Old 02-03-2020, 10:07 PM #1
Syr4RinNC's Avatar
Syr4RinNC's Avatar
ABS wiring split/ dealer won't cover under warranty
Just wanted to poll the forum's thoughts on this issue
My wife's 4runner is 2 years old, under warranty.
We got a warning on the dashboard about the ABS system malfunction and took it into the local dealer.
Apparently a wiring into the wiring harness near the rear driver side wheel/ break caliper split.
They felt that this was due to a stick or rock or normal debris from driving ending up in the undercarriage damaging the wiring
Theres no other damage to the vehicle what so ever.
They refused to cover this under warranty and stated that even though this was normal wear and tear this is due to normal hazards of driving.
Do you all generally agree with this that Toyota shouldn't cover this or has anyone had dealers cover this type of problem under warranty?
For normal people this would be a $0 fix of splicing wires together. At a dealership it was outrageous.
You can see the blue wire separated in the middle harness below
ABS wiring split/ dealer won't cover under warranty-image000000-jpg
Old 02-03-2020, 10:21 PM #2
Spinnukur's Avatar
Spinnukur Spinnukur is offline
Spinnukur is on a distinguished road
Spinnukur's Avatar
I had my driver's side, front, replaced under warranty. They did it once and stated it would probably not be approved again as I have a 3" lift.
I think it depends on the dealership and/or the rapport you have with your advisor at said dealership.
Hope it helps.
ICON S6 w/DJ UCA & rear upper+lower link kit | ICON rear track bar | C4 Fab Low Pro FB & RS | Shrockworks RB w/TC and Rigid LEDs | Nitto Ridge Grapplers 285/70R17 | SCS F5 | Smittybuilt 9.5K Winch | Extreme LED Front & Rear Lightbars | SSO Camera Relocation Kit | SPOD HD | Factor 55 Pro-Link, Hawes Fairlead, & Hitchlink 2.0 | Gobi Stealth Rack w/Ladder & Tool Box | Toyota LED Halo Foglights w/Daytime Running | XD 4300k Philips HIDs | Philips LED Interior and Exterior | MaxTrax & EEZI-AWN K9 MaxTrax Mount | Scepter Fuel Cans - MILSPEC | Denver Outfitters Rod Vault | ARB 2000 Awning | Krazy Beaver Blackout Shovel | ICON lower control arm & skid plate protection
Spinnukur is offline   Reply With QuoteReply With Quote
Old 02-03-2020, 10:33 PM #3
Syr4RinNC's Avatar
Syr4RinNC's Avatar
Hope it helps.
Thanks- I appreciate that.
The manager's response was that they have to send pictures/ a report for all warranty requests and that Toyota would deny this anywhere.
Im sure that answer is somewhere in between that if you have a good relationship/ know the dealership they'll cut you a break vs what Toyota should/ will cover
Old 02-03-2020, 11:03 PM #4
spartacus's Avatar
spartacus's Avatar
You can File a complaint with Toyota hq and see what they say could be worth a shot.
Old 02-04-2020, 12:53 AM #5
phlawx's Avatar
phlawx phlawx is offline
phlawx is on a distinguished road
phlawx's Avatar
Sounds like a lazy dealership manager with a weak argument (rock or stick??)
”AIRWOLF” 2017 TEP KDSS MGM
OME BP-51 / bfg ko2 / gobi stealth / rigid adapt / switch-pros 9100 / arb on-board air / OEM audio plus reference 500 / blackout trd pro trim / sunroof / behind grille [rago fab] / next up: kustom54 headlights + winch + skid plates + 2nd battery
phlawx is offline   Reply With QuoteReply With Quote
Old 02-04-2020, 08:49 AM #6
SR5Bart SR5Bart is offline
Real Name: Bart
SR5Bart has a spectacular aura about SR5Bart has a spectacular aura about
Real Name: Bart
Call 800 331-4331 Toyota customer support in Plano TX. Long as the vehicle is stock I can pretty much put my job on the line that they will cover it
I just had a customer with a 2010 highlander his rear diff went bad they threw in $2500 good will money towards the repair since he buys only Toyota and services them here as well.
18 Trail. Cookie cutter built (SOLD)
14 SR5P (SOLD)
SR5Bart is offline   Reply With QuoteReply With Quote
Old 02-04-2020, 09:23 AM #7
thennen's Avatar
thennen thennen is offline
thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold
thennen's Avatar
Something outside the vehicle broke that wire, and I imagine that maybe a light came on right when it happened?. I personally don’t think manufacturers should be held accountable for road hazards that break things. I’m guessing the warranty is pretty clear on what’s covered.
