Old 12-10-2019, 09:31 PM #1
Sifrk's Avatar
Sifrk Sifrk is offline
Sifrk is on a distinguished road
Sifrk's Avatar
Defroster not working
Hey!
So I just found out my defroster isn't working. The button on the center console isn't even lighting up. I checked the fuse box in the engine bay. The 30AMP fuse under 'DEF' was fine, and the large square-ish fuse(?) didn't appear to be damaged. I haven't taken out the plastic in the center console yet, so maybe there's a loose connection? Any ideas?
SiFrk
'16 TRDP
Sifrk is offline   Reply With QuoteReply With Quote
Old 12-10-2019, 09:53 PM #2
Dillusion Dillusion is offline
Dillusion is a glorious beacon of light Dillusion is a glorious beacon of light Dillusion is a glorious beacon of light Dillusion is a glorious beacon of light Dillusion is a glorious beacon of light
Bad switch?
Think the squareish fuse you are referring to is a relay.
Can try to swap the relay with another one and see if it works. if not try to by pass the switch.
2018 TRD OFF ROAD
My Build
Dillusion is offline   Reply With QuoteReply With Quote
Old 12-10-2019, 10:05 PM #3
Sifrk's Avatar
Sifrk's Avatar
Originally Posted by Dillusion View Post
Bad switch?
I tried swapping the relay but no luck either. BTW, the night light does come on so there's power to the button.
How do I bypass the switch?
SiFrk
'16 TRDP
Old 12-11-2019, 01:27 PM #4
Pull it off guessing the dash trim needs to come off and I'm assuming it is normally open. Just manually short out the wires.
If that doesn't work need to find a wiring diagram and see where you are losing the power.
2018 TRD OFF ROAD
My Build
Old 12-11-2019, 05:29 PM #5
Sifrk's Avatar
Sifrk's Avatar
I've had the dash off before, but usually any wiring will be attached to a harness. I'll give it a shot anyway. Thanks!
SiFrk
'16 TRDP
Old 12-11-2019, 05:55 PM #6
I've never pulled mine apart but I have to guess that behind the switch should have a plug when you can short the pins when removed.
2018 TRD OFF ROAD
My Build
Old 12-11-2019, 09:36 PM #7
Sifrk's Avatar
Sifrk's Avatar
I'll keep you posted. Probably not going to tackle that till the weekend. I'm surprised I didn't just find a blown fuse. Hate troubleshooting
SiFrk
'16 TRDP
Old 12-12-2019, 01:28 AM #8
El Dusty's Avatar
El Dusty El Dusty is offline
El Dusty has a spectacular aura about El Dusty has a spectacular aura about El Dusty has a spectacular aura about
El Dusty's Avatar
Might sound silly but check that the rear window is rolled up all the way. I believe there is a sensor in the rear window system that stops the defrost circuit. You can easily test the sensor here as the rear window wiper will only run if this sensor is working with the window rolled up. Best of luck.
El Dusty is offline   Reply With QuoteReply With Quote
Old 12-12-2019, 07:38 PM #9
Sifrk's Avatar
Sifrk's Avatar
Sounded silly but that was the fix. Holy crap! I guess that fail safe makes sense??? IDK. Anyway, thanks man!
SiFrk
'16 TRDP
Old 12-19-2019, 06:38 PM #10
nb rob's Avatar
nb rob nb rob is offline
nb rob is just really nice nb rob is just really nice nb rob is just really nice nb rob is just really nice nb rob is just really nice
nb rob's Avatar
that's a weekly thread in the 5th gen section.
Glad you got it to the bottom of it! Free fixes are the best
_______________________
2015 trail edition premium w/ KDSS
OPOR sliders ● 255/75/17 firestone destination AT ●
King coilovers and shocks w/ compression adjust ● Dirtking UCAs ● Icon 2" rear springs
nb rob is offline   Reply With QuoteReply With Quote
Old 12-19-2019, 09:45 PM #11
Sifrk's Avatar
Sifrk's Avatar
Absolutely! Glad the community is willing to help.
I get the reason for the safeguard, but man! an indicator light would be appreciated, Toyota.
SiFrk
'16 TRDP
Old 01-06-2020, 10:59 PM #12
Osborne White's Avatar
Osborne White Osborne White is offline
Osborne White is on a distinguished road
I was really relieved to read this thread...Last week during a hard rain I realized my rear wiper didn't work and while investigating I noted that the rear defroster didn't work and no indicator light..I went to the fuse box and checked the fuses all good..(still don't know where to find a wiring diagram)..I was lost..thought I would try the rear window to see if that worked..was it on the same circuit..rear window worked fine...on the drive home from work the next day I thought I would try the defroster again and MAGIC ......everything worked. Now I know how I fixed my problem....THANK YOU EL Dusty and forum members.
Osborne White is offline   Reply With QuoteReply With Quote
Old 01-28-2020, 07:29 PM #13
KDubb KDubb is offline
Real Name: Ken Shepherd
KDubb is on a distinguished road
Good tip!
I will keep this in mind. My dog loves to lolly gag out that window so it goes up and down a lot.
KDubb is offline   Reply With QuoteReply With Quote
Old 01-07-2022, 05:10 PM #14
Vegg8 Vegg8 is offline
Vegg8 is on a distinguished road
Had the same problem. defroster not working, back window wiper not working. Tried to roll down window then roll it up which fixed the issue.
Vegg8 is offline   Reply With QuoteReply With Quote
Old 01-08-2022, 02:51 PM #15
TRD88 TRD88 is offline
TRD88 is on a distinguished road
For those that don’t know, you can disable the rear window by locking all the windows with the window lockout switch located on the drivers door. However, it would be nice to simply lockout the switch on the center console without having to disable all the windows. Does anyone make something that clips onto the rear window center console switch that prevents the switch from accidentally/unknowingly being activated?
TRD88 is offline   Reply With QuoteReply With Quote
center , console , defroster , fuse , working
Windows defroster not working ToyotaDan 4th Gen T4Rs 14 01-07-2024 04:13 PM
Rear defroster not working fully. johnbyebye 3rd gen T4Rs 3 01-07-2019 02:18 PM
Rear defroster not working tjhaf2007 4th Gen T4Rs 6 02-04-2014 07:39 PM
Rear Defroster not working jpgordon24 Classic T4Rs 9 11-15-2011 11:37 PM
Rear Defroster not working... alchik 3rd gen T4Rs 5 10-21-2009 07:12 PM
