Old 07-11-2019, 01:06 PM #1
rob_dixon's Avatar
rob_dixon rob_dixon is offline
rob_dixon will become famous soon enough
rob_dixon's Avatar
Wiring harness/Relay kits:Does any brand work RE: cheap to $$ Ditch Lights?
Does the wiring harness "brand" really matter when choosing a ditch light?
If I use a brand that is paired with cheapo $12-25 ditch lights, and then later decide to upgrade to something like a Baja or Rigid ditch light, will it cause an issue?
Back in the day monster cable made a fortune on marketing to folks who thought their cables made a noticeable difference, but in this real world case we are talking high heat, voltage, watt matching, relays, and exposure to the elements. Makes my head spin. (Baja design has 8 harnesses listed!)
The kit i bought was only $8 and has a max working current of 15A (180 Watts). But the baja designs light only runs. 20 Watts/1.4 Amps....so in thoery its not an issue.
Thoughts?
rob_dixon is offline   Reply With QuoteReply With Quote
Old 07-12-2019, 10:58 AM #2
riceandpho's Avatar
riceandpho riceandpho is offline
riceandpho is a jewel in the rough riceandpho is a jewel in the rough riceandpho is a jewel in the rough riceandpho is a jewel in the rough
riceandpho's Avatar
if you can read how relay works, you can create your own relay harness, 14 gauge wire will be enough. usually a 20 amp main fuse is enough.
if you want a simple harness, just spend the 35-40 for the standard 9006 harness you get from lightwerkz or theretrofitsource. im still using there relay harness for my hid setup and have never failed. the lighted up relay which is from 2008 or 09 era.
Pioneer DEH-80PRS,Rockford Fosgate T600-2,Hertz ML 1650.3(2 pairs),T400-2,Hertz ML 280.3(2 pairs),T1000-1bdcp,(2)JL Audio 12W6v3, Mechman 240a HO Alternator, Dual Northstar 31m,Borla Dual Exhaust,AFE Magnumforce intake.Enkei WT-4 Michelin Defender LTX 275/55R20. retrofitted S2000 projectors,Philips 85122 White Vision,Morimoto 5Five Ballast.Diode Dynamics SS3 Yellow Fog Sport.2 pairs of Hella Supertones.Full led conversion on interior and exterior.HAWK Talon Rotors and LTS pads F+R,Stoptech stainless steel lines F+R.Bilstein 5100 @0.85, MOOG FJ Springs front,Bilstein B12 36-281824 rear .
riceandpho is offline   Reply With QuoteReply With Quote
baja , brand , ditch , light , made
5 PIN Relay wiring harness 4wordSOUL 4th Gen T4Rs 0 01-24-2017 12:47 PM
Cheap 4Runner that Needs Wiring Harness Koko4 3rd gen T4Rs 20 03-21-2015 11:10 AM
FT: 96-98 Tailgate Window Relay/Wiring Harness Schnaars For Sale: T4R Items 2 05-10-2014 12:48 AM
WTB: 99-00 Tailgate Wiring Harness/Window Relay Unit Schnaars Want to Buy/Trade 2 05-09-2014 12:08 AM
FS: Non-DRL Flasher Relay w/ Wiring Harness Pennywise Classifieds - buy & sell (no commercial ads please) 3 02-20-2006 06:22 PM
