Originally Posted by fryingmonkey
I've been researching this for a while and haven't come up with anything. Any revelations?
Been researching here and there.
Easiest swap would be to the FJ fuel tank but lose some capacity. 19 vs 23 gallons. I have a 1.5" body lift, and once I 3-link it I could mount it above the frame rail a decent amount. FJ tank has a built-in plastic skid plate too, which is light weight and strong enough especially with it mounted so high.
I removed the tank on my Tundra, and learned a little about some of the connections and routings, and it doesn't seem too tricky to build a tank from scratch either, using a factory sender/pump unit. Not sure that is necessary though like I said the FJ tank should be plug and play hardest part will be mounting it. And then possibly fabricate a secondary tank behind the axle which feeds into the main tank with the flip of a switch. Would only have to hold 6 or 10 gallons.
2005 4R Sport 4WD
"The last of the V8s!" - Custom TIG'd SS Dual Exhaust - King 2.5" +2 LT. - ARB Front & Rear - 37's - Dana 60 -
Build Thread
1977 Celica Liftback - LFX Swap -
Build Thread
