Old 10-25-2019, 09:35 PM #1
Bernardchan96 Bernardchan96 is offline
Real Name: Bernard Chan
Bernardchan96 is on a distinguished road
Rounded Sway bar bushing bolts, tips on removing
I was trying to replace my front sway bar bushings and replace the mounts as well. When trying to remove the mounting bolts, i removed 2/4 no problem with my impact wrench 14mm deep socket, but the other 2 it rounded the bolts pretty bad. Now i just bought some liquid wrench and have sprayed it for a while now and tried with some pliers no luck. Im borrowing some vice grips and channel lock pliers and will try again but is there any other suggestions? Mine is a 05 v8 and i live in canada so it is rusted to shit. I dont have a welder to weld a nut on, would buying an electric heat gun and applying it to the bolt help>? The bolt is a 14 mm and i cant get a 9/16 socket on it either.
Bernardchan96 is offline   Reply With QuoteReply With Quote
Old 10-26-2019, 12:37 AM #2
Narat_524 Narat_524 is offline
Narat_524 will become famous soon enough
without a welder you have two other options off the top of my head, the first being much preferable to the second.
1) get a plumber's torch that runs on propane. Get bolt extractor sockets for that general size of bolt. Get the bolts hot, but not so hot you catch the bushing on fire. Use the extractor socket to the turn the bolt while it's smoking hot just a quarter turn or so. Hit the bolt with Liquid Wrench, let it cool a bit, then twist it the rest of the way out.
2) With a dremel or cutoff tool or grinder, grind some new, smaller flats on the bolts. Pray to the mechanical Gods that they shine upon you. Use your impact bolt-head-rounding device to snap the heads off the rusted bolts because the mechanical Gods despise you. Drink a 6-pack while you ponder every bad decision you've ever made in life. Drill broken bolt with right-hand drill bit, pressing hard to ensure you break the drill bit off in the broken bolt. Drink a 6-pack while pondering if you've ever made a good decision in your life. Using the tiniest left-hand drill bit in your set that you haven't managed to lose or break, yet, attempt to drill into the broken right-hand drill bit while whispering a Detroit shaman chant. After breaking the small drill bit off in the larger drill bit stuck in the broken bolt, drink a 6-pack and ponder the meaning of life and whether it's worth existing at all. Using a cold chisel of improper length to get a good swing at it, attempt to convince the drill bit it wants to leave its new-found home. Good job! Now that you've chipped your cold chisel, gouged the frame, sway bar bracket, and sway bar itself, you can get serious about solving this issue with a sawzall. Drink a 6-pack because you look like you need it. Using the sawzall, remove the sway bar from around the bracket. Consider whether you needed a sway bar in the first place. It's late, so you probably didn't really need it. Replace the bolts you removed so the bracket doesn't rattle. Congratulations, you're done! Drink a 6-pack in celebration!
Narat
2019 TRD ORP, Milestar Patagonia LT295/70R17, Method Trail 701 wheels, King suspension 600 sprgs, Dobinson C59-677V +400 rr sprgs, ECGS 4.56 grs, Frt E-Locker, Coastal Offroad Alu dual swing rear bmpr, CBI Alu frt bumper, SmittyBilt X20 10K Synth, Flatlink E, RCI full steel skids and sliders, DuroBumps, MetalTech RR LCA, Dual 31M/34M Northstar Batts, Blue Sea ML-ACR, LFD Offroad Bat tray, Schrockworks air pump relo brkt, ARB twin comp, Gibson exh, Infinity Component dsh and dr spkrs, Hertz HCX 165 hatch spkrs, 2x Kicker KEY 180.4 DSP amps, Kenwood TM-V71, Cobra 75 WX ST, Midland MXT275, ArcLight LEDs, XenonDepot HID low, LED High, Diode Dynamics Turn-as-Tail, Switchbacks, CaliRaised Ditch light brackets, Rigid SS Ditch lights, Stock OR wheels with 285/70R17 E GY DuraTracs, Custom drawer/sleep platform, Dometic CFX50, More lights and antennas than I can name, beer
Narat_524 is offline   Reply With QuoteReply With Quote
Old 10-26-2019, 10:09 AM #3
Real Name: Skip
AuSeeker is a splendid one to behold AuSeeker is a splendid one to behold AuSeeker is a splendid one to behold AuSeeker is a splendid one to behold AuSeeker is a splendid one to behold AuSeeker is a splendid one to behold
Real Name: Skip
Narat
You sound like you live in the rust belt and have done this before....BUT then ran out of beer or past out, or both!!!
2004 Limited V8
Old 10-27-2019, 09:19 AM #4
Hoser Hoser is offline
Hoser is on a distinguished road
Narat you are a person after my own heart. If you don't get it, drink a beer and think about it. If you do get it, drink a lot more beer and forget about it. All kidding aside, welding a nut on would work the best but due to a rubber bushing that would cause a lot of grief. I use a penetrating oil called Kroil. This stuff is the best I have ever used to free rusted fasteners. Heating with a torch and then using the oil usually works. I worked skilled trades and had to deal with this for 31 years.
Hoser is offline   Reply With QuoteReply With Quote
Old 10-29-2019, 01:40 AM #5
Seymore Butts's Avatar
Seymore Butts Seymore Butts is online now
Seymore Butts will become famous soon enough
I changed these bushings a couple of days ago, and the bolts were all 12mm on my '08. Check your bolts again, they may not be 14mm after all.
Seymore Butts is online now   Reply With QuoteReply With Quote
Old 10-29-2019, 09:34 AM #6
Puerco Puerco is offline
Real Name: Turtle
Puerco is on a distinguished road
Real Name: Turtle
https://www.amazon.com/Maximum-Impac...05298090&psc=1
these will save you a headache, and let you enjoy more beer.
Puerco is offline   Reply With QuoteReply With Quote
Old 10-30-2019, 06:29 AM #7
Do these destroy the bolt head? cause i need to reuuse the bolts for a little while until i find the bolts from toyota
Old 10-31-2019, 02:01 PM #8
pDubs's Avatar
pDubs pDubs is offline
pDubs is a jewel in the rough pDubs is a jewel in the rough pDubs is a jewel in the rough pDubs is a jewel in the rough
pDubs's Avatar
You definitely won't want to reuse these bolts. You should be able to go to home depot or any hardware store and get replacement bolts.
Anti Seize is your friend here with the replacement bolts.
2014 SR5 Premium
5100s w/Dobinsons 302/505 springs - TRD Pro wheels - Prinsu Full Length Rack - 265/70 Falken Wildpeak AT3W - Full RCI skids - RSG sliders - Gobi ladder - Rago brackets and 32" LED light bar- TSO TRD Pro grille - 5k HIDs - ARB diff breather - other small stuff
pDubs is offline   Reply With QuoteReply With Quote
bar , bolts , rounded , sway , wrench
WTB: 03-09 Front sway bar bushing bolts Bernardchan96 Want to Buy/Trade 0 10-21-2019 02:32 PM
Question about sway bar bushing bolts Jimbo03T4R 4th Gen T4Rs 16 12-26-2016 05:48 PM
Sway Bar Bushing Bolts Being Buttholes brianhuntRVA 4th Gen T4Rs 8 06-29-2016 11:09 AM
Removing Rusted/Rounded Head Bolts gergg 3rd gen T4Rs 23 03-23-2016 01:59 PM
Tips on removing driveshaft yoke/flange bolts? Philbert Classic T4Rs 16 10-24-2008 12:25 AM
