Old 03-25-2020, 05:05 PM #1
patkelly4370's Avatar
patkelly4370 patkelly4370 is offline
patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold
Aftermarket skidplate/oil change question
I currently have OEM setup. I'm about to do my first 4runner oil change.
I remove a cover plate to access the drain plug.
My question is:
Aftermarket skids have hole to drain the oil. Do you leave the OEM cover off with aftermarket skid?
patkelly4370 is offline   Reply With QuoteReply With Quote
Old 03-25-2020, 06:17 PM #2
Captsolo Captsolo is offline
Captsolo will become famous soon enough
I have a 2005 SR5 with the same skid plates as yours.
The piece that allows you to drain the oil has been gone on mine for years. Apparently one of the mechanics that changed my oil over the years just left it off.
I'd leave it off. I think that piece is "plastic" but not sure as mine has been gone for years.
I do my own oil changes now. Fooling with that "plate" on every oil change is absurd.
Captsolo is offline   Reply With QuoteReply With Quote
Old 03-25-2020, 06:32 PM #3
spartacus's Avatar
spartacus's Avatar
I think most if not all have an access for the drain bolt some like rci have a panel with a allen bolt to cover the drain bolt.
Old 03-26-2020, 09:56 AM #4
pDubs's Avatar
pDubs pDubs is offline
pDubs is a glorious beacon of light pDubs is a glorious beacon of light pDubs is a glorious beacon of light pDubs is a glorious beacon of light pDubs is a glorious beacon of light
pDubs's Avatar
^The RCI skids have a hole drilled in for the drain plug. Then a window with allens for the oil filter.
I have full RCI skids. I have found it's not worth leaving the skids on to try and do an oil change. Twice now (don't really know why I tried a second time) the oil poured out through the hole in the skids fine at first, then began coming out slower and literally went all over the top side of the skid plate. Oil was then seeping out in between the front and transmission skid, out the sides, just everywhere.
Same goes with the window for the filter. I think the only way it would work well is with the fumoto drain valve with tubing coming down through the hole, and the motivx filter drain tool as well.
Toyota 4Runner Oil Filter Tool List for DIY Oil Change from Motivx Tools
2014 SR5P
5100s w/Dobinsons 302/505 springs - SCS F5s - 285/70 Wildpeak AT3W - Prinsu Full Length Rack - Smittybilt Gen 2 RTT - Full RCI skids - RSG sliders - Pedal Commander - Gobi ladder - Rago brackets and 32" LED light bar- TSO TRD Pro grille - 5k HIDs - ARB diff breather - other small stuff
pDubs is offline   Reply With QuoteReply With Quote
Old 03-26-2020, 10:43 AM #5
That was my next question.
I just ordered the Fumoto valve. I was wondering about clearance to the skid plate.
Also, has anyone broken or worn out the plastic oil filter housing? Flip flopping on whether to buy the metal housing.
Old 03-26-2020, 11:46 AM #6
pDubs's Avatar
pDubs's Avatar
With the OEM skids I never had a problem draining the oil through the big window. It's the RCI skids that have a smaller hole and I had problems with.
I changed to a metal oil filter housing, and swapped the stalk on the inside of housing over after cracking my plastic one trying to remove it. I used this one: Amazon.com: Genuine Toyota 15620-31060 Oil Filter Cap Assembly: Automotive
2014 SR5P
Old 03-26-2020, 03:20 PM #7
Twilghtzone Twilghtzone is offline
Twilghtzone is on a distinguished road
Nope, the plate is steel. IMHO:Undoing 2 bolts is not a deal-breaker.
That said... an oil drain valve is a good investment (Like Fumoto).
Avoids taking the oil drain plug out of the aluminum pan.
Steel bolt/Aluminum threads... over (maybe lots'a) time the Aluminum will wear/strip out.
>"Also, has anyone broken or worn out the plastic oil filter housing? Flip flopping on whether to buy the metal housing."
I bought the metal housing. Works fine... just oil/grease/never-seize the threads as you put it in for the first time.
Twilghtzone is offline   Reply With QuoteReply With Quote
Old 03-30-2020, 01:47 PM #8
shadow247's Avatar
shadow247 shadow247 is offline
shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice
shadow247's Avatar
Factory Skids on my 3rd Gen, and I just remove the plate every time. It's only once every 6 months anyway, and it gives me a good chance to look at everything that is hidden by the skids and give it a good inspection. I usually go ahead and power wash it when I've got it out and hit it with a fresh coat of rustoleum if there's any scratches on it.
The 4Runner Show
shadow247 is offline   Reply With QuoteReply With Quote
aftermarket , change , cover , drain , oil
Question for past or present RCI skidplate owners. Velonici 4th Gen T4Rs 11 07-12-2018 05:00 PM
Oil filter change no skidplate removal required ron in sc 5th gen T4Rs 13 02-01-2016 09:09 PM
Aftermarket Skidplate Recommendations Please! zerowkul98 4th Gen T4Rs 6 07-26-2011 08:04 PM
CV boot change vs replacing w/aftermarket axle chayos00 General Discussions 18 12-15-2009 06:51 AM
Skidplate Question on 01? daugherty83 3rd gen T4Rs 3 10-07-2009 07:04 AM
