Old 01-07-2020, 05:43 PM #1
eric_rosenwald's Avatar
eric_rosenwald eric_rosenwald is offline
eric_rosenwald is on a distinguished road
Battery Storage/Enclosure for 4WD Trips?
I want to start bringing an extra battery with me on my 4WD trips to isolated places.
What's the best way for me to secure the battery? Is there an enclosure that would work well? I'd like to be able to pack it in with plenty of other gear. If it were in a sturdy box or something, I imagine it wouldn't be as much of an issue if I stack equipment on it.
Thanks for the feedback,
Eric
eric_rosenwald is offline   Reply With QuoteReply With Quote
Old 01-08-2020, 04:45 PM #2
The battery would solely be be intended to install as a new battery. I have a GoalZero solar setup and I love it!
What's an AGM battery?
Thanks
Old 01-08-2020, 04:47 PM #3
Also:
I assume that after I buy the battery, I should have it plugged in with a trickle charger all the time. Or is it better to do something else? since it's new?
Old 01-08-2020, 04:52 PM #4
Bumbo's Avatar
Bumbo Bumbo is offline
Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of
Bumbo's Avatar
Thanks
AGM stands for absorbed glass mat.
In a nutshell it’s basically spill proof and can be mounted in any orientation unlike a regular flooded lead acid battery.
AGM is just a type of construction, and its available in various application blends from a regular starter to a deep cycle just like their flooded counterparts.
Old 01-08-2020, 04:54 PM #5
So it's essentially like a normal car battery, but just using a spill-proof technology? If so, are AGM batteries hard to find for a 200k T4R?
Old 01-08-2020, 04:55 PM #6
Bumbo's Avatar
Bumbo's Avatar
Also:
If you are storing it long term with no plans of using it, it would be best to connect it to the charger / maintainer.
If it’s just sitting in the back of the truck in a battery box for the purpose of having a spare for the trip, you can get away without doing anything other than making sure its full before you leave.
Old 01-08-2020, 04:58 PM #7
I should be more specific: I would be taking it in the battery box (thanks for the recommendation) a maximum of 5 days per month. Otherwise, I can leave it connected to the charger / maintainer in my house.
Given that, what kind of charging schedule/method would you recommend?
Old 01-08-2020, 05:00 PM #8
Bumbo's Avatar
Bumbo's Avatar
Yes, it’s a normal car battery.
AGM batteries are very common, but they generally cost a little more money than a flooded unit. You should not have a problem locating an AGM that would fit our 4Runners.
Many auto manufacture like BMW who install their batteries in the truck of vehicles all use AGM by default.
It is worth mentioning that some AGM manufactures will have a slightly higher top end charge voltage than others. It’s usually found on the more expensive high end deep cycle variants, but it’s not always the case. Nothing that would prevent you from throwing it in as a drop in, but would be worth noting for settings on your trickle / maintainer.
Old 01-08-2020, 05:03 PM #9
Bumbo's Avatar
Bumbo's Avatar
I would be perfectly comfortable leaving it in a battery box for the duration of the trip. 5 days is nothing for a battery just sitting especially if its stored at home on a maintainer.
You will be fine.
Old 01-09-2020, 01:02 PM #10
KWSRStorm's Avatar
KWSRStorm KWSRStorm is offline
KWSRStorm has a spectacular aura about KWSRStorm has a spectacular aura about
KWSRStorm's Avatar
You could get something like this and attach it to the box. Then all you need to do is plug it in. Internally it would be connected to the battery. So youre not dealing with unscrewing terminals each time you take it out of the car and have to charge it.
https://www.amazon.com/NOCO-Genius-G...8589134&sr=8-3
Sent from my SM-G973U using Tapatalk
KWSRStorm is offline   Reply With QuoteReply With Quote
Old 01-14-2020, 01:06 AM #11
Akkording's Avatar
Akkording Akkording is offline
Akkording is just really nice Akkording is just really nice Akkording is just really nice Akkording is just really nice
Akkording's Avatar
A marine battery box would work if you want to have it a sealed box, Google it and see if it would work for your intended use.
Goal zero make excellent products, they know how to market to their targeted audience.
