06-03-2019, 08:23 PM
I have a spider living in my 4runner
The wife and I went to leave today and we found a full spider web was built in the passenger floor from the seat to the door. I am not really sure what to do. She wants me to use Raid but I'm not to keen on filling the truck with Raid. Any other ideas?
06-03-2019, 08:26 PM
Real Name: George
Real Name: George
Fire. Lots and lots of fire...
'17 EssAre5Pee - Barcelona Red
Bilstein 5100's (fr-0) ~ Dobinson C59-302 front (2.5"), C59-505 rear (1.5") ~ JBA UCA's
Cooper Discoverer A/T3's - LT265/70R17 ~ Auxbeam 32", Rago brackets
XD HID's (low) LED's (high), LED swap in and out ~ Rear diff routed along fuel filler pipe ~ LFD 3/4 steel roof rack
RVA Toyota Trucks
06-03-2019, 08:39 PM
You mean hairspray and a lighter?
06-03-2019, 08:40 PM
Real Name: Alec
Real Name: Alec
Agreed, Burn it to the ground, Claim insurance get a new one.
Orrrrr Bug Bomb it if you have a second car, then be sure to leave the windows down for a while, idk Personally I'd just sell the car haha
Galactic Mica '04 V8 Sport Edition 4x4 110K+ Miles
Airbox Charcoal Filter Mod, Summit Racing 3 inch Electric Exhaust Cut out
265/70R17 Goodyear A/T's Load Range E, Fumoto Oil Drain Plug
06-03-2019, 09:23 PM
On the bright side, it's probably not a camel spider, so there's that.
2019 TRD Off Road w/KDSS in silver. Dobinsons IMS59-50700 & C59-314 front (coil seats lowered 1/2"), IMS59-50705 & C59-505 rear; Dobinsons diff drop; Ironman UCAs; Eimkeith PCK, Ironman adjustable panhard rod, and Treaty Oak KDSS spacers; Toyo Open Country A/T III 255/80R17; C4 Fab skids & Shrockworks sliders; Durobumps front & rear.
06-03-2019, 10:06 PM
Mr insurance guy, it started on a bright sunny day.....
I think tomorrow is serious vacuum day. I went back in and there was no restart of a web. Maybe the heat affected it. I will probably spritz some Raid under the seat.
06-03-2019, 10:15 PM
Nuke it from orbit. It's the only way to be sure.
06-03-2019, 10:22 PM
Real Name: Alec
Real Name: Alec
I'll dial up North Korea
06-03-2019, 11:29 PM
I basically did a combo of 90 PSI air compressor into every crevice, vent, gap, and underseat area; followed by vacuuming; followed by simultaneously cooking the interior on high heat while driving 80 mph down the freeway and alternating putting down various windows to use the negative pressure to suck out hidden particles - and spiders. Worked for me.
"How rare that we can point ourselves inevitably west and go, go, go. Run out the highway and the hills. Slide our fingertips over the creases and the valleys of the impossibility that is America. You can’t grasp its vastness from a plane. It’s diversity from a map. You have to put your feet on the ground. Your hands in the dirt." - Zach Bowman
Photos, mods & trip reports
06-03-2019, 11:35 PM
Real Name: Skip
Real Name: Skip
Just let the spider live in the 4runner, you will never have to worry about any other bugs in your ride!!
2004 Limited V8
06-03-2019, 11:55 PM
Use Wildfire
2011 Starfire Pearl GX460 stock base ;)
2012 Blizzard Pearl SR5 | 285 Toyo OC AT3 | Level 8 Slam | YotaWerx ActiveDuty | Die Hard AGM w/ArcLightLeds V2 Booster | Borla 40665 | URD Y & MAF Cal TRD | C4 Center LP | Maxbore 2mm TB "loaner from my boy Dave" | X20 10k Factor55 | Shrockworks Armory | RCI LCA skids | TC Gusset | LFD Offroad 7/8 | TJM Airtec dry aFe HPS coupler w/TRD CAI tube | B8 6112 | 650# King | ICON Delta Joint | Fox 2.0 VS| SAW 1.5" |230k|
| 03 DCSB Tacoma OME equipped, +320k Still Truckin |
06-04-2019, 11:58 AM
Real Name: Alec
Real Name: Alec
"Swipter used Wildfire!"
-It's Super Effective-
"Spider Fainted"
"Insurance paid $25,000 to Swipter"
06-04-2019, 02:11 PM
If it makes you feel any better my brother recently bought an almost new used car from a dealer that just so happened to have some sort of pest infestation… either small cockroach or bed bug looking things.
Personally the spider seems like a welcome addition when you contrast the two.
That said, I don’t think I would Raid my car… last few times I had some sort of spider living inside, it just seemed to work itself out over time. That or you can release something else inside the car to eat it… here is a list of suggestions.
9 Natural Predators That Control Spiders
06-04-2019, 02:39 PM
Real Name: Who's asking?
"Spider Fainted"
Lol
"Swipter's 4runner is in actual fire"
"Swipter tries to claim insurance."\
"His rep finds this thread and thinks he is committing insurance fraud."
On a side note I wouldn't use raid. you will have to inhale fumes. I would just try to find said spider and kill it. If it is just one spider that shouldn't be too bad.
2005 4RUNNER V8 4WD -- Sony XAV-AX100 -- Bilstein 5100 shocks -- Wheelers T1/T12 Springs -- 5th Gen Wheels -- 2006-09 Tail Light Conversion -- AFE Pro Dry S -- X2Power 24f -- ScanGauge II...
06-04-2019, 03:08 PM
Fogger! (Bug Bomb)
Mark
04 V8 SE, RST Twin stick conversion. 4x4 Labs rear bumper, SW Sliders & Bullbar, ARB Locked F&R, 5.39’s, Smittybilt 10,000lb winch, 1.5 4Crawler BL, Flowmaster, CB and 2m/70cm Ham, Sat. Radio, CO2 system, Lightforce, African Outback Rack, Budbuilt, Front Runner RTT. Rock Solid Toys Solid axles, Atlas Crawl Case, 40" Cooper STT Pro's on Fuel Anza D116 beadlocks, 5:38 gear set, ADS Coilovers.
