Old 01-17-2020, 11:02 PM #1
missslucrew's Avatar
missslucrew missslucrew is offline
missslucrew is on a distinguished road
I need your advice on snow cables
Yes.... the dreaded snow chain/ cable question. Ive tried to search for the answer but every website has a different answer!!!
I have a 2004 Limited (best car ever btw)... should I put snow cables on all 4 tires or just the rear... or front????
I know I should know this! My guess is all 4 to get the most traction.... but then I read somewhere that your could damage the front brake line?
Any input is greatly appreciated!
I need your advice on snow cables-20200117_182920-jpg
2004 Limited V8 4x4 Titanium Metallic / 2007 Chevy 2500 Diesel
missslucrew is offline   Reply With QuoteReply With Quote
Old 01-18-2020, 01:10 PM #2
BlackCloud's Avatar
BlackCloud BlackCloud is offline
BlackCloud has a spectacular aura about BlackCloud has a spectacular aura about
BlackCloud's Avatar
I always thought rear only.
BlackCloud is offline   Reply With QuoteReply With Quote
Old 01-18-2020, 09:34 PM #3
cb1111's Avatar
cb1111 cb1111 is offline
cb1111 is a splendid one to behold cb1111 is a splendid one to behold cb1111 is a splendid one to behold cb1111 is a splendid one to behold cb1111 is a splendid one to behold cb1111 is a splendid one to behold cb1111 is a splendid one to behold
cb1111's Avatar
This is not very ambiguous.
When in trouble - obfuscate
cb1111 is offline   Reply With QuoteReply With Quote
Old 01-19-2020, 07:51 AM #4
Sky Sky is offline
Sky will become famous soon enough Sky will become famous soon enough
Sky Sky is offline
Originally Posted by cb1111 View Post
Except it doesn't answer the question of front or rear on AWD/4WD.....they state all 4 tires on AWD/4WD should have chains.
But most people likely don't have 2 pairs of chains.....
2019 4Runner TRD Off Road Premium
2011 FJ Cruiser TRD
1974 FJ40 (wish I still had it)
Sky is offline   Reply With QuoteReply With Quote
Old 01-19-2020, 12:29 PM #5
lakerman lakerman is offline
lakerman is on a distinguished road
Says somewhere not to put on the front, lines or something are going to get damaged, it's here somewhere on the forum, just don't do it!, more experienced people need to chime in. Never needed a set in my life, a shovel yes, guess I'm not pushing the boundaries hard enough!
lakerman is offline   Reply With QuoteReply With Quote
Old 01-19-2020, 05:24 PM #6
Banned
Real Name: Mark
ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future
Banned
Real Name: Mark
Rear
In 30 years of driving a 4R on roads in the Sierra in winter I only put chains on once when required by a Yosemite NP ranger. On the rear tires only. They do loosen up a bit and if you go too fast they can slap around (centrifugal force). Hence the warning about installing them on front tires.
Old 01-19-2020, 09:12 PM #7
cb1111's Avatar
cb1111's Avatar
From the link:
If tire chains are required, here are 10 basic guidelines for their use:
Tire chains should be installed on the drive wheels of the vehicle following the chain manufacturer's instructions, To retain as much of the normal handling characteristics of 4WD/AWD vehicles as possible, tire chains should be installed on all four tires, requiring the purchase of two pairs of tire chains.
That said, and given the comments from "internet experts" here that say "I read somewhere that..", I'd open a case with Toyota and ask them.
Or you can just get spikes spider
Old 01-20-2020, 06:03 AM #8
Sky Sky is offline
Sky Sky is offline
From the link:
Again- that doc does not answer the question of front or rear if a person only has one set of chains for an AWD/4WD vehicle.
But here comes a shocker>
page 272 of the '19 4R owner's manual
states they go on the rear.
