Warning/Safety-Light Mount - Above roof rack!
At times for work I need to throw a yellow LED warning light on the roof of my rig ('07 SR5), it has magnetic feet for "easy" mounting. Problem here is that it is basically hidden inside my OEM roofrack/crossbars and rear spoiler.
Does anyone have a source on where I can get a taller light, or either extension feet for this thing (magnetic), or a mount that is somewhat easy to put on/take off for the crossbar?
It needs to go up probably 6-8 inches to be visible over the rear spoiler.
This is not an everyday thing, so the easier the better, I'm not looking for permanent mods or installs. I could engineer something, but I figured I'd ask you fine folks here first. My best two to three hours searching the internet has yielded no suitable results.
Thanks.
2007 SR5 4WD | Front: Bilsteins set at 2.5 | Rear: Bilsteins, Cornfed 2" spacer | 265 70 17 BFG KO2 | 1.25 Wheel Spacers | Sport Headlight swap
