Old 05-18-2019, 12:47 AM #1
FlannelShanel FlannelShanel is offline
FlannelShanel is on a distinguished road
Leaving Keys Behind...
Hey all,
Looking for suggestions on leaving my keys behind when out fishing, kayaking, running, etc. I’ve enjoyed Ford’s SecuriCode before, where you can lock your keys inside and can re-enter using a keypad code. I’ve seen a couple cheap aftermarket options that are similar, but none look too promising. Also not a fan of the “stash it on a tire” mentality, just personal preference. Thanks in advance for any thoughts!
'15 Barcelona Red Trail. Bilstein 6112 front, 5100 rear, KO2 285/70R17, Method Racing MR305 NV... Open to any and all suggestions!
FlannelShanel is offline   Reply With QuoteReply With Quote
Old 05-18-2019, 07:56 AM #2
txclimber's Avatar
txclimber txclimber is offline
txclimber is on a distinguished road
txclimber's Avatar
https://www.amazon.com/HitchSafe-HS7.../dp/B000I66JEM
2007 4runner SE V8 4WD: OME BP-51, SPC, Scion IM 2016+
2005 4runner SR5 V8 4WD: ICON Stage 1, Total Chaos UCA, Scion T1819 (SOLD )
1986 4Runner 4WD 22-RE: Full Rebuild, LCE Header, Custom Head, Supra AFM
txclimber is offline   Reply With QuoteReply With Quote
Old 05-18-2019, 09:22 AM #3
riceandpho's Avatar
riceandpho riceandpho is offline
riceandpho is a jewel in the rough riceandpho is a jewel in the rough riceandpho is a jewel in the rough riceandpho is a jewel in the rough
riceandpho's Avatar
look into compustar
they have a key pad as a add on.
you can also do the drone setup, where you use your phone as a key fob.
also smart watch too.
i would just put the key fob in a zip lock and make it water resistant enough.
Pioneer DEH-80PRS,Rockford Fosgate T600-2,Hertz ML 1650.3(2 pairs),T400-2,Hertz ML 280.3(2 pairs),T1000-1bdcp,(2)JL Audio 12W6v3, Mechman 240a HO Alternator, Dual Northstar 31m,Borla Dual Exhaust,AFE Magnumforce intake.Enkei WT-4 Michelin Defender LTX 275/55R20. retrofitted S2000 projectors,Philips 85122 White Vision,Morimoto 5Five Ballast.Diode Dynamics SS3 Yellow Fog Sport.2 pairs of Hella Supertones.Full led conversion on interior and exterior.HAWK Talon Rotors and LTS pads F+R,Stoptech stainless steel lines F+R.Bilstein 5100 @0.85, MOOG FJ Springs front,Bilstein B12 36-281824 rear .
riceandpho is offline   Reply With QuoteReply With Quote
Old 05-18-2019, 12:48 PM #4
sharpie223 sharpie223 is offline
sharpie223 is on a distinguished road
I've been planning this as well. What I'm going to do is find a coded key box that screws onto the vehicle for holding the key secure. These are cheap but effective, just a mechanical number code to open. I'm going to mount that under and hidden on a frame member somewhere. Then I'm going to make a sheet metal box that will cover this, held in place by spring clips or similar, and paint it flat black so that it just appears to be part of the car and nothing special.
sharpie223 is offline   Reply With QuoteReply With Quote
Old 05-18-2019, 01:00 PM #5
tk423 tk423 is offline
tk423 is on a distinguished road
I use the Kanulock KeyVault when I go surfing.
KEYVAULT
– Kanulock USA
tk423 is offline   Reply With QuoteReply With Quote
Old 05-18-2019, 03:51 PM #6
Starsky Starsky is offline
Starsky will become famous soon enough
Out here, a lot of surfers leave their keys behind when they're in the water. A lot just use the magnetic holders, but one of the more clever solutions is to use a realtor lock box on the tow hitch or door handle.
Starsky is offline   Reply With QuoteReply With Quote
Old 05-18-2019, 03:57 PM #7
RAD4Runner's Avatar
RAD4Runner RAD4Runner is offline
RAD4Runner has a spectacular aura about RAD4Runner has a spectacular aura about
RAD4Runner's Avatar
How About a Simple Solution? :)
If your truck is too smart to let you use a mechanical key, this simple solution will not help:
1) Leave remote/electronic key/fob hidden inside truck,
2) Wear this surfing, kayaking, diving, mud-running... etc.
86 4Runner, 22R-Eliable, 5-Speed Manual, dlx. WHAT'S YOURS?
If you want us to help from afar please let us see, hear, feel what you're dealing with.
A picture paints a thousand words.
Toyota components are bullet-proof. Issues often arise from poor wiring, assembly and/or maintenance. Suspect those first.
Next only to our senses, the multi-meter is the most important electrical diagnostic tool. Spend $6 at Harbor Freight or $$$ blindly replacing parts.
RAD4Runner is offline   Reply With QuoteReply With Quote
Old 05-19-2019, 10:33 PM #8
mr.walleye mr.walleye is offline
mr.walleye will become famous soon enough
I do the same thing except I use 2 dog tag bead chains.
mr.walleye is offline   Reply With QuoteReply With Quote
Old 05-21-2019, 01:34 PM #9
-E5J-'s Avatar
-E5J- -E5J- is offline
Real Name: J
-E5J- has a spectacular aura about -E5J- has a spectacular aura about
-E5J-'s Avatar
Real Name: J
Originally Posted by FlannelShanel View Post
Hey all,
I put mine in a small dry box, along with my wallet & phone... works very well.