2011 Starfire Pearl GX460 stock base ;)
2012 Blizzard Pearl SR5 | 285 Toyo OC AT3 | Level 8 Slam | YotaWerx ActiveDuty | Die Hard AGM w/ArcLightLeds V2 Booster | Borla 40665 | URD Y & MAF Cal TRD | C4 Center LP | Maxbore 2mm TB "loaner from my boy Dave" | X20 10k Factor55 | Shrockworks Armory | RCI LCA skids | TC Gusset | LFD Offroad 7/8 | TJM Airtec dry aFe HPS coupler w/TRD CAI tube | B8 6112 | 650# King | ICON Delta Joint | Fox 2.0 VS| SAW 1.5" |230k|
| 03 DCSB Tacoma OME equipped, +320k Still Truckin |
Akkording is offline   Reply With QuoteReply With Quote
Old 01-15-2020, 11:52 AM #12
sn_85's Avatar
sn_85 sn_85 is offline
sn_85 is a splendid one to behold sn_85 is a splendid one to behold sn_85 is a splendid one to behold sn_85 is a splendid one to behold sn_85 is a splendid one to behold sn_85 is a splendid one to behold sn_85 is a splendid one to behold sn_85 is a splendid one to behold
sn_85's Avatar
I still don't see the point of carrying a spare battery in your vehicle. When was the last time your battery died on you? I'd recommend bringing along a lithium battery jump pack instead. It's a lot less weight and easier to pack. You can jump yourself and then get a new battery once you're back on the road. And if you're going to bring a second battery with you at least make it functional and work for you. Run it as a dual battery setup or build an aux battery box to charge electronics from. Otherwise you're just carrying a 50lb battery that you will like never use.
https://www.amazon.com/NOCO-GB40-Ult...a-449394730282
Portable Power Pack – Equipt Expedition Outfitters
Auxiliary Battery Box – Equipt Expedition Outfitters
2016 Nautical Blue Metallic Trail | SCS | Falken Wildpeak AT3/W | Icon CDCV | Heftyfab Front Bumper | 4x4 Labs Rear | Shrockworks Sliders | RCI Skids | Warn VR10S | OGE Dual Battery System | sPOD | Katzkin
2013 Blizzard Pearl LE 4WD - SOLD!!!
sn_85 is offline   Reply With QuoteReply With Quote
Old 01-15-2020, 01:27 PM #13
Bumbo's Avatar
Bumbo's Avatar
He has a point… if you are carrying the battery primarily for the purpose of jump starting then there are other solutions worth considering that take up a lot less space and weight. The likelihood of experiencing a battery failure is also pretty rare, especially if you maintain the truck well, meaning changing the battery slightly ahead of schedule (3-5 years) to keep it fresh.
If you use the battery for running accessories, then you can consider just building it into the truck similar to a dual battery setup, or make a battery box / portable power pack and make it usable. You could easily make something like a goal zero unit for far less money and even be able to charge off the 4Runners electrical system when its running, just like a dual battery setup.
You can also downsize a project like this into something a bit more manageable depending on your needs. I built a very simple solar generator out of a 30 cal ammo cam. It includes a 17ah sealed lead acid battery, MPPT solar charge controller, USB charging, and 12v outputs to connect gear. I generally use this inside my tent to provide power for charging and lighting… and a 12v heated blanket because glamping.
I have a couple different solar panel I can use with it as well. If its connected in parallel with the trucks electrical system, can be used to charge the main starter battery as well.
Old 01-17-2020, 09:07 PM #14
AWDLiFE AWDLiFE is offline
Real Name: David
AWDLiFE is on a distinguished road
Real Name: David
Sick
AWDLiFE is offline   Reply With QuoteReply With Quote
4wd , battery , plenty , sturdy , trips
Road Trips: Where to go and What to see? Okki 5th gen T4Rs 7 07-26-2017 10:52 PM
Mid week trips Lego3k1 So Cal 7 06-02-2012 02:49 PM
2012 trips? mtbnole Central Overland Travels 5 01-30-2012 12:45 AM
Waking from winter storage: Battery reconnect txtroutbum Classic T4Rs 0 06-04-2007 06:28 PM
