Old 05-17-2019, 10:05 PM #1
smakdatt smakdatt is offline
smakdatt is on a distinguished road
BAJA Design lights brighter with provided switch....
Not sure where to post this but i found out something today when working on my car lights.
I have a pair of BAJA design squadron R lights and when i use it with the provided switch, my lights are noticeably brighter.
When i hooked this light to use with an Air On Board switch, the light are dimmer. Both uses the same fuse. Not sure why.
This is what the specs on BAJA lights
Squadron-R Pro, Pair Wide Cornering, Amber
Wattage/Amps: 40W / 2.90A
Lumens: 4,900 Utilizing 4 Cree LEDs
Air On Board switch
AIR ON BOARD
12 VOLT
3 AMP
uses a 15 AMP fuse.
Anyone with electrical knowledge please chime in and explain to us why in detail.. I don't want to spend money buying a switch that would make my lights dimmer.
smakdatt is offline   Reply With QuoteReply With Quote
Old 05-18-2019, 11:46 AM #2
mk3--'s Avatar
mk3-- mk3-- is offline
mk3-- is on a distinguished road
mk3--'s Avatar
Resistance. If the switch adds any resistance to the circuit then the voltage to the lights will be lower and so will the brightness.
If you have an ohm meter you can measure across the switch contacts and compare.
mk3-- is offline   Reply With QuoteReply With Quote
Old 05-22-2019, 12:35 PM #3
BackOff's Avatar
BackOff BackOff is offline
Real Name: Derek
BackOff is a jewel in the rough BackOff is a jewel in the rough BackOff is a jewel in the rough BackOff is a jewel in the rough
BackOff's Avatar
Real Name: Derek
No relay?
2004 T4R 4x4 SR5 v6
Some modifications.
Black-N-Blue
BackOff is offline   Reply With QuoteReply With Quote
Old 05-22-2019, 12:43 PM #4
Bumbo's Avatar
Bumbo Bumbo is offline
Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of
Bumbo's Avatar
If the operating current is moving though the switch… then you would be subject to resistance & voltage drop associated with it.
That said, if the operating current is passing through a relay, the switch would have zero effect on your lighting output.
Another thing to note… if you are using passing the current though the switch, your switch is now the fuse, not your 15A fuse. Check the switch for heat. I don’t know what the lights draw, but if you are exceeding the current rating, it’s only a matter of time until you have a melted mess to deal with.
Old 05-23-2019, 03:13 PM #5
golfbuddy's Avatar
golfbuddy golfbuddy is offline
golfbuddy is on a distinguished road
golfbuddy's Avatar
Originally Posted by BackOff View Post
No relay?
This is the real question.
golfbuddy is offline   Reply With QuoteReply With Quote
Old 05-23-2019, 03:53 PM #6
Dillusion Dillusion is offline
Dillusion is a glorious beacon of light Dillusion is a glorious beacon of light Dillusion is a glorious beacon of light Dillusion is a glorious beacon of light Dillusion is a glorious beacon of light
I'm guessing no.
2018 TRD OFF ROAD
My Build
Dillusion is offline   Reply With QuoteReply With Quote
Old 05-23-2019, 05:13 PM #7
tcbaklash's Avatar
tcbaklash tcbaklash is offline
tcbaklash is on a distinguished road
tcbaklash's Avatar
Just replying to give a layman's explanation to why this is happening...
Yeah pretty much your switch has a higher electrical resistance than the one provided with the lights, it's acting as a load, i.e. it is consuming power. Your light is also a load because it also consumes power. Putting more than one load in series configuration drops the amount of voltage that other loads can use. Your switch is sapping voltage in the circuit, and the amount of voltage that your lights can use is now lower and as a result they are dim.
You can avoid this by putting your light and switch in parallel configuration: Using a relay.
It's more work but you get more life out of your switch too.
'00 4Runner SR5 (242,100 miles)
3" Toytec/Bilstein lift, 285/75r16 BFG KO2s
'16 Ford Fiesta ST, pushing more boost than I should be
tcbaklash is offline   Reply With QuoteReply With Quote
Old 05-23-2019, 06:57 PM #8
And possibly not cause a fire if you switch is not rated for it.
2018 TRD OFF ROAD
My Build
Old 05-26-2019, 08:34 PM #9
fourwd1's Avatar
fourwd1 fourwd1 is offline
Moderator
Real Name: The Chosen One
fourwd1 is just really nice fourwd1 is just really nice fourwd1 is just really nice fourwd1 is just really nice
Moderator
fourwd1's Avatar
2 lights that draw 2.90A each = 5.8A and your switch is rated 3A, again assuming you are not using a relay.
It's that simple.
'89 4Runner SR5 - stock
fourwd1 is offline   Reply With QuoteReply With Quote
Old 05-26-2019, 09:53 PM #10
Dropzone's Avatar
Dropzone Dropzone is offline
Dropzone is a jewel in the rough Dropzone is a jewel in the rough Dropzone is a jewel in the rough
Dropzone's Avatar
Ohm's law
google Ohm's Law
and multiply the light ratings x2
like foudwd1 said
the wiring your use will also impact the lights.
you spent a bunch of money on quality lights, why cheap out on a crap switch??
Air On Board switch
AIR ON BOARD
12 VOLT
3 AMP
uses a 15 AMP fuse.
BAJA Design lights brighter with provided switch....-ohms-law-wheel-8-jpg
1994 4Runner AKA: Project Recycle
@503dropzone on IG
Dropzone is offline   Reply With QuoteReply With Quote
air , baja , board , lights , switch
Baja Designs Offroad LED Lights Get Brighter TotalAutomotiveLV Total Automotive Performance 3 03-03-2019 06:01 PM
Other options then Baja Design lights white4run General Discussions 1 08-21-2017 11:48 AM
Baja Design fog replacement kit MTN4RNR 5th gen T4Rs 25 02-04-2017 12:58 AM
Brighter Reverse Lights bgmac 3rd gen T4Rs 49 12-08-2011 09:51 AM
