Old 11-22-2019, 06:15 PM #1
Ripper238's Avatar
Ripper238 will become famous soon enough
Ripper238's Avatar
Transmission killer advice
As the title says i am a transmission killer, every car i have owned has had a transmission go except for my last car (Mazda 3). My 79 & 82 Buick went through one each, my Dodge caravan went through 3 transmissions, my Acura went through 1 at just under 100k. My Mazda was the first to not have an issue, but i sold it just over 100K.
I don't beat my cars, tow heavy boats or anything, no neutral drops or manual down shifts.
So, what advice can you guys provide that will help me not kill my 2019 4R transmission?
How often should i change the transmission fluid?
Is slightly rolling when putting into gear harmful (I tend to do this sometimes)?
More likely the transmissions in the cars i had sucked, but i want this 4R for well over 300k.
Old 11-22-2019, 06:38 PM #2
LandCruiser's Avatar
LandCruiser LandCruiser is offline
Real Name: Sparky
LandCruiser is a jewel in the rough LandCruiser is a jewel in the rough LandCruiser is a jewel in the rough LandCruiser is a jewel in the rough
Real Name: Sparky
I wouldn't be surprised if a Buick or Dodge broke.
Throw yourself a dip son!
LandCruiser is offline   Reply With QuoteReply With Quote
Old 11-22-2019, 07:21 PM #3
mesooohoppy mesooohoppy is offline
mesooohoppy will become famous soon enough mesooohoppy will become famous soon enough
figure out what bad driving habit(s) is killing your transmissions and stop doing it.
what gear are you starting in from a roll to be shifting? neutral? if so, why are you putting an auto in neutral and shifting back into park when rolling?
99 4runner limited; imperial jade mica
IG: mesooohoppy
mesooohoppy is offline   Reply With QuoteReply With Quote
Old 11-22-2019, 08:30 PM #4
Syr4RinNC is on a distinguished road
A lot of this is technology. 4runner transmissions were likely fail eventually until 2006.
New computer sensors and monitors watch the temperatures and function a lot better. The transmission in your 2019 is tried and true for 13 years without significant issues. You can get plug ins and data to monitor your transmission performance and fluid temp.
The scheduled maintenance recommends changing the transmission fluid every 60k if you're towing or carrying a lot of weight; for standard use no maintenance required
Old 11-22-2019, 08:50 PM #5
Ripper238's Avatar
Ripper238's Avatar
Good question. Its probably just me. But going from reverse to drive there's soo much more of a lag then my last two cars. Even park into drive lags so I find myself ever so slightly moving when I put it into gear.
Sent from my SM-N960U using Tapatalk
Old 11-22-2019, 08:52 PM #6
Ripper238's Avatar
Ripper238's Avatar
I agree. Like another implied not one of my cars with transmission problems was known to have very good transmissions.
Old 11-22-2019, 10:09 PM #7
spartacus's Avatar
spartacus will become famous soon enough spartacus will become famous soon enough
spartacus's Avatar
Heat is the biggest transmission killer. Get a scan gauge and keep an eye on the temps. When off roading when ever possible keep it in 4low and slow.
Old 11-23-2019, 12:27 AM #8
UnderFire's Avatar
UnderFire UnderFire is offline
UnderFire will become famous soon enough UnderFire will become famous soon enough
UnderFire's Avatar
Mid 80s gm were junk, the caravans all have transmission problems. Honda/Acura had troubles with their automatics not lasting for a long time too. I wouldn't be too worried about it.
Sent from my JSN-L23 using Tapatalk
'97 3RZ 5 Speed "FrankenRunner" (Build Thread) - Tundra TRD/5100's/LC 8 Wraps Lift | 1" BL | 4.88's F/R | 35x15 Toyo M/T on 15x10 AR23's | 4WD Conversion | Manual Hub Conversion | NWTI Front Bumper | Tan Interior Conversion | Infiniti QX4 Seat Swap | 99+ Upgrades | OTRATTW Switches| Yakima rack setup | 42" LED Bars F/R | 2x Lightforce Genesis 210 HID's
UnderFire is offline   Reply With QuoteReply With Quote
Old 11-23-2019, 10:49 AM #9
pDubs's Avatar
pDubs pDubs is offline
pDubs is a jewel in the rough pDubs is a jewel in the rough pDubs is a jewel in the rough
pDubs's Avatar
Definitely don't put the truck in drive when you are still rolling backwards from reversing, come to a stop and then put in drive. It's not that hard.