I need your advice on snow cables-4rchains-jpg
2011 FJ Cruiser TRD
Old 01-20-2020, 12:15 PM #9
cb1111's Avatar
cb1111's Avatar
If you only have one set of chains then they go on the drive wheels.
Interesting note about the owner's manual. Since the 4R is available in AWD/4WD and 2WD, does the manual specify if that applies to both?
On a side note. I've used Spikes Spiders before and they are quite good. Very quiet and no flapping chains.
Old 01-20-2020, 12:57 PM #10
Sky Sky is offline
Sky Sky is offline
Nope- they don't address 2wd vs 4wd.
Found another mention in the manual on page 274 where they state
■Tire chain installation
Observe the following precautions when installing and removing chains:
●Install and remove tire chains in a safe location.
Install tire chains on the rear tires only. Do not install tire chains on the front tires.
●Install tire chains on rear tires as tightly as possible. Retighten chains after
driving 1/4-1/2 mile (0.5-1.0 km).
●Install tire chains following the instructions provided with the tire chains
2011 FJ Cruiser TRD
Old 01-20-2020, 01:34 PM #11
Banned
Real Name: Mark
Banned
Real Name: Mark
If you’re getting equipped for a winter ski trip, and want to comply with the CA requirements, you just need to carry one set for the rear tires. With a 4WD vehicle you don’t need to install them under R1 or R2 conditions as long as your tires are considered snow tires (M/S). In R3 conditions (snow falling, deep snow on road) all vehicles need chains. But usually before that happens CalTrans will close the road anyway.
Caltrains chain info:
Chain Controls / Chain Installation | Caltrans
So, you’ll rarely, if ever, need to install them. But practice at home, they can be a PITA especially in the cold and with gloves on. Have fun in the snow!
Old 01-20-2020, 01:50 PM #12
Bumbo's Avatar
Bumbo Bumbo is offline
Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of
Bumbo's Avatar
One of the reasons I love having a AWD/4WD truck is for R2 conditions. I hate stopping at chain control.
In the few times I did have to put on chains:
FWD – In the front
RWD – In the rear
AWD/4WD – Rear if only 1 set of chains
I carry 2 pairs for all 4 wheels, but have never needed to use them all at the same time. Even in crap conditions it’s pretty amazing what you can do in AWD with the right tires.
Old 01-20-2020, 03:49 PM #13
MTn_man MTn_man is offline
MTn_man is on a distinguished road
Really depends on what types of conditions you are planning on driving in. I have a front and rear set, but usually only carry one. First off if you have good tires, you should be able to get through most reasonable snow conditions. For example I had my runner up to the doors in loose power a few weeks ago without chains. Snow was light and the base layer was compact with good traction. I've had all 4 tires chained up in 1/2 in of fresh with a layer of ice. Needed the chains to bite into the ice and a set on front and back to keep both ends heading in the right direction. To me it seems that snow that is deep enough to require front and rears is better suited to skis or a sled.
Chains on the back seem safer to me and if I chains up it's always rear first. Throwing a chain kinda sucks and there is a lot less stuff in the rear to damage than the front.
2007 SR5 4.0 V6 210k
MTn_man is offline   Reply With QuoteReply With Quote
Old 01-20-2020, 04:23 PM #14
Bumbo's Avatar
Bumbo's Avatar
If you actually NEED all 4 wheels cabled/chained on a 4WD 4Runner, then those conditions are probably so wild that that they would probably close the road to all motor traffic.
answer , cables , front , input , snow
Snow chains, not cables loko ino Want to Buy/Trade 7 02-11-2013 01:47 PM
Snow tire cables 810moto For Sale: Non-T4R Items 0 12-04-2011 01:38 AM
Snow Cables or Chains? Jaebster 4th Gen T4Rs 1 12-07-2007 05:02 PM
Snow chains/cables ran 4th Gen T4Rs 2 11-19-2007 05:32 AM
$60 new snow cables for SE RXvedub So Cal 0 03-13-2006 12:16 AM
