Old 02-15-2020, 04:21 PM #1
@jrfordlandia's Avatar
@jrfordlandia @jrfordlandia is offline
Real Name: Jason Ford (not related to Henry or Harrison)
@jrfordlandia will become famous soon enough
Need help on Toyota electrical
Do these plugs look like corrosion that might cause a battery short or computer short? Trying to debug a short and stumbled on these two plugs that look noticeably different than all the other wiring harness connections. My battery keeps draining and shorting out.
(Note, this is for my Camry, but I'm an active 4Runner owner and poster on here as well.)
Thanks for any advice, Jason
Need help on Toyota electrical-20200215_122258_26d32ece74fd449b812edd3663224bf8d6823515-jpg  Need help on Toyota electrical-20200215_122312_9bed0a1b1ead62ffce40e3986629e5d4e7397b25-jpg
2018 4Runner 4x4 SR5P, Super White w/Third Row, 285-KO2's, SCS Ray10’s, Dobinson 302/505 springs with 700/705 gas shocks, Tandem Sliders, TRD Skid, Cold Air Intake
2015 4Runner 4x2 SR5 Premium, 5100’s, KO2's, Super White (sold)
@jrfordlandia is offline   Reply With QuoteReply With Quote
Old 02-16-2020, 12:25 PM #2
AuSeeker AuSeeker is offline
Real Name: Skip
Real Name: Skip
Hard to tell from the photo, but does the plastic part of the plug appear to be melted or is that some type of grease?
Also what does the other part of the connector that the one you posted connects too look like?
2004 Limited V8
Old 02-16-2020, 01:06 PM #3
It is grease but none of the other large connectors on that same pillar have that look. They all look clean and clear. The brown smears off and doesn’t appear to be melted. I can’t tell if the pins have corrosion based on the angle of their location. I’ll try to get more pics. Maybe I should put an ohm meter on it to look for a connection.
Old 02-16-2020, 01:42 PM #4
Shiftless Joe's Avatar
Shiftless Joe Shiftless Joe is offline
Shiftless Joe is on a distinguished road
The clean grease was protected from dirt, the brown stuff is slightly contaminated with dirt. Perfectly normal.
Shiftless Joe is offline   Reply With QuoteReply With Quote
Old 02-16-2020, 01:50 PM #5
Real Name: Skip
Real Name: Skip
It's most likely dialectic grease which is a non-conductive grease used to keep moisture and corrosion from getting into or forming in a connection, being a non-conductive material many say it can prohibit a good connection if applied to the actual contacts and should only be used for sealing a connection after it's been connected, I somewhat disagree with that because as long as the metal contacts/connectors are tight fitting the connection is there and the grease doesn't interfere with the connection because because the tight metal to metal contact is a good connection and any of the dialectic grease is squeezed out of the metal to metal contact.
It wouldn't be a bad idea to clean some of the grease from the connection if it is some other type of grease or Vaseline which are conductive and could cause a short between connectors, but if it is indeed dialectic grease I doubt it will make any difference.
Which connection exactly is this connector for?
Do you know the entire history of the vehicle?
If not it could of at one time been in a flood or submerged in water to some degree and whoever salvaged it used the grease to repel moisture.
2004 Limited V8
Old 03-08-2020, 11:50 AM #6
klesfein klesfein is offline
klesfein is on a distinguished road
liteblue?
Thanks for the solution. I have been looking for the solution from long time.
klesfein is offline   Reply With QuoteReply With Quote
Old 03-08-2020, 07:14 PM #7
Sky Sky is offline
Sky will become famous soon enough Sky will become famous soon enough
Sky Sky is offline
Your Vaseline claim intrigued me- so I stuck my high $$ Fluke DVM probes in a jar of Vaseline. Nope not conductive
2019 4Runner TRD Off Road Premium
2011 FJ Cruiser TRD
1974 FJ40 (wish I still had it)
Sky is offline   Reply With QuoteReply With Quote
Old 03-08-2020, 07:31 PM #8
Real Name: Skip
Real Name: Skip
Hmmm, I just use Vaseline as an example since it's a petroleum product I was sure it was conductive, but for a sure test try inserting a 120 volt hot wire into a jar of Vaseline and then stick your finger in there.
I did check and you're correct but I would still advise not to use Vaseline on electrical connections since being a petroleum product it could degrade the insulation on wiring.
2004 Limited V8
Old 03-08-2020, 08:20 PM #9
Sky Sky is offline
Sky Sky is offline
I'll pass on the 120V finger stick in thing....
Oh..and good point about petroleum possibly degrading insulation.
2011 FJ Cruiser TRD
battery , draining , note , plugs , short
1995 Toyota Truck Factory Service Manual, Vol 2 , chassis, body, electrical. $25 gtgt_bangbang For Sale: T4R Items 0 01-18-2015 04:57 PM
1991 toyota 4runner electrical issues!!! HELP? syher1 Classic T4Rs 0 10-08-2011 11:15 AM
Toyota 4X4 with Odd Electrical Problem toy4runr General Discussions 0 06-23-2011 02:49 PM
FS: Various Toyota electrical parts and switches 84-95 4Runner/trucks Jamesd Classifieds - buy & sell (no commercial ads please) 0 10-04-2009 03:58 PM
Where to buy Toyota electrical plugs? control Engines / Suspension / Wheels / Tires / Audio / Accessories 0 01-08-2009 10:08 AM
