12-13-2018, 06:33 PM
#16
Mine you...i have zero knowledge. Are these portable fridge plug and play? Can i just plug it into my 12V in the back and it will run constantly (while engine on)??
I don’t have a 4runner...but thinking about this for my Sienna...would fit in the “tub” in the back...and i have 12V and 110 in the cargo.
12-19-2018, 09:42 AM
#17
not sure if it's the same problem in the sienna, but in the 5th gen 4Runner the existing 12V plug has enough voltage drop that it will prematurely shutoff fridges and cause issues so most people run a dedicated 12V plug.
in general though yes it's just plug and play
01-30-2019, 09:13 PM
#18
Originally Posted by TEAM_4RUNNER
Sick! We love our CFX50, it has been with us for over 20,000 miles and countless off road and camping trips. Here is a picture of ours and our account is @Team4Rpro on Instagram!
Love the setup! I'm in the market to buy one and I have the same truck. Does your 50 have a freezer and fridge or just fridge? I've been eye balling a 65 or even a 75 but not sure how it will fit. I've only leaned towards a 75 because it has a true fridge and freezer!
01-31-2019, 03:10 PM
#19
Real Name: Ryan B
Real Name: Ryan B
Originally Posted by Trailboundt4r
Ive borrowed a dometic fridge before and its awesome! can't wait to get one of my own someday. Once i figure out how to post photos I will share one!
I had the photo issue too, now that Photobucket is defunct for hosting.
If you post the photos into your User CP (top left tab) "album(s)" here, it makes it super easy because it gives you an [IMG] copy and paste-able link that you can then post into a comment to use the picture.
Make sense?
02-05-2019, 11:11 AM
#20
I’m curious of the 65-75 as well. I love the 75 for the feature of a True dual zone fridge/freezer but I just don’t know how it will fit in a 2017? 75 seems really big when I saw it in person. Not sure how much breathing room this unit needs? Any input or photos of a 65 and or a 75 in 5th gen would be awesome.
03-08-2019, 02:16 PM
#21
Amazon having the CFX50W on sale right now! I just ordered one for $858.64.
08-27-2019, 01:31 PM
#22
Hey
@ Dometic
just bought the CFX75 on the Labor Day sale...do you know if the Slide will fit in the 5th Gen 4Runner by chance?
thanks!
Kansas City!!! ...2016 Trail Ed Premium w/ KDSS, Toytec Boss Performance suspension, 285 Nitto Ridge Grapplers, C4 Armor, RCI skids, ExtremeLED bars, Baja Squadrons, Frontrunner Rack, Dobinsons Snorkle and Springs, Magnuson Supercharger. Build out by @AdventureMotorsKC
Instagram: @kcSNOWrunner
03-06-2020, 11:20 PM
#23
Real Name: JM
Real Name: JM
Bought a stock 02 4runner about a year ago when I got to Germany, hoping to start building it this summer. Been looking at installing a fridge and Dometic is what's caught my attention the most. The cfx 35w is what I'm planning on getting, for now at least, may go bigger once state side and the truck gets used more for longer trips.
Are the fridges both 110 and 220? I do plan to ship the truck stateside once I'm done in Germany, so would it be a problem? I plan on running a dedicated 12v to the rear for the fridge anyways.
Thanks
03-07-2020, 06:48 PM
#24
Cfx3 35
Just received the latest model CFX3 35. Will be installing it next week in my 5th gen on a platform I built. I’ll be using the DFG Offroad fridge slide.
I’ve been testing the fridge the last 3 days. I didn’t want to go through the hassle of a dual battery setup, so I have it plugged into a Jackery 500 L-ion generator which I will plug into the 12 volt outlet in the back when driving, and when camping, I bought a Goal Zero Boulder 100 suitcase solar panel to charge the Jackery while camping.
I charged the Jackery to full capacity and ran the Dometic (empty) inside my garage for 48 hours and used 70% of the generator’s capacity.
I expect the fridge to do even better when it contains food and drink and is pre chilled, but that will be offset by opening the fridge several times while camping.
Once I get the slide installed on the platform, I’ll post some pictures of the setup.
04-04-2020, 05:08 PM
#25
Can these be run straight off the battery or is a dual battery setup necessary? Or maybe just a goal zero?
04-04-2020, 05:20 PM
#26
Read the post directly above yours. My Jackery 500 lithium is basically the same as the Goal Zero lithium, but cheaper by $100. Got mine for $425 when they were on sale about a month ago. Works great with my Dometic and no need to wire up a second battery or run dedicated 12 volt to the back. I just didn’t want the hassle of doing either of those things, plus...I can use the Jackery for other things if I want to, and I also charge it with a solar panel as well.
04-05-2020, 05:48 PM
#27
I'm running a Dometic 63qt wired directly to the battery. Ran the wiring through the firewall grommet, under the driver side floor trim and to the back to power the fridge.
2017 T4R TRD Pro Cement - Dobinsons 2/1" (300/599), IMS 700/701, Air Lift 1000 air bags (60804), Pelfreybilt hidden winch mount, Warn VR8 w/ Amsteel synth, 2021 ORP LED headlights, DD SS3 Sport yellow fogs, CBI steel skid plates, Rough Country 20" LED bar, Gobi stealth no rise w/ ladder, ARTEC sliders, ARB 63qt fridge, Canvasback liners, homemade spare tire hitch carrier, ARB single air compressor w/ Slee mount, bronze TRD Pro wheels
04-08-2020, 03:25 PM
#28
I run the CC40 connected directly to the 12V outlet in the back. No worries about voltage drop or draining the battery as it draws only a small amount of power and shuts off when the ignition is off. Its as foolproof as you can get. It opens to the side so you can easily get stuff out without the lid closing on you.
2005 Blue SR5 v8
3" suspension lift, 1" body lift, 315's, rear Elocker, on-board air system, slider air tanks, full skid plates, front Demello bumper, rear HMF plate/tube bumper, rear 9000lb hidden winch, front 10000lb winch, dual electric fans (in cab adjustable temp), rock lights, 25W LED projector lights.
04-14-2020, 06:08 PM
#29
@ BlakeA
have you run this battery setup much as of yet? I was contemplating the same approach, but using my PLB40 instead. I removed that 12V outlet to get a look, and the wires that run into it have got to be 18 AWG (pretty small). Has me a little worried about pulling ~8 amps continuously during a charge...though it looks like your Jackery 500 will only pull 3.6 amps, so maybe not as big a concern for you.
Thanks!
2016 TE (w/ KDSS) - Bilstein 6112/5160 w/ B12 1.5" - Icon UCAs w/ Delta Joint - BFG A/T KO2 285s
04-16-2020, 09:20 AM
#30
Originally Posted by esteban008
@ BlakeA
Thanks!
Actually, I have NOT had a chance to run this system for any length of time, other than testing. I may not get a chance to until July. Before I bought this setup, I watch some YouTube videos where some people had run similar setups though, so I’m reasonably confident it should work fine.
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
