Not sure where to post this but i found out something today when working on my car lights.
I have a pair of BAJA design squadron R lights and when i use it with the provided switch, my lights are noticeably brighter.
When i hooked this light to use with an Air On Board switch, the light are dimmer. Both uses the same fuse. Not sure why.
This is what the specs on BAJA lights
Squadron-R Pro, Pair Wide Cornering, Amber
Wattage/Amps: 40W / 2.90A
Lumens: 4,900 Utilizing 4 Cree LEDs
Air On Board switch
AIR ON BOARD
12 VOLT
3 AMP
uses a 15 AMP fuse.
Anyone with electrical knowledge please chime in and explain to us why in detail.. I don't want to spend money buying a switch that would make my lights dimmer.
