inside the 4runner for a lot of trips. I use the husqvarna powerbox,
and it fits extra fuel, bar oil, ear protection, gloves, files, scrench, and a small axe.
this is the way.
jasonbach is offline   Reply With QuoteReply With Quote
Old 01-14-2021, 01:23 PM #24
Morse34 Morse34 is offline
Morse34 is on a distinguished road
Morse34 is offline   Reply With QuoteReply With Quote
Old 01-28-2021, 04:18 PM #25
Flyer Flyer is offline
Flyer will become famous soon enough
Some good ideas here. If I used a gas chainsaw, I'll fabricate a nice/safe mod for it somewhere outside. I do carry one but I use the battery-powered Milwaukee chainsaw and carry two huge batteries. I have used it many times now and it is phenomenal for a battery powered saw. I also carry a very large hand saw that folds. I have never had to use the hand saw. If in a group, there will be couple of folks carrying gas saws too....usually inside the vehicle. I'd rather not.
2005 V8 4Runner 4X4 SR5, FJ TRD Bilstein Suspension, KO2s
2020 Mercedes GLE450
2014 Wrangler Rubicon, Synergy suspension + 35 MTRs + way too many mods
Flyer is offline   Reply With QuoteReply With Quote
Old 01-29-2021, 07:02 PM #26
Wild Thing's Avatar
Wild Thing Wild Thing is offline
Real Name: Doc
Wild Thing has a spectacular aura about Wild Thing has a spectacular aura about
Wild Thing's Avatar
Real Name: Doc
For the trail? Yep, as well as for hunting and camping trips.
Multiple sized Huskies to choose from for a husky guy.
The one for the road carried in either an aforementioned Husqvarna Powerbox
that one came in or a dedicated long plastic tub. I like the latter better
because my saws're well used and get/remain filthy with oil, grease, wood
and dirt. Best to keep it well contained.
But hell, it's old hat for me...
I have to carry one just to get through my property!
Carrying a Chainsaw-1-19-21-wind-blown-sugar-pine-near-shop-1-jpg
Stock 2008 Driftwood V8 4WD Limited with X-REAS, est. late 2020. Build page to come...
Wild Thing is offline   Reply With QuoteReply With Quote
Old 07-07-2021, 05:39 AM #27
Dan23 Dan23 is offline
Dan23 is on a distinguished road
Love the SawHaul for Polaris or tractors. No easier way to protect chainsaws. You can spend half a day building your own chainsaw carrier for vehicles or just buy a quality unit and get it delivered asap!
Dan23 is offline   Reply With QuoteReply With Quote
Old 07-10-2021, 11:43 AM #28
RichinRidgewood's Avatar
RichinRidgewood RichinRidgewood is offline
RichinRidgewood is a splendid one to behold RichinRidgewood is a splendid one to behold RichinRidgewood is a splendid one to behold RichinRidgewood is a splendid one to behold RichinRidgewood is a splendid one to behold RichinRidgewood is a splendid one to behold RichinRidgewood is a splendid one to behold
Stihl has nice carry cases. I drain the fuel and run my 029 Super and MS180 dry. I keep them in the basement in cases and they don't smell. You could carry a quart of premix in a well sealed steel/aluminum can and only fill the chain saw up when you need to do cutting.
2020 4Runner SR5 Premium 4x4
Barcelona Red, Graphite/Grey
Sunroof
RichinRidgewood is offline   Reply With QuoteReply With Quote
Old 07-21-2021, 10:17 AM #29
CutthroatSlam CutthroatSlam is offline
CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold
Son got me this 18v cordless Milwaukee 16" with 12 amp hour battery for stealth use on trees downed in the river blocking my drift boat. It works quite well. I also have an Echo Timber Wolf 20" for Montana home and a Stihl Farm Boss 20" for the Fullerton home.
Error | DNS Resolution | Northern Tool + Equipment
Carrying a Chainsaw-milwaukee-jpg
CutthroatSlam is offline   Reply With QuoteReply With Quote
Old 07-21-2021, 01:13 PM #30
I'm looking for a bigger electric chainsaw. I brought my older DR battery operated chainsaw for a trail cleanup we did a few months back. It works on small stuff.
We had a guy along with a gas powered Stihl that took care of the big stuff. A wind storm the day before had huge trees blocking the main road where we trail ride.
Carrying a Chainsaw-recovery-gear-jpg
Fun with chainsaw and winch Mick1 5th gen T4Rs 3 09-23-2014 10:24 PM
Carrying a snowblower. 87YOTA 3rd gen T4Rs 13 11-20-2012 12:31 AM
Bloody chainsaw? Sword? Brass nuckles? Sure go on into the US! sharp4runr Off Topic 5 07-27-2005 03:33 PM