If it really is a $0 fix to splice it back together, I’d go ahead and do that if I were you. The dealer may be obligated to go further if they do the repairs - splicing/repairing that ABS wire may present a future liability for them, in which case they’ll probably quote you for replacing the harness or something similar. I wouldn’t sweat going after a free repair if it were me.
thennen is offline   Reply With QuoteReply With Quote
Old 02-04-2020, 12:43 PM #8
GripT4R GripT4R is offline
Banned
GripT4R is a glorious beacon of light GripT4R is a glorious beacon of light GripT4R is a glorious beacon of light GripT4R is a glorious beacon of light GripT4R is a glorious beacon of light GripT4R is a glorious beacon of light
Banned
Spend 60 seconds and fix it yourself.
GripT4R is offline   Reply With QuoteReply With Quote
Old 02-04-2020, 12:50 PM #9
Syr4RinNC's Avatar
Syr4RinNC's Avatar
So I talked with the dealership where I bought it
- they laid it out exactly as you all have said. That dealerships that you have a good relationship with will often cover things like this once under good will, but it is not a warranty issue.Thanks for the customer service contact info. I may try that before going back to the service manager here.
Old 02-04-2020, 01:39 PM #10
Drunner97's Avatar
Drunner97 Drunner97 is offline
Real Name: Danny
Drunner97 will become famous soon enough Drunner97 will become famous soon enough
Drunner97's Avatar
Real Name: Danny
Was the electrical tape around the wire chewed up like that when you took it in or did the dealership do that? If it was chewed up when you took it in, something hit it and split it. Looks like a fairly clean cut though, which is odd. Would have had to be a pretty sharp rock or stick and I'm not seeing any other damage around it. Wires don't typically get cut, they typically get yanked out of the connectors and if that's the one that I think it is, it's tucked up high enough on the frame that you're going to have to try really hard to make it split right there.
edit: that close to the plug you'd expect a lot more damage/scrapes/scratches on nearby components if it was indeed a rock or a stick. That almost looks intentionally cut.
build thread: https://independentoffroading.com/in...xit-thread.30/
IG: @4runner_doa
Drunner97 is offline   Reply With QuoteReply With Quote
Old 02-04-2020, 06:34 PM #11
Syr4RinNC's Avatar
Syr4RinNC's Avatar
Its all very confusing to me. I believe the electrical tape/ wrap was cut back by the dealership
Old 02-05-2020, 01:26 PM #12
Syr4RinNC's Avatar
Syr4RinNC's Avatar
The customer service rep I had basically said that they stand by the service submission and support the dealerships. Had the dealership submitted this under good will, Toyota would have likely approved the repair. Because the dealer did not submit it under good will and continue to stand by it is my responsibility then the customer service reps dont have the ability to over-rule them and submit it for good will.
Old 02-05-2020, 01:32 PM #13
Real Name: Bart
Real Name: Bart
Sounds like a bunch of aholes at that dealer. Sorry man
14 SR5P (SOLD)
Old 02-05-2020, 02:24 PM #14
Syr4RinNC's Avatar
Syr4RinNC's Avatar
Agreed - thanks
Old 02-05-2020, 07:33 PM #15
Drunner97's Avatar
Real Name: Danny
Drunner97's Avatar
Real Name: Danny
Solder the wires back together and call it a day. It's simple enough. You could try to fight the dealership, but the reality of it is that this still almost looks like vandalism to me. The cut is too clean, and honestly I've dragged my rig over enough rocks, sticks, bushes, twigs, whatever and never torn an abs wire. I did however easily pull all 4 wires out of the connector working on my suspension. So the wire should have pulled out, before looking like a clean cut. Something sharp did that.
IG: @4runner_doa
cover , due , normal , warranty , wiring
Dealer vs. owner oil changes -- void warranty? 93toy 5th gen T4Rs 17 11-18-2021 05:33 PM
Will the dealer warranty this? jonesmw10 4th Gen T4Rs 3 07-04-2015 11:33 PM
Please, where does the brake wiring split edwardvmassey 4th Gen T4Rs 1 12-02-2014 11:06 PM
Which dealer for warranty work? JB. Problems & Warranty Issues 2 10-27-2010 02:49 PM
Warranty Good at Any Dealer? Jimbo Problems & Warranty Issues 4 02-08-2005 06:14 PM
