Old 12-21-2019, 06:11 AM #1
SolRayz's Avatar
SolRayz SolRayz is offline
SolRayz is on a distinguished road
SolRayz's Avatar
Valve cover spark plug shaft seal corrosion. Need help with this!
I know this is a 4runner forum, but I'm a desperate 4Runner owner that took my wifes Rav4 to the shop Wed morning for a couple issues and new tires.
They discovered my valve cover leaking and opened it up. And this is what they saw. Has anyone ever seen corrosion and deterioration where the spark plug shaft seals go on the valve cover, on any vehicle ever? Mechanic says this is plastic and cheap construction, but i thought the whole valve cover was aluminum. I've owned to car since 2012 and have meticulously changed the engine oil with Mobile1 Syth every 5K miles and this is a 2005 Rav4 with 82,000 miles on it. The mechanic says its quite brittle. Whats going on here?
Here is link to the pictures in case they don't load in the thread.
Resized-20191220-141518
Resized-20191220-141528
Resized-20191220-141536
Resized-20191220-141547
Resized-20191220-141553
Resized-20191220-141602
Resized-20191220-141608
upload image
-----Marc-----
2003 V8 Limited 4WD
SolRayz is offline   Reply With QuoteReply With Quote
Old 12-21-2019, 03:44 PM #2
rdruss's Avatar
rdruss rdruss is offline
Real Name: Ron
rdruss's Avatar
Real Name: Ron
I'm assuming you took vehicle to a non-Toyota dealer. I would certainly make Toyota aware of this situation for their input and possible cause/solution.
Maybe they are already aware and have a solution.
Old 01-03-2020, 10:56 AM #3
JohnathanSullivan JohnathanSullivan is offline
JohnathanSullivan is on a distinguished road
(5th Gen) Things I learned when swapping my Limited wheels with a different model yea
I decided to swap out the factory 20s on my 2016 Limited with a set of 17s off a 2018 SR5. I have my reasons. I couldn't find any definitive info out there before I swapped, so I decided to just go for it and see what happened. Hopefully this will help someone out in the future.
First thing I found was Toyota uses overlapping TPMS sensor numbers/frequencies. 2 of the wheels off the 2018 I swapped with would register on the tire shop's scanner as compatible with 2016, 2 did not. Therefore they sent me to the dealer to get the sensors reprogrammed.vidmate mobdro word counter
Second, the dealer cannot reprogram the TPMS sensors. They tried twice. Their efforts shut the TPMS light off for about 10 miles, then it came back on both times. Apparently you need to replace the sensors completely. At $150-$200 a piece (dealer quoted), I'll deal with the light. I have a couple of old cars I mess with so I'm used to checking tire pressures periodically anyway. Reprogramming may or may not work if you swap wheels with the same model year, but I cannot confirm either way.
Third, the Limited's spare is a full size 20" wheel and tire, just like the other 4 on the truck. The dealer could not confirm if the Limited has a 5th sensor in the spare or not. I feel it could, since it's a 5th premium wheel, but I can also see why it wouldn't since it's intended to be used as a spare. Additionally, don't forget to swap out your spares!! The 17" package is just slightly taller and a little wider. Mismatching tire height and width is not good for a full-time 4wd/AWD vehicle. The height difference might not be enough to cause any damage in the amount of time you'd be using a spare, but I'm not going to risk it.
JohnathanSullivan is offline   Reply With QuoteReply With Quote
Old 01-03-2020, 02:37 PM #4
pDubs's Avatar
pDubs pDubs is offline
pDubs is a glorious beacon of light pDubs is a glorious beacon of light pDubs is a glorious beacon of light pDubs is a glorious beacon of light pDubs is a glorious beacon of light
pDubs's Avatar
2014 SR5P
5100s w/Dobinsons 302/505 springs - SCS F5s - 285/70 Wildpeak AT3W - Prinsu Full Length Rack - Smittybilt Gen 2 RTT - Full RCI skids - RSG sliders - Pedal Commander - Gobi ladder - Rago brackets and 32" LED light bar- TSO TRD Pro grille - 5k HIDs - ARB diff breather - other small stuff
pDubs is offline   Reply With QuoteReply With Quote
cover , mechanic , miles , spark , valve
Spark Plug Tube Seal Replacement / Install yotaah 3rd gen T4Rs 7 01-04-2024 11:52 PM
Valve Cover Gasket / Spark Plug Gasket Repacement Jeremy556 5th gen T4Rs 23 05-17-2023 12:24 PM
Valve cover spark plug grommets/gaskets need help :( MuddyButt 3rd gen T4Rs 21 08-16-2015 09:58 PM
Spark Plug Wires and EGR Valve metallicarox Classic T4Rs 4 09-29-2008 09:13 PM
Spark Plug Tube Seal jetdrivr 3rd gen T4Rs 3 09-27-2006 04:58 AM
