01-26-2020, 01:51 AM
Real Name: Andrew
Real Name: Andrew
Technical Question: Upgrading OEM Coils, Keeping Stock Shocks
Hey guys,
Former Tacoma owner here so I'm a little unfamiliar with modding the rear of the 4runner. I just ordered a set of ICON 2" rear coils and I hear a bunch of people claim its alright to run a 2 inch spacer with stock shocks.
So my question is this: From an offroad/suspension geometry perspective, what am I risking by sticking with factory shocks for the time being? Am I losing flex? Am I risking blowing the stock shocks with the increase ride height?
Thanks in advance!
01-26-2020, 07:35 AM
Originally Posted by DirtyHarry
Hey guys,
Thanks in advance!
Hey there, just to make sure Im understanding you, you plan to put in 2in icon coils in the rear and a spacer puck in the front? If so, shouldn't be a problem but if you're looking for more flex/travel, you'd need to go with a different set up. If just looking for height/stance, you should be fine.
2019 ORP - KDSS, Dobinsons C59-302/GS59-700 front and C59-725/IMS59-50701 rear, Dobinsons UCA, DuroBump/Daystar bumpstops, Sonoran Steel High Articulation tracbar, Marlin Crawler LCA frame brace, OGS Lo-Key Bumper w/ Warn VR EVO 10-S, RCI Sliders, fully armored with RCI/C4/Outgear Solutions skids, Falken Wildpeak M/T 285/70/17, LFD SS-Crossbars, ARB breather kit (Rear Diff and Locker), ScanGaugeII, Anytime Front/Backup Camera, onboard ARB Twin compressor MORRFlate kit, and DD SS3 Sport fogs
01-26-2020, 01:35 PM
I would think..
Hey guys,
Thanks in advance!
that the OE rear shocks aren't intended to be used with a lift spring. A spacer would work fine until you can get a lift goin.
01-27-2020, 02:42 PM
Real Name: Andrew
Real Name: Andrew
But will it work? Whats the difference between using a lift spring and a 2 inch spacer like many guys do?
01-27-2020, 02:44 PM
Real Name: Andrew
Real Name: Andrew
I've got Fox 2.0 coilovers in the front now, but I'm stock in the rear. I was hoping to use a lift coil spring in the rear in lieu of a spacer with the stock OEM shocks for the time being.
I wanted to make sure that was safe first.
01-27-2020, 04:50 PM
I believe member MAST4R was running stock shocks (rear) with lifted coils and had no issues. Could be wrong though, so check with him for sure!
01-27-2020, 05:10 PM
Real Name: Andrew
Real Name: Andrew
Thank you sir! I will swap them eventually, but I only have like 11k on the stock suspension and I was hoping to save for a while before I drop another couple hundred bucks.
01-28-2020, 11:15 AM
Real Name: Andrew
Real Name: Andrew
Hey so just and update. I read a bunch of MAST4R's posts but couldn't decipher whether or not he ran stock shocks with aftermarket lift coils. I chickened out and ordered some 1-3 inch fox 2.0 IFP shocks to match the front. Who needs savings anyway?
