Originally Posted by patkelly4370
Another semi-related question.
With a light bar, where/how do you run the wire to the inside?
Here is how I did it. For me I aimed the light bar to intersect with the high beam cutoff, but as you stated in the OP, just much brighter. I installed a combo (spot/flood) light bar so that it also has a wider range than the OEM lights project.
"If I can do It You Can" Behind Grill Light Bar Install - Toyota 4Runner Forum - Largest 4Runner Forum
2015 SR5 Premium 4wd Magnetic Grey w/3rd row: Frontrunner Slimline II 3/4 Rack - Yakima Skybox 16 - Weathertech - 22" Behind Grill Light Bar - TRD Skid w/Full Aluminum RCI Skids - RCI Sliders - Falken AT3 265 SL - Lamin-X - Taxa Cricket
"If I Can Do it You Can" Light Bar Install
ARB Breather Mod
Cymon's Weekend Warrior/MFD Thread
