Old 08-29-2019, 11:43 PM #1
nick_rabbo's Avatar
nick_rabbo nick_rabbo is offline
nick_rabbo will become famous soon enough
nick_rabbo's Avatar
Power USB Rocker Switch Options?
What's up forum,
I'm looking to replace one of the blanks in my 4th gen with a usb socket switch. And I'm afraid most people don't realize they need to buy a quality socket if they want their devices to charge quickly.
I have a OnePlus 5 phone and despite it being 2 years old, it charges insanely fast, even by today's standards. That's because the special charging brick that comes with it outputs 5V at 4amps = 20W. Newer phones like the Galaxy Note 10 come with a charger that outputs 15V at 3amps = 45W which is insane.
I don't want to buy a cheap power socket so can someone check me on this cause I'm no electrician? If I were to get one of these usb power sockets like the one pictured below, which outputs 5V at 2.1amps PER PLUG RECEPTACLE, doesn't that mean I'll get 10.5W? Which means charging my OnePlus 5 would take about twice as long as I'm used to since 10.5W is almost half of the 20W I'm used to.
Does anyone know of a socket that actually outputs 4amps or more per receptacle? Or if my thinking here is incorrect, can someone please chime in and help me understand?
Thank you very much.
Sent from my ONEPLUS A5000 using Tapatalk
2005 T4R Sport V8 4WD
nick_rabbo is offline   Reply With QuoteReply With Quote
Old 08-30-2019, 10:51 PM #2
Billxdm Billxdm is offline
Billxdm is on a distinguished road
You are correct on your power(watt) calculation. Power(P)=I*V(current x voltage)
Billxdm is offline   Reply With QuoteReply With Quote
Old 08-30-2019, 10:56 PM #3
nick_rabbo's Avatar
nick_rabbo's Avatar
Thank you for confirming.
So is there some type of limitation when the socket is being fed by a vehicle 12v instead of a home 120v source? Like is that the reason all these sockets being sold on Amazon cant provide higher wattage outputs? The max I'm finding is 5V at 2.4amps which is 12 watts.
Old 08-30-2019, 11:01 PM #4
Seems like its limited by the actual USB technology itself.
How USB Charging Works, or How to Avoid Blowing Up Your Smartphone - ExtremeTech
Old 08-31-2019, 03:08 PM #5
Blu42's Avatar
Blu42 Blu42 is offline
Blu42 is on a distinguished road
Blu42's Avatar
Are you comparing these to the OnePlus Dash charger? If so, I wouldn't.
Using a quality USB cable will be the biggest help with maximizing charging rate. Seriously, two almost identical cables and one may charge at 1.3A while another charges at 500mA.
I make sure any charger I use is at least 2A as these are plentiful now and don't really have an issue with the rate. Check what your device is actually charging at by using the Android app Ampere. This app has helped me weed out bunk cables and charging bricks several times.
If you really wanted the dash charging rates you could always Frankenstein a Dash car charger into a rocker switch. I think you'll be fine with 2A though.
2007 SR5 4WD Driftwood Pearl Totaled 2018
2014 Trail Premium with KDSS - Nautical Blue
Blu42 is offline   Reply With QuoteReply With Quote
oneplus , outputs , power , socket , usb
Rocker Lining options? nwebb01 3rd gen T4Rs 3 07-01-2018 07:52 PM
need rocker switch DED&DED 3rd gen T4Rs 2 12-22-2014 02:54 PM
Contura Rocker Switch T4rman Engines / Suspension / Wheels / Tires / Audio / Accessories 0 02-26-2012 07:33 PM
Air Compressor - Rocker Switch? phillyd2 Engines / Suspension / Wheels / Tires / Audio / Accessories 1 12-08-2011 01:18 AM
missing rocker switch astynx Classic T4Rs 4 01-10-2011 08:31 AM