I would say just try and keep the accelerator steady, are you like jerky with the accelerator, making the trans do unpredicted downshifts, then you let off throttle? I grew up only driving manuals and not until my 4th gen 4runner did I own an auto, and I noticed that being more smooth and predictable for the trans helps with smooth shifts.
2014 SR5 Premium
Cornfed 1" front level - TRD Pro wheels - Prinsu Full Length Rack - 265/70 Falken Wildpeak AT3W - 1.25" wheel spacers - Full RCI skids - RSG sliders - Gobi ladder - Rago brackets and 32" LED light bar- TSO TRD Pro grille - 5k HIDs - ARB diff breather - other small stuff
pDubs is offline   Reply With QuoteReply With Quote
Old 11-23-2019, 11:15 AM #10
Ripper238's Avatar
Ripper238's Avatar
I will definitely put more effort into slowing down my reverse to drive transitions. Besides that i am pretty consistent with the accelerator. Its just the lag from reverse to drive or park to drive that's so darn slow relative to all my other cars.
Getting to know my 4R has been interesting with its odd transmission, but if its reliable ill take any oddities and work with them.
Old 11-23-2019, 11:39 AM #11
Cranberry's Avatar
Cranberry Cranberry is offline
Cranberry is on a distinguished road
Cranberry's Avatar
just throwing it out there but I run an OBDii wireless bluetooth reader I got off amazon for $10 and connect it wirelessly to an app I paid for called Dash Command. I can wirelessly monitor every sensor in the vehicle when on road trips or hitting trails. Helps keep an eye on the trans temp or oil pressures etc... in total I think I was into the reader and app for under $30 and it works better then anything else iv tried, plus no wires to run through the dash!
2019 4Runner TRD Off Road / Bilstein 5100 Lift 2.5 F 1.5 R / TRD Pro Front Skid Plate / BFG KO2's 275/70/17R / Rhino Rack Pioneer SX Roof Rack / N-Fab Nerf Bars / Yellow Lamin-X Fog / ARB 12V Compressor
Cranberry is offline   Reply With QuoteReply With Quote
Old 11-25-2019, 12:21 PM #12
pDubs's Avatar
pDubs's Avatar
Link to Amazon?
2014 SR5 Premium
Old 11-25-2019, 09:57 PM #13
mteolus's Avatar
mteolus mteolus is offline
mteolus is just really nice mteolus is just really nice mteolus is just really nice mteolus is just really nice
mteolus's Avatar
Don't drive in 4h on 4x4 roads, switch it to 4lo.
2017 Off-road Premium w KDSS, moon roof, sliding rear cargo deck,3" Toytech Boss lift, SPC upper control arms, Sonoran Steel High Articulation KDSS Trac/PanHard Bar, RCI sliders, RCI skid plates aluminum including gas tank, C4 Fab diff skid plate, SCS Ray 10 Wheels Matte Gray, 285/70R17 BFG KO2 C load RWL, Cali Raised LED 3x2 fog-light pods, Lock'r Down EXxtreme console safe with electronic lock, Auto Heat Shield all windows, Raingler rear cargo net, Canvasback rear covers, LFD Off-Road cross bars aluminum, wind fairing, and Hi-lift jack mounts, Goat Armor.
Old 11-25-2019, 10:59 PM #14
pDubs's Avatar
pDubs's Avatar
What's the reasoning behind this? I drive in 4hi all the time when offroading.
2014 SR5 Premium
Old 11-25-2019, 11:34 PM #15
Ripper238's Avatar
Ripper238's Avatar
I believe the transmission runs hotter in 4 high when 4 low is more appropriate.
100k , cars , killer , transmission , transmissions
Transmission questions need some advice 2010-Runner-Trail Classic T4Rs 2 07-25-2015 10:22 AM
Transmission pan drop advice Rangeroad 3rd gen T4Rs 5 07-13-2013 10:55 AM
Transmission Cooler Advice Recoil Rob 3rd gen T4Rs 10 11-16-2012 06:00 PM
Transmission Flush advice TN22Corps 3rd gen T4Rs 11 06-20-2011 04:08 PM
transmission advice needed please cisco492 Problems & Warranty Issues 2 08-14-2005 06:29 PM
Copyright ©2000 - 2019, vBulletin Solutions Inc.
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Lite) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Copyright © 2019
