Old 08-07-2018, 09:44 PM #1
Inv4drZm's Avatar
Inv4drZm Inv4drZm is offline
Inv4drZm's Avatar
Custom Fuel Tank ?'s
Hey everybody, looking to replace my OEM 23 gallon fuel tank with another tank under the cargo area for belly clearance and a 4-link setup in the future.
Just wondering what's the easiest way to do this. If I get a custom tank made, is it possible to reuse the factory fuel pump/sender as long as the new tank is the same internal height? I think the biggest issue with this is mounting/sealing the pump unit on the new tank, therefore using the same threads for the bung. Are there any other problems I might run into? I can buy a tank and pump assembly on ebay for pretty cheap to get all my measurements and sell them afterward.
I have seen where 3rd gen guys swap to a Ford tank (18 gallons) but they use an aftermarket fuel gauge. I would prefer not to do this as I think my idea should work well, and I can have a custom sized tank to fit my 4th gen (~23 gallons), it will just be more expensive.
What do you think?
Inv4drZm is offline   Reply With QuoteReply With Quote
Old 08-08-2018, 04:26 PM #2
Inv4drZm's Avatar
Inv4drZm's Avatar
OK, I found this fuel gauge interface module which I think is programmable to match up ohm readings between the stock fuel gauge and any sender.
https://www.summitracing.com/parts/cin-sn34
Thinking about fuel tanks from Boyd's welding.
Universal Aluminum Gas and Diesel Fuel Tanks
Old 08-08-2018, 10:09 PM #3
BlairB's Avatar
BlairB BlairB is offline
Real Name: Blair
BlairB will become famous soon enough
BlairB's Avatar
Real Name: Blair
Can't add much, but I am curious to see what you discover. If you find someone that can make a custom tank that fits where the factory spare sits, I bet you would have a fair number of other people who would also want to pick one up. I know I would love to add one as a 2nd tank so I can ditch the jerry cans.
2008 4Runner Sport Edition 4WD V6- Long Travel, Camping Rig Build Thread
2023 Lexus LX600 F Sport- Daily Driver
2023 Highlander Hybrid Limited- Wife Daily Driver
BlairB is offline   Reply With QuoteReply With Quote
Old 07-05-2019, 05:18 PM #4
fryingmonkey fryingmonkey is offline
fryingmonkey is on a distinguished road
I've been researching this for a while and haven't come up with anything. Any revelations?
fryingmonkey is offline   Reply With QuoteReply With Quote
Old 11-23-2020, 09:09 PM #5
Inv4drZm's Avatar
Inv4drZm's Avatar
Been researching here and there.
Easiest swap would be to the FJ fuel tank but lose some capacity. 19 vs 23 gallons. I have a 1.5" body lift, and once I 3-link it I could mount it above the frame rail a decent amount. FJ tank has a built-in plastic skid plate too, which is light weight and strong enough especially with it mounted so high.
I removed the tank on my Tundra, and learned a little about some of the connections and routings, and it doesn't seem too tricky to build a tank from scratch either, using a factory sender/pump unit. Not sure that is necessary though like I said the FJ tank should be plug and play hardest part will be mounting it. And then possibly fabricate a secondary tank behind the axle which feeds into the main tank with the flip of a switch. Would only have to hold 6 or 10 gallons.
Old 11-23-2020, 10:14 PM #6
rdruss's Avatar
rdruss rdruss is offline
Real Name: Ron
rdruss's Avatar
Real Name: Ron
Check out dirtco's thread in 3rd gen. He added a tank and has some pictures and good discussion. His is a HIGHLY modified 3rd gen to say the least!
Old 02-14-2021, 12:45 PM #7
Eltigreblanco Eltigreblanco is offline
Eltigreblanco is on a distinguished road
I'd love a larger tank
Eltigreblanco is offline   Reply With QuoteReply With Quote
Replace Fuel Pump - Drop Fuel Tank? Rock_Rat 3rd gen T4Rs 11 12-17-2023 05:33 PM
Custom gas tank skid? Lindenwood 3rd gen T4Rs 8 04-05-2018 02:13 AM
Fuel tank or Fuel pump problem? TwoToneT4R 3rd gen T4Rs 6 11-30-2017 04:18 PM
97 4Runner fuel tank building pressure/ wont take fuel Yotaoffroad27 3rd gen T4Rs 4 10-06-2015 10:34 AM
5th gen, tank shield and fuel tank oibdeke For Sale: T4R Items 0 11-04-2011 03:11 PM
