04-25-2020, 09:35 PM
How does the oil change algorithm know synthetic or mineral oil in car?
2010 4Runner w/ 113000 miles.
The oil age "sensor" is apparently an algorithm that uses vehicle usage and ambient conditions to calculate when to change the oil. Since synthetic oil is much more resilient than petroleum oil, what is the calculation based on? Do I assume the system is assuming petroleum oil is being used, or does it have a magic dipstick that senses synthetic oil. In other words, how real is the notification to change the oil if I'm using synthetic oil?
thanks.
04-26-2020, 04:51 PM
Real Name: Skip
Real Name: Skip
thanks.
The "Maint" /oil change light comes on based on mileage, it doesn't care what kind of oil you use because it's just a reminder light set to come on after a certain number miles after it was reset during the last oil change!
On my 4th Gen it's 5000 miles.
2004 Limited V8
It doesn’t know.
Current - 2016 Mag Gray SR5, 3rows - diode dynamics fogs, tint, FalkenAT3W, blacked out badges, more to come
Old - 2008 Black sr5 v6 - Bilstein 5100s, FJ rears, black counter steers, xenon depot h11 hid kit, Scion Radio upgrade (touchscreen), BHLM, tint, Cooper AT3s.
04-27-2020, 11:00 AM
Your 2010 4runner takes 0W-20 oil, which only exists in synthetic...
2014 SR5P
5100s w/Dobinsons 302/505 springs - SCS F5s - 285/70 Wildpeak AT3W - Prinsu Full Length Rack - Smittybilt Gen 2 RTT - Full RCI skids - RSG sliders - Pedal Commander - Gobi ladder - Rago brackets and 32" LED light bar- TSO TRD Pro grille - 5k HIDs - ARB diff breather - other small stuff
04-27-2020, 11:30 AM
Real Name: Sparky
Real Name: Sparky
It has an idiot light that comes on with mileage intervals that is supposed to be reset by the service tech, but it rarely is.
Old and (c)rusty.
04-27-2020, 01:19 PM
Also, as other have mentioned, it's simply every 5,000 miles, the "Maintenance required" comes back on.
My wife has a Chevy Suburban which calculates idle time, cold starts, vehicle speed, RPM, mileage, etc to factor in when the oil should be changed. Much more realistic than just saying replace every X,000 miles.
2014 SR5P
04-27-2020, 02:08 PM
Real Name: Sparky
Real Name: Sparky
My Macan does that, also measures the oil level since there's no dipstick.
Old and (c)rusty.