Also, you can use the non-fob valet key if it has to be on you and get wet...
2019 4Runner TRD Pro, Midnight Black Metallic - RCI Sliders & Aluminum skids, WeatherTech Floor mats all around, Toyota wind/bug deflector on hood
2016 4Runner XP, Magnetic Grey Metallic - Sold
2015 4Runner Limited, Classic Silver - Sold
2002 4Runner SR5 Sport Edition, Thunder Cloud Metallic Grey - Sold
-E5J- is offline   Reply With QuoteReply With Quote
Old 05-21-2019, 08:08 PM #10
RAD4Runner's Avatar
RAD4Runner's Avatar
Simple, inexpensive, foolproof solution, right?
Old 05-22-2019, 03:04 PM #11
tcbaklash's Avatar
tcbaklash tcbaklash is offline
tcbaklash is on a distinguished road
tcbaklash's Avatar
I always keep a door key in my wallet. But if you're planning on ditching the wallet too... IMO I would just recommend hiding it in the undercarriage and securing it with something. Combo lockboxes seem like a cool idea until you flood them with muddy water and you have to open them with a cut-off wheel (speaking from experience). They're also easy to lockpick.
I wouldn't
Information on opening them is super available
'00 4Runner SR5 (242,100 miles)
3" Toytec/Bilstein lift, 285/75r16 BFG KO2s
'16 Ford Fiesta ST, pushing more boost than I should be
tcbaklash is offline   Reply With QuoteReply With Quote
Old 05-22-2019, 03:33 PM #12
JAXJeremy's Avatar
JAXJeremy JAXJeremy is offline
Real Name: Jeremy
JAXJeremy has a spectacular aura about JAXJeremy has a spectacular aura about JAXJeremy has a spectacular aura about
JAXJeremy's Avatar
Real Name: Jeremy
that's one of the things I miss most about my Ford..Loved that keypad..would drive my wife nuts when I left the keys in the car when we went out..I agree that something magnetic you can put underneath seems like the best solution..
'18 SR5 4WD, magnetic gray metallic, stock, RCI front skid, LFD cross bars, Pedal Commander, Accessorides Remote Start.
JAXJeremy is offline   Reply With QuoteReply With Quote
Old 05-22-2019, 04:09 PM #13
nb rob's Avatar
nb rob nb rob is offline
nb rob is just really nice nb rob is just really nice nb rob is just really nice nb rob is just really nice nb rob is just really nice
nb rob's Avatar
I have also envied the ford keypad for ages, but I'm not about to buy a ford for just that (although its the best reason)
My 4runner is a fishing machine, and I'm living in salmon flyfishing heaven thanks to geoarbitrage. I've been using RAD4Runner's solution for 15 years now, with several different vehicles. FOB is stashed safely away in the vehicle.
On some dicey trips, I've stashed a spare key in the endcap of the OEM roof rack, and told the rest of the members of my group where it is, just in case.
I remember the guys on the nissan titan forum were buying an aftermarket keypad and putting inside the gastank door. I sure wish that were available to us. In the meanwhile, the valet key on a string hasn't let me down once. Maybe one day a stout mosquito will fly off with it
_______________________
2015 trail edition premium w/ KDSS
OPOR sliders ● 255/75/17 firestone destination AT ●
King coilovers and shocks w/ compression adjust ● Dirtking UCAs ● Icon 2" rear springs
nb rob is offline   Reply With QuoteReply With Quote
Old 05-23-2019, 09:26 PM #14
pDubs's Avatar
pDubs pDubs is offline
pDubs is a glorious beacon of light pDubs is a glorious beacon of light pDubs is a glorious beacon of light pDubs is a glorious beacon of light pDubs is a glorious beacon of light
pDubs's Avatar
When I mountain bike I just lock the truck, then flip open the trailer plug and hang keys from there.
2014 SR5P
5100s w/Dobinsons 302/505 springs - SCS F5s - 285/70 Wildpeak AT3W - Prinsu Full Length Rack - Smittybilt Gen 2 RTT - Full RCI skids - RSG sliders - Pedal Commander - Gobi ladder - Rago brackets and 32" LED light bar- TSO TRD Pro grille - 5k HIDs - ARB diff breather - other small stuff
pDubs is offline   Reply With QuoteReply With Quote
Old 05-27-2019, 04:53 AM #15
originalg00kster's Avatar
originalg00kster originalg00kster is offline
originalg00kster is a jewel in the rough originalg00kster is a jewel in the rough originalg00kster is a jewel in the rough
I bet that stout mosquito lives in Florida!
originalg00kster is offline   Reply With QuoteReply With Quote
i’ve , keys , leaving , promising , similar
Programming instructions for blank Transponder keys/chip keys for OEM toyota ignition infamousRNR 3rd gen T4Rs 26 11-02-2023 09:24 PM
Who's leaving the family? my92t4r 3rd gen T4Rs 1 11-19-2014 06:45 PM
LEAVING california... bhenry92 Off Topic 30 08-09-2013 04:10 PM
Leaving 5th gen...hello 4th gen! NikonShooter 5th gen T4Rs 16 10-10-2011 10:16 AM
Leaving mud on car bad? eskimochaos 4th Gen T4Rs 5 04-16-2009 06:24 PM
