Old 01-30-2020, 05:07 PM #16
Jetboy's Avatar
Jetboy Jetboy is offline
Jetboy has much to be proud of Jetboy has much to be proud of Jetboy has much to be proud of Jetboy has much to be proud of Jetboy has much to be proud of Jetboy has much to be proud of Jetboy has much to be proud of Jetboy has much to be proud of Jetboy has much to be proud of Jetboy has much to be proud of
Jetboy's Avatar
Originally Posted by Drunner97 View Post
You'd have to destroy the inner cup/stub shaft before a flopping axle would damage the seal. The inner stays seated in the differential regardless of where the break occurs (unless you snap it at the inner stub shaft, at which point you're screwed anyway) and protects the seal from damage. 9/10 times you're going to destroy the outer cage before the stub shaft or cup fail. Only damage is likely to happen on the R&R. I'm not saying carrying extra seals is a bad thing, I'm just saying you're unlikely to ever actually need to use them. Especially if you're not locked in the front.
Probably right. The fit is pretty loose in the bearings though. There's about 2-3mm of wobble in the cup by hand. Feels like a loose shaft could flop pretty good in the same type of situation where you'd blowup the t-case output shaft bearing/seal with a drive shaft failure. I'm thinking something more like WOT up a sand dune, not so much in slow speed rock crawling. I'm not sure how much the seal can take. May have plenty of flex to handle as much movement as the inner cup can move.
I'm unlocked my T4R. Went through 2 ARBs and sold warranty replacement #3 and now am back to open front. Probably not too much risk open. I also don't do the hardcore stuff in my daily driver. The Rubicon is probably the hardest trail I've done in my 5th gen and I've been through a couple times without breaking anything. So I actually feel pretty okay about going most places without a spare, but I still take one mostly because I have it, so it make sense to toss it in. Anything more than that and I'd take the trail rig.
Old 02-23-2020, 12:32 PM #17
Tielemans Tielemans is offline
Tielemans is on a distinguished road
I definitely wanted to complete it. Friend broke a cv and just dropped roblox music codes it back to 2wd and drove home and replaced it.
Tielemans is offline   Reply With QuoteReply With Quote
backup , broken , replaced , sm-g955u , trail
Rear Axle Seal: Axle Puller Tool Design nobb 3rd gen T4Rs 29 11-23-2019 07:39 AM
Q: Replace axle bearings&seals or find assembled axle? Mutant 3rd gen T4Rs 12 09-14-2017 10:35 AM
Wiring aux backup lights to a switch and factory backup lights Miyota 3rd gen T4Rs 6 12-29-2016 11:03 AM
Rear axle/suspension problem-axle shifts when going on/off the gas Rusty Plum 3rd gen T4Rs 7 09-07-2014 09:46 PM
Solid Axle Swap vs regular axle w/ lift/suspension? priestsallore Classic T4Rs 9 04-28-2010 11:30 PM
