Old 12-03-2019, 12:53 AM #1
patkelly4370's Avatar
patkelly4370 patkelly4370 is offline
patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold
Intended aiming of aftermarket lights
So with OEM lights, fog lights are mounted and aimed low and wide and close in, for low speed, low visibility.
Low beams are aimed farther out and a bit more centered, for up to highway speeds.
High beams are focused centered and farther out (and marginally brighter) for highway speeds and no oncoming traffic.
So (being new to offroading) a light bar is mounted high and illuminate the same as low and high beams combined, but much brighter?
And ditch lights are aimed more to the sides and downwards (thus the name)?
Being as they are almost exclusively LED, is the stock alternator (2017 SR5) sufficient to run these lights simultaneously?
Just trying to educate myself here.
patkelly4370 is offline   Reply With QuoteReply With Quote
Old 12-03-2019, 01:02 AM #2
Another semi-related question.
With a light bar, where/how do you run the wire to the inside?
Old 12-05-2019, 09:33 AM #3
UrbanRunner651's Avatar
UrbanRunner651 UrbanRunner651 is offline
Real Name: Newell
UrbanRunner651 will become famous soon enough
Real Name: Newell
Bars and pods can be mounted wherever you like.. lower mounts can be fed through trim, under the hood, along the frame or through any existing pathway you can find. Some people start drilling holes but again it just depends on how clean you want the install to look. The location will dictate/limit how the wiring can be run.
The stock alternator is sufficient to run a few accessories. Some people run a secondary battery to help but that is more for when you start running a fridge cooler, air compressor, etc.. I have a 32" spot/flood in the lower grille on my 08' and a 10" spot in the hood scoop. I also have two 12" subs in the back, an ultragauge and radar and have never noticed any dimming or issues with battery drain with them all on simultaneously.
UrbanRunner651 is offline   Reply With QuoteReply With Quote
Old 12-06-2019, 03:56 PM #4
Cymon's Avatar
Cymon Cymon is offline
Real Name: Chris
Cymon is just really nice Cymon is just really nice Cymon is just really nice Cymon is just really nice
Cymon's Avatar
Real Name: Chris
Here is how I did it. For me I aimed the light bar to intersect with the high beam cutoff, but as you stated in the OP, just much brighter. I installed a combo (spot/flood) light bar so that it also has a wider range than the OEM lights project.
"If I can do It You Can" Behind Grill Light Bar Install - Toyota 4Runner Forum - Largest 4Runner Forum
2015 SR5 Premium 4wd Magnetic Grey w/3rd row: Frontrunner Slimline II 3/4 Rack - Yakima Skybox 16 - Weathertech - 22" Behind Grill Light Bar - TRD Skid w/Full Aluminum RCI Skids - RCI Sliders - Falken AT3 265 SL - Lamin-X - Taxa Cricket
"If I Can Do it You Can" Light Bar Install
ARB Breather Mod
Cymon's Weekend Warrior/MFD Thread
Cymon is offline   Reply With QuoteReply With Quote
Old 12-09-2019, 09:59 PM #5
I've always aimed my lights by real world parameters. Just did it again tonight with the 4runner.
I parked our car, 05 Dodge Magnum, facing a flat wall.
I then parked the 4runner behind it about 5 car-lengths back.
The (OEM) headlight cutoff was higher than the roof of the car. I was blinding everyone I followed. The high beams were useless because they were aimed 15 feet in the air, well above the horizon.
I reaimed the low cutoff to just at the bottom of the Magnums rear window.
Test drove it on our pitch black rural roads.
OEM headlights and I can see much better.
So can everyone else.
Old 12-10-2019, 11:04 AM #6
This thread was for off road lighting, ditch and roof lights.
Guess I got a little off track with my own thread, lol.
aimed , beams , high , lights , low
fog light aiming and new fog/driving lights digphisher Engines / Suspension / Wheels / Tires / Audio / Accessories 54 01-15-2023 03:35 PM
Aftermarket lights for sale in particular tail lights Dirtdiggin Classic T4Rs 1 11-13-2017 10:54 AM
aiming adjusting OEM fog lights '02 t4rain 3rd gen T4Rs 1 12-05-2014 02:31 PM
aftermarket fog lights? 994runna 3rd gen T4Rs 0 09-29-2011 10:01 PM
aftermarket fog lights SilverBullet01 3rd gen T4Rs 14 05-04-2008 10:38 PM
